02-22-2020, 14:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: rajasthan
Member: 597610 Status: Offline Thanks Meter: 50 | EMMC RPMB is not yet programmed (clear) or RPMB Read failure EMMC RPMB is not yet programmed (clear) or RPMB Read failure EasyJtag Suite Classic ver.: 3.6.1.4 / wxWidgets 3.1.2-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA3B-935B , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM1 ACPI\PNP0501 Communications Port (COM1) COM98 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Plus Control Port (COM98) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0B0110131696BB1A, ,FW Ver.: 01.63 CMD Pullup Level:443 mV CMD Active Level:2258 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A483847347492012827E14B249C eMMC CSD : D02701320F5903FFFFFFFFE78A40002A eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2017 Rev.0x1 eMMC NAME: H8G4t , S/N: 673702219 eMMC NAME (HEX): 483847347420 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB Read failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4t_ 673702219_20200222_1854.extcsd please tell me write process clear RPMB |
