07-31-2018, 18:44 | #1 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | EasyJTAG Plus (eMMC Tool Shuite): Log of changes, khown bugs and info about fixing it just about 17.05.2016 (ver 1.0.0) - Initial Release 30.11.2016 (ver 1.0.0.39) Fix: Bug with the smart card at the start of the program Fix: Bug when processing sparse image Fix: Bug with extract data from contacts2.db Fix: Writing for some MTK images Fix: Bug when opening MTK-partitions in the Explorer Add: Reading tables from emmc on the Factory tab (for writing partitions if you do not have a header file) Add: Support GP-partitions Add: Option "Write all eMMC Regions at once" Add: Automatically sending crash reports Add: Button "Sending crash report for the current log" Add: Notification in the system tray Add: Adding ROM2 when reading from the image Add: Automatic writing configuration for MTK after flashing Add: Some GUI changes 02.12.2016 (ver 1.0.0.40) Fix: Bug with switching ROM Fix: Bug with access to GP-partitions Fix: Bug when searching for FRP Add: Generic / Universal Factory Format (Toshiba, Hynix, etc.) 08.12.2016 (ver 1.0.0.41) Fix: Bugs that have been found through your crash report 11.12.2016 (ver 1.0.0.42) Fix: Fixed force erase timeouts detection (Universal Factory Format) 09.03.2017 (ver 1.0.0.43) Fix: Bugs that have been found through your crash report Add: Some improvements Add: Write by vendor "Spreadtrum" (While only SC773X) Add: Search for tables nVidia Tegra Add: Completely rewritten Explorer 28.04.17 (ver 1.0.0.44) Fixe: Bugs that have been found through your crash report Fix: Minor changes to EasyFS.dll Add: The project was completely rewritten as a Unicode version Add: Option "Get firmware info" (version, date, etc.) Add: Option "Skip unreadable blocks" Add: Function "Remove WriteProtection" Add: New S.M.A.R.T. information for EMMC revision 5.0 and higher Add: Removing Android Locks ( Gesture PIN Password ) 01.05.2017 (ver 1.0.0.45) Fix: Bugs that have been found through your crash report Add: eMMC chip name identification from cid (Preloader parser) 16.05.17 (ver 1.0.0.46) Fix: Bugs that have been found through your crash report Add: Scanning PIT from eMMC (Explorer) Add: Scanning from MassStorage (E-MATE / KET / QC_9006) 28.05.2017 (ver 1.0.0.47) Fix: Bugs that have been found through your crash report Fix: Searching for partitions when scanning MBR Fix: Searching for MassStorage devices Add: AutoUpdate for the program 08.08.2017 (ver 1.4.8) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) 12.12.2017 (ver 1.4.9) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) 16.04.2018 (ver 1.5.0) Fix: Bugs that have been found through your crash report Add: Showing Connected Pins for a Socket (Emmc check) Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor) Add: SmartReport for Sandisk Add: Vendor Sony Add: Automatic backup of the TrimArea partition for Sony (read by vendor) Add: Grouping of extracted messages by sender (Explorer) Add: Extract Calendar (Explorer) Add: Checking FullDiskEncryption from Boot (Explorer) Add: Scan FullFlash from devices with UFS-memory (Explorer) Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung) Add: Ext4 formatting is completely rewritten (write by vendor) Add: Reading files with emmc errors (Explorer) Add: Skipping for existing files while saving (Explorer) Add: Write protection for ROM 2/3 11.06.2018 (ver 1.5.1) Fix: Bugs that have been found through your crash report Add: Explorer NTFS Support (it will probably be slow on EasyJTAG V1) Add: Extracting contacts from store.vol (currently only from a file on disk) Last edited by layder; 09-16-2018 at 17:36. |
The Following 5 Users Say Thank You to layder For This Useful Post: |
08-03-2018, 12:15 | #2 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Bugs at current version and info about fix it Bugs at current version and info about fix it Easy JTAG Classic 3.0.0.0 - write Firmware errors on eMMC firmware on some boxes (fixed in 3.0.0.3); - error when recovery eMMC firmware KMV3W000LM-B310: did not fit CID (will be fixed in 3.0.0.4 and higher); - bad new eMMC firmware for KMKJS000VM-B309 (ver. 0x7) (fixed in 3.0.0.3, return to ver. 0x3). eMMC Tool Suite 1.5.1 - errors are: "-8, DATA SND CRC Error" and "-3, DATA RCV Timeout Error" (partially fixed in 1.5.2); - Write by Vendor - Samsung: some BL files are not written to ROM2 (fixed in 1.5.2); (before 1.5.2 released, use old 1.5.0) - error when retrieving data from store.vol if the database is corrupted (fixed in 1.5.2); - wrong mount point when formating a partition /userdata (fixed in 1.5.2); - an empty EFS was saved with Read by Vendor - Samsung (fixed in 1.5.2); - when Write by Vendor from Img, the files inserted in the lines did not fit, it was written from Img (fixed in 1.5.2); - Read by Vendor - MTK (GPT) the scat file was not correctly saved, but when Write by Vendor - MTK, the tick for pgpt.bin was not automatically set (fixed in 1.5.2); - hang of the box with the sequence: "Check eMMC Pins" - "eMMC Check" - "Random Verify Test" (fixed in 1.5.2). ... |
08-06-2018, 11:21 | #3 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | 06.08.2018 (ver 1.5.2) Fix: Bugs that have been found through your crash report Fix: Writing ROM2 for Samsung (Write by vendor) Fix: Freezing the program on a RandomVerify Add: Initial Folder for saving from Explorer (in settings) Add: Extract from store.vol from eMMC (explorer) Add: Automatic repair of damaged store.vol when extracting (Explorer) Add: Adding MountPoints for partitions (efs, userdata) when formatting Add: Checking for an empty EFS before backup (Read by Vendor Samsung) p.s. Kaspersky software and Awast is warning for viruses - it's a false alarm ("taggant-system" for it is shutting down) http://vmpsoft.com/20180505/ieee-ams...-31-july-2018/ Last edited by layder; 06-24-2019 at 09:06. |
The Following 4 Users Say Thank You to layder For This Useful Post: |
12-28-2018, 09:05 | #4 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | 28.12.2018 (ver 1.5.3) Fix: Bugs that have been found through your crash report Fix: Scatter file processing (MTK) Fix: Contact Extractor Fix: Preloader parser Fix: FAT partitions mounting Fix: Minor interface changes Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP) Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks) Add: Auto/Manual loaders select for Qualcomm HS-USB QDLoader 9008 interface Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung) Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm) Add: Unpack Bootloader.img archive from Motorola firmware files Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions) Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions) Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC) Add: Explorer: Pin and Password decoding (only English and Russian letters) |
The Following 6 Users Say Thank You to layder For This Useful Post: |
06-24-2019, 09:01 | #5 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | 23.06.2019 (ver 1.6.0) Fix: Bugs that have been found through your crash report Fix: Samsung GPT create (Write by vendor - Samsung) Add: Support UFS Memory Add: Showing eMMC RPMB Counter Status Add: OPPO OFP firmware extractor (Utilites) Add: LG TOT/KDZ firmware extractor (Utilites) Add: "Disable Hi-Speed eMMC timing" option (Settings) Add: Showing information about Xiaomi MiCloud (Explorer) Add: Enter your account for Xiaomi EDL authorization Add: Manually formatting partitions in EXT4 Add: New loaders for Qualcomm QDLoader 9008 port Last edited by layder; 06-24-2019 at 09:08. |
The Following 11 Users Say Thank You to layder For This Useful Post: |
03-21-2021, 10:50 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | EasyJTAG Plus 2.0 beta update from 17/03/21 Unpack this files to EasyJTAG Plus directory after 1.6.4 Plus installed Add: LG KDZ write by vendor Add: Support new kdz format Fix: Latest API for UFS chips. Improve UFS chips connect stability https://drive.google.com/file/d/1AdG...ew?usp=sharing |
The Following 7 Users Say Thank You to layder For This Useful Post: |
05-06-2021, 08:50 | #7 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | EastJtag eMMC Plus 05.05.2021 (ver 1.6.6.0) Relesed 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) http://updates.easy-jtag.com/easyjta...us_1.6.6.0.exe Last edited by layder; 05-08-2021 at 15:41. |
