07-22-2018, 08:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: SLOVENIA, LJUBLJANA Age: 55
Member: 48933 Status: Offline Thanks Meter: 104 | Error: EMMC Password Locked Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = Card Serial = EasyJTAG Box Firmware = 2.29 Changelog: 11.06.2018 (ver 1.5.1.0) Fix: Bugs that have been found through your crash report Add: Explorer NTFS Support (it will probably be slow on EasyJTAG V1) Add: Extracting contacts from store.vol (currently only from a file on disk) Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 90014A48594E4958205C003959A1AEE7 EMMC CSD: D04F01320F5903FFFFFFFFFF8A400001 EMMC Manufacture : SKHYNIX , EMMC NAME: HYNIX , HEX: 48594E495800 , S/N: 003959A1 , rev. 0x5C EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2011 EMMC ROM 1 (Main User Data) Capacity: 15160 MB (0003B3800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC BootArea Write Protection: No EMMC Password Locked: Yes Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HYNIX_003959A1_20180722_090152.extcsd EMMC Init completed. Error: EMMC Password Locked how to unlock this EMMc? wbr, A |
07-23-2018, 16:47 | #3 (permalink) |
Member: 48933 Status: Offline Thanks Meter: 104 | EasyJtag Suite Classic ver.: 3.0.0.0 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM1 ACPI\PNP0501 Communications Port (COM1) COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM3) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Compression if OFF Z3X EasyJtag Software ver. 3.0.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1645mV pin connected ok command: 1651mV pin connected ok data0: 1651mV pin connected ok data1: 1647mV pin connected ok data2: 1651mV pin connected ok data3: 1624mV pin connected ok data4: 1652mV pin connected ok data5: 1651mV pin connected ok data6: 1638mV pin connected ok data7: 1646mV pin connected ok Box S/N: , ,FW Ver.: 02.29 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A48594E4958205C003959A1AEE7 eMMC CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2011 Rev.0x5C eMMC NAME: HYNIX , S/N: 3758497 eMMC NAME (HEX): 48594E495820 EMMC ROM1 (Main User Data) Capacity: 15160 MB , 0x1D9C000 pages , 0x3B3800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00008000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HYNIX _ 3758497_20180723_1743.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0xda] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x0f] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x06] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x09] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x10] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x08] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x02] Sleep current (VCC) [S_C_VCC: 0x08] Sleep current (VCCQ) [S_C_VCCQ: 0x08] Sleep/awake timeout [S_A_TIMEOUT: 0x10] Sector Count [SEC_COUNT: 0x01d9c000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] Card Type [CARD_TYPE: 0x0f] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x00 Write reliability parameter register [WR_REL_PARAM]: 0x00 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x00019a Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Unable to read partition info from a locked card... Done. Checking security ... Running:MMC: Password force remove... Z3X EasyJtag Software ver. 3.0.0.0 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz Force erase SD/MMC password, wait up to 3 min... CARD Ready Timeout Error Force erase SD/MMC password Failed, trying in alternate way Force erase SD/MMC password Operation Failed. |
07-27-2018, 19:22 | #7 (permalink) |
Member: 48933 Status: Offline Thanks Meter: 104 | Checking security ... Running:eMMC: Factory Format Z3X EasyJtag Software ver. 3.0.0.0 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:1000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode FAILED.... eMMC Format Failed. Repairing... eMMC Repair Operation Failed. Done. |
07-27-2018, 20:13 | #8 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Use Format Fix at EasyJTAG calssic | |
The Following 2 Users Say Thank You to layder For This Useful Post: |
07-28-2018, 05:09 | #9 (permalink) |
Member: 48933 Status: Offline Thanks Meter: 104 | Checking security ... Running:eMMC: Factory Format Fix Z3X EasyJtag Software ver. 3.0.0.0 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz Formatting eMMC card, please wait up to 3 min... Final Stage... eMMC Final Operation Failed. Done. |
07-28-2018, 08:25 | #10 (permalink) | |
If not sucsess - you eMMC is dead | |
The Following User Says Thank You to layder For This Useful Post: |
03-31-2021, 04:00 | #14 (permalink) | |
https://forum.gsmhosting.com/vbb/f67...overy-2293345/ | |
