Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-02-2013, 13:03   #16 (permalink)
Member: 775704
Thanks Meter: 13
EMMC TOOL: emmc pinout Pictuer
7,9,11.....19 CONNECT TOGETHER EMMC POWER PINS , But where is the POWER PINS ? how to connect?
Old 08-06-2013, 04:14   #17 (permalink)
Member: 230584
Thanks Meter: 3
The Following 3 Users Say Thank You to reeadh For This Useful Post:
Old 08-06-2013, 06:05   #18 (permalink)
Member: 230584
Thanks Meter: 3
Old 08-08-2013, 09:01   #19 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 120
box mod
For people who don't want to buy the adapter, here is the modification to supply the eMMC from the box:
Remove R3, R6 and re-route the pins 17 and 19 to the internal regulators U7 and U6. This means we will have VCCQ 1.8V on pin 19 and VCC 3.3V on pin 17.
WARNING, remember that you will have ALL THE TIME this two voltage on the connector, so use this 2 pins ONLY and ONLY when dealing with eMMC direct!
The Following 9 Users Say Thank You to oblio For This Useful Post:
Old 08-08-2013, 15:44   #20 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 348
And the box warranty ???
Old 08-08-2013, 18:12   #21 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 120
Will be void, so better go buy that adapter, this mod is for people with some guts who will NOT rely on "warranties" but on researches and improvements...
The Following 3 Users Say Thank You to oblio For This Useful Post:
Old 08-09-2013, 05:21   #22 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 120
Forgot to post the log:
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
Background operations status [BKOPS_STATUS: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d1f000]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02]
I/O Driver Strength [DRIVER_STRENGTH: 0x00]
Card Type [CARD_TYPE: 0x07]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x48]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000ba
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
General Purpose Partition Size
[GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Successefuly connected to box on COM354
Box S/N: 1111FB1B14E97E34, ,FW Ver.: 01.47
Loading eMMC Addon Firmware...
CMD Pullup Level:1598 mV
CMD Active Level:2330 mV
EMMC CID 15010056545530304D00028082937075
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufactorer ID: 15
EMMC OEM ID: 0100
EMMC Date: 07/1997 FW rev.0x0 HW rev.0x0
EMMC Serial #: 41976467
EMMC NAME: VTU00M
EMMC Capacity: 14910 MB (High Density Card)
Extended CSD rev 1.6 (MMC 4.5)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x04]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Writing file...G:\_gsm\Z3X\Easy-jtag\files\samsung\I9300\dump\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_00200000.bin
CMD Active Level:2320 mV
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Writing 00200000 bytes to 00000000 ...ROM2
Write Speed: 158 kB/s
Done !!!
As you can see in the picture, no adapter, no charger/usb cable and no battery, only eMMC direct
The Following 2 Users Say Thank You to oblio For This Useful Post:
Old 08-13-2013, 16:01   #23 (permalink)
Member: 71290
Sonork: 100.1645657
Thanks Meter: 97
Thank you very much for your solution sir, I was very useful
Old 08-16-2013, 01:03   #24 (permalink)
Member: 1763603
Thanks Meter: 2
I modify everything and connects the emmc, get error check conection
Old 08-17-2013, 12:51   #25 (permalink)
Member: 1023134
Sonork: 100.1656920
Thanks Meter: 19
could connect the pcb samsung i9300
Old 08-17-2013, 15:02   #26 (permalink)
Member: 1909321
Thanks Meter: 4
plz, release i9500 , i9505 pinout........ thank
Old 08-17-2013, 16:27   #27 (permalink)
Member: 724757
Sonork: 100.1627486
Thanks Meter: 16
while i try emmc repair for i9300
detect emmc log
CMD Pullup Level:1650 mV
CMD Active Level:2299 mV
EMMC CID 15010056545530304D006A0B6330218F
EMMC OEM ID: 0100
EMMC Date: 02/1998 FW rev.0x0 HW rev.0x0
EMMC Serial #: 1779131184
EMMC NAME: VTU00M
EMMC Capacity: 15028 MB (High Density Card)
Sector Count [SEC_COUNT: 0x01d5a000]
Boot Area Write protection [BOOT_WP]: 0x10
Permanent ReadOnly locking: not possible
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000bb
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Reading dump to file...E:\z3x\EasyJtag\Repair File pinout\I9300\New Folder\EMMC_00000000_00400000.bin
Successefuly connected to box on COM119
Box S/N: 05050F0F3E60A930, ,FW Ver.: 01.47
CMD Pullup Level:1660 mV
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Switching EMMC partition...
Reading 00400000 bytes from 00000000 ...ROM1
main partation write log
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Writing 20000000 bytes to 00000000 ...ROM1
eMMC ACK Error at addr:0x11600
again write error
eMMC ACK Error at addr:0xf0c0
but boot partation rom 2 write is ok
plz help what is rom 1 write error????
The Following User Says Thank You to bijaylama For This Useful Post:
Old 08-18-2013, 09:41   #28 (permalink)
Member: 1664420
Sonork: 100.1637032
i also have same problem plzz help
Old 08-18-2013, 11:22   #29 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 120
Warning again, JPIN-JIC by MOORC has the pin no 17 shorted to ground, so cut it before using this adaptor or else you will destroy the internal regulator U7 !
The Following User Says Thank You to oblio For This Useful Post:
Old 08-22-2013, 04:45   #30 (permalink)
Member: 775704
Thanks Meter: 13
HERE list of EMMC based samsung:
Samsung Galaxy Note II N7100 (16GB),
Samsung GALAXY S4 (I9500/16GB),
Samsung I9300 GALAXY SIII (Unicom Edition),
Samsung I9100 GALAXY SII (16GB),
Samsung I9003 GALAXY SII (16GB),
Samsung I9300 GALAXY SIII (International Edition, 16 Гб),
Samsung Galaxy i9220,
Samsung Galaxy Note N7102 II (32GB / Unico),
Samsung W2013, Samsung S7568 ,
Samsung I9300 GALAXY SIII (International Edition, 32 Гб),
Samsung W999, Samsung Galaxy Note II N7100 32G,
Samsung S7572,
Samsung E120LGalaxy SII HD LTE
Samsung W899,
Samsung I9268, Samsung S7562i (Galaxy S Duos),
Samsung GALAXY Примечание II N719 ,
Samsung I879,
Samsung Galaxy Note II N7102 (16GB / dual),
Samsung Galxy Note III,
Samsung Galaxy i9220 Примечание (белый),
Samsung I939D GALAXY SIII (двойной версии карт),
Samsung GALAXY Примечание II N7108 (мобильная версия),
Samsung I9308 GALAXY SIII (мобильная версия),
Samsung B9388, Samsung I8262D (GALAXY Dous),
Samsung I8190 GALAXY SIII Mini (16GB),
Samsung I9070 Galaxy S (8GB),
Samsung I9100 GALAXY SII ( белый),
Samsung I8190 GALAXY SIII Mini (8 Гб),
Samsung i9100G (GALAXY SII),
Samsung I8552 (Galaxy Win),
Samsung I9108 (GALAXY SII),
Samsung B9120 (усилитель II),
Samsung I8750 (ATIV S/16GB),
Samsung I9105P (GALAXY SII Plus),
Samsung I9305 (GALAXY SIII LTE),
Samsung I939 GALAXY SIII (Telecom версии),
Samsung I9260 GALAXY премьера (16GB),
Samsung I8160 (Galaxy Ace 2),
Samsung GALAXY S4 (I9508 / Mobile)
Samsung N7105 (Galaxy Note II LTE),
Samsung I699 (GALAXY Trend),
Samsung I9260 GALAXY премьера (8GB),
Samsung GALAXY S4 (I959 / Телеком версии),
Samsung I929 (GALAXY SII DUO),
Samsung I9050,
Samsung I9228, Samsung I9103 (Galaxy R),
Samsung I909 (Galaxy S),
Samsung I779,
Samsung I8250,
Samsung I8150 (Galaxy W),
Samsung I919 (GALAXY S DUOS),
Samsung GALAXY S4 (I9505 / Quad / 4G версия),
Samsung I8258,
Samsung I919U (GALAXY S Duos),
Samsung GALAXY S4 (I9500/32GB),
Samsung I8530 (Galaxy Beam),
Samsung B9062,
Samsung S6358 (Galaxy Ace Уважаемые),
Samsung I9018 (Galaxy S),
Samsung I619 (Galaxy Ace Уважаемые),
Samsung I809 (Galaxy S),
Samsung N8000 (Galaxy Note 10.1),
Samsung i9200 (Galaxy Mega 6.3/16GB),
Samsung i9200 (Galaxy Mega 6.3/8GB),
Samsung S7500 (Galaxy Ace Plus),
Samsung I9208 (Galaxy Mega 6.3),
Samsung Galaxy Note 8.0 (N5100/3G + WiFi),
Samsung E210S (GALAXY SIII),
Samsung I535 (GALAXY SIII),
Samsung D710 (Эпическая сенсорный 4G),
Samsung I759,
Samsung I9150 (Galaxy 5.8 Mega ),
Samsung S6352 (Galaxy Ace родного)
Samsung S7508 (Galaxy Ace Plus),
Samsung S5698 (Galaxy Xcover),
Samsung S7530 (OMNIA M),
Samsung GALAXY SIII (TD-LTE версия),
Samsung I659 (Galaxy Ace Plus),
Samsung I717 (Galaxy Note),
Samsung I9300 GALAXY SIII (International Edition, 64 Гб),
Samsung I9020 (Nexus S),
Samsung GALAXY SII i9100G (Tencent версии),
Samsung I9220 Galaxy Note (Extreme Edition),
Samsung S6108 (Galaxy Y POP)
Samsung I9023 (Nexus S),
Samsung I8558 (Galaxy Win),
Samsung Galaxy Tab 7.7 P6800 (16 Гб версия),
Samsung S7530E (OMNIA M),
Samsung B5330 (Galaxy Chat),
Samsung I8730 (Galaxy Express),
Samsung I9205 (Galaxy Mega 6,3),
Samsung I747 (GALAXY SIII),
Samsung I9070 Galaxy S (16GB),
Samsung I339,
Samsung I9100 GALAXY SII (32GB),
Samsung I9100 GALAXY SII (Unicom Edition),
Samsung GALAXY S4 (I9500/64GB),
Samsung I519, Samsung E110S (Celox),
Samsung I667 (Фокус 2),
Samsung I9210 (Galaxy SII LTE),
Samsung S6500D,
Samsung T889 (Galaxy Note II),
Samsung I727 (Galaxy SII усилится),
Samsung I8750 (ATIV S/32GB)
Samsung S5300 (Galaxy карманные),
Samsung i9088 (Galaxy S),
Samsung L710 GALAXY SIII (двухъядерные версии),
Samsung I9080 (GALAXY Гранд),
Samsung T989 (Hercules),
Samsung S6812i,
Samsung B5510 (GALAXY Y Pro),
Samsung I777 (Синга),
Samsung S6500 (Galaxy Mini 2),
Samsung E170K (Galaxy R Style),
Samsung I930 (ATIV Odyssey),
Samsung E220 (GALAXY Pop/8GB),
Samsung S7272 (Galaxy Ace 3),
Samsung S5280 (GALAXY Star)
Samsung I9152 (Galaxy Mega 5,8),
Samsung i677 (Фокус Flash),
Samsung S7710 (Galaxy Xcover 2),
Samsung E220 (GALAXY Pop/16GB),
Samsung S6012 (Galaxy Music Duos),
Samsung S6810 (Galaxy славы),
Samsung R830 (Galaxy Axiom),
Samsung GALAXY SIII +,
Samsung S5301 (Galaxy Pocket Plus),
Samsung S6812 (Galaxy славы),
Samsung I547 (Galaxy Rugby Pro),
Samsung I6282D (Galaxy Core),
Samsung M950 (Galaxy Reverb),
Samsung I437 (Galaxy Express),
Samsung S6312 (GALAXY Молодые Duos),
Samsung T699 (Реле 4G Galaxy S),
Samsung S6310 (GALAXY Young),
Samsung M340S (Galaxy M),
Samsung L300 (Galaxy Победы 4G LTE),
Samsung I847 (регби SMART),
Samsung Galaxy SII WiMAX,
Samsung S759 (Omnia M),
Samsung I577 (Galaxy Exhilarate),
Samsung I405 (Galaxy Metrix 4G),
Samsung E310S (Mega Galaxy 6.3),
Samsung T959 (Очаровывай 4G),
Samsung M190S (Galaxy S Hoppin),
Samsung I7500U Samsung,
Samsung I757 (Galaxy SII Скийрокет HD),
Samsung Nexus S 4G
But in support only have three models:
I9082 ,I9300 and N7100 . where is the other models ?
Page generated in 0.63865 seconds with 8 queries
