Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 05-10-2014, 11:20   #61 (permalink)
mobifone's Avatar
Member: 860880
Thanks Meter: 82
connect usb cable to adapter only no usb cable should be connected to pcb .i hope you have already solder all wire from adapter to pcb now you are ready to go
Old 05-10-2014, 11:55   #62 (permalink)
Member: 2164581
Sonork: 100.1670571
Thanks Meter: 6
Thankx Alot Bro im Soldering Again bCoz there were bundlx Of err0r s0me tym usb Some tym CMD But The Most common error that i sufferd was CMD according to seqrch they said, soldrring is not Good 80 Percent Comentx that i read was about soldering CMD Properly i have removed all wires now gonna sold again i hope thia tym it will w0rk
Thankz alot once again Mobi bro
Sent from my iPhone using Tapatalk
Old 05-22-2014, 04:01   #63 (permalink)
Member: 1201970
Thanks Meter: 34
can i repair i9300 without product name??
Old 05-22-2014, 07:26   #64 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 176,612
in most of cases yes.
The Following User Says Thank You to blang For This Useful Post:
Old 06-02-2014, 03:30   #65 (permalink)
Member: 2077936
Thanks Meter: 21
I am very interested in purchasing a Z3X box. Blang, you're picture shows how to connect to box but not the direct EMMC points on the board. If I purchase the Z3X box and support will I have access to these pinout pictures on your support files? Or are the support files just JTAG connections that don't go directly to the EMMC?
Old 06-08-2014, 14:49   #66 (permalink)
Member: 2194348
Thanks Meter: 41
i have an i9100p stuck on samsung logo , after flash its completly dead , so i connect emmc chipset with my tool then write boot partition 1 and 2 but still no download mode ,
please i need some generale steps to work with emmc tool to get a good diagnostic for my device (hardware or software ...... )
Old 06-22-2014, 09:36   #67 (permalink)
shohidsd1's Avatar
Member: 1706809
Thanks Meter: 54
how to work with Easy-Jtag
[QUOTE=blang;9593804]FAQ - DIRECT EMMC connect in pictures!! DONT ASK MORE!
HERE SAMPLE OF CONNECTION TO PCB.
===============FAQ==============================
Q - If i not have Adapter can i connect to EMMC direct on boart?
A - YES. But need use 2 external power.
Q - Why i need use double voltage?
A - VCC - power of NAND memory inside eMMC (can be 2.8 - 3.3V)
VCCQ - power of internal emmc controller. (can be 1.8 - 2.8V) (need setup vccq in sw same with real voltage)
Q - Do i need connect anything else to phone PCB ?
A - NO. NO NEED CONNECT BATTERY OR USB CABLE TO PCB.
NEED ONLY 6 WIRES: GND, CLK, CMD, DAT0, VCC, VCCQ
Q - Can i repair EMMC CHIP (suddenly dead phones)
A - NO. AT THIS moment you cant repair EMMC. But we work on solution for update internal emmc firmware. May be ... who know.
Q - Can i repair Suddenly dead phones.
A - Yes. If something was erased in EMMC CHIP.
Q - Can i repair boot on phone with disable JTAG?
A - Yes you can. (N7100,I9300 boot inside ROM2, after write ROM2 phones back to work)
Q - Can i repair dead phones I9082, i9105, S6810P with disabled JTAG, after touch ROM2.
A -YES you can. Just need write ROM2 via EMMC direct connection.
Q - Where i can take EMMC DIRECT connection pinout on BOARD?
A - Tested EMMC direct connect pinout we uploading to EMMC pinout under phone folder name on support.
Q - How can i find byself EMMC pinout.
A - Yes you can most of emmc have same pinouts. Need desolder EMMC and find where go 5 pins. CMD,CLK, DAT0, VCC,VCCQ
Q - What phones supported by EMMC Tool.
A - Supported any phones for READ/WRITE based on known EMMC. At this moment we support most of known EMMC.
HERE list of EMMC based samsung:
sir I am sorry to ask you again on how to connect and how to work with easy jtag .I'm very eager to work with it but i have no knowledge about it on how to connect and work so it is very typical and complicated for me and many more ,even reading FAQ and following picture tutorial given by you so we need a video tutorial on different kind of mobile phones.
thanks sir
and sorry again for my newbie question,
The Following User Says Thank You to shohidsd1 For This Useful Post:
Old 06-26-2014, 17:11   #68 (permalink)
Member: 1898385
Is suppoted Repair Boot Samsung note 2 N7100?
Old 08-27-2014, 06:28   #69 (permalink)
Member: 2193576
Thanks Meter: 19
Please i whant full dump emmc file sm-g7102 4.4.2
Please post a link download full dump emmc file sm-g7102 4.4.2
Old 09-02-2014, 12:10   #70 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 313
I modify My Box And it's Working well
No Need Any Adapter
The Following 2 Users Say Thank You to naushad09 For This Useful Post:
Old 09-03-2014, 15:53   #71 (permalink)
Member: 2250829
Thanks Meter: 2
i have adaptar. i sold 6 ware.. connect usb but emmc card not detecting. Z3X EasyJtag Software ver. 1.5.6.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 0D00201ADBA517B7, ,FW Ver.: 01.50
CMD Pullup Level:1175 mV
CMD Active Level:2402 mV
Can't init EMMC, Reason: CMD Timeout Error
Done. help sir.........
Old 10-02-2014, 14:57   #72 (permalink)
Member: 1191351
Sonork: 22
Z3X EasyJtag Software ver. 1.6.1.1
Box S/N: 0EFFF02156D6D079, ,FW Ver.: 01.50
CMD Active Level:1536 mV
Can't init EMMC, Reason: DATA Status Error
Done. plez help meeeeeeeeeeee
Old 10-21-2014, 13:45   #73 (permalink)
Member: 1387849
Sonork: 100.1623264
Thanks Meter: 14
hello guys i have a problem with galaxy grand i9082 phone is dead motherboard shorting
any one help how to solve im waiting for solution
Thank you
Old 11-30-2014, 19:09   #74 (permalink)
Member: 988127
please helpme sir
Z3X EasyJtag Software ver. 1.6.6.0
Box S/N: 17FFE0166CEC3928, ,FW Ver.: 01.50
CMD Pullup Level:2062 mV
CMD Active Level:2103 mV
Done.
Old 01-02-2015, 12:58   #75 (permalink)
Member: 2175541
Thanks Meter: 16
Originally Posted by bosox View Post
please helpme sir
Done.
Maybe the EMMC is dead... Replace it
Page generated in 0.42322 seconds with 8 queries
