09-16-2017, 16:12 | #1 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Final Solution For OPPO R2001 After Flash Only Vibrate Problem... 100% Tested By Me ! Finally I Solved OPPO R2001 After Flash Only Vibrate Problem... Solution : Try with "Easy Jtag Box" Process : (I) Universal Factory Format, (II) Write Full EXT_CSD File From Backup, (III) Sellect Scatter File & Write Firmware in Write By Vendor Tab. After Writing Complite Your Device 100% Power ON, Bcoz That is Tested By Me. |
The Following 4 Users Say Thank You to Pijush Das For This Useful Post: |
09-17-2017, 09:00 | #3 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | yes this problem solved years ago ... format old emmc for temporary or ... change emmc for permanent fixed |
The Following User Says Thank You to bagus.dps For This Useful Post: |
