Member: 1834832
Thanks Meter: 1,450 | "Firmware Info Not Found" & "Chip Not Detect Issue" Hi I Am Facing Some Strange Issue With Easy JTAG Hope Team Will Fix It Soon
1# Classic Module Now Also Crash After Detect Chip
2# Some Chip Show Dead On Detection Even All Pins Show Connected I Know Chip Having Some Issue As Product Name Showing Something Else But Its Detect In Other XYZ Tool Show Partition Table Too ...
3# I Write Dump On Redmi 6 Show All Info Ok Then I Flash It Using Write By Vendor Already Untick Erase N Reparation Option After Flash Show "Firmware Not Found" On Detect...
Here Is Log For Write Dump N Info Quote:
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.329)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 448AA8EBF9317344
Card Serial = AA6DE225
EasyJTAG Box Firmware = 2.50
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/E-Socket
Setting bus width to 4 Bit
Setting frequence to 42 MHz
EMMC Device Information :
EMMC CID: 150100474436424D4206B3E1AAB07117
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: GD6BMB , HEX: 474436424D42 , S/N: B3E1AAB0 , rev. 0x06
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: GD6BMB_B3E1AAB0_20200229_193038.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB)
Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB)
Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB)
Partition: expdb, [000004188000 - 000005588000], size: 000001400000 (20.0 MB)
Partition: frp, [000005588000 - 000005688000], size: 000000100000 (1.00 MB)
Partition: nvcfg, [000005688000 - 000007688000], size: 000002000000 (32.0 MB)
Partition: nvdata, [000007688000 - 00000B688000], size: 000004000000 (64.0 MB)
Partition: metadata, [00000B688000 - 00000D688000], size: 000002000000 (32.0 MB)
Partition: protect1, [00000D688000 - 00000DE88000], size: 000000800000 (8.00 MB)
Partition: protect2, [00000DE88000 - 00000E800000], size: 000000978000 (9.47 MB)
Partition: seccfg, [00000E800000 - 00000F000000], size: 000000800000 (8.00 MB)
Partition: persist, [00000F000000 - 000013000000], size: 000004000000 (64.0 MB)
Partition: sec1, [000013000000 - 000013200000], size: 000000200000 (2.00 MB)
Partition: proinfo, [000013200000 - 000013500000], size: 000000300000 (3.00 MB)
Partition: efuse, [000013500000 - 000013580000], size: 000000080000 (512. KB)
Partition: md1img, [000013580000 - 000019980000], size: 000006400000 (100. MB)
Partition: spmfw, [000019980000 - 000019A80000], size: 000000100000 (1.00 MB)
Partition: scp1, [000019A80000 - 000019B80000], size: 000000100000 (1.00 MB)
Partition: scp2, [000019B80000 - 000019C80000], size: 000000100000 (1.00 MB)
Partition: sspm_1, [000019C80000 - 000019D80000], size: 000000100000 (1.00 MB)
Partition: sspm_2, [000019D80000 - 000019E80000], size: 000000100000 (1.00 MB)
Partition: gz1, [000019E80000 - 00001AE80000], size: 000001000000 (16.0 MB)
Partition: gz2, [00001AE80000 - 00001BE80000], size: 000001000000 (16.0 MB)
Partition: nvram, [00001BE80000 - 00001FE80000], size: 000004000000 (64.0 MB)
Partition: vbmeta, [00001FE80000 - 000020680000], size: 000000800000 (8.00 MB)
Partition: lk, [000020680000 - 000020780000], size: 000000100000 (1.00 MB)
Partition: lk2, [000020780000 - 000020880000], size: 000000100000 (1.00 MB)
Partition: boot, [000020880000 - 000024880000], size: 000004000000 (64.0 MB)
Partition: logo, [000024880000 - 000028880000], size: 000004000000 (64.0 MB)
Partition: odmdtbo, [000028880000 - 000029880000], size: 000001000000 (16.0 MB)
Partition: cust, [000029880000 - 000049880000], size: 000020000000 (512. MB)
Partition: tee1, [000049880000 - 000049D80000], size: 000000500000 (5.00 MB)
Partition: tee2, [000049D80000 - 00004A280000], size: 000000500000 (5.00 MB)
Partition: pad, [00004A280000 - 00004A800000], size: 000000580000 (5.50 MB)
Partition: vendor, [00004A800000 - 00007A800000], size: 000030000000 (768. MB)
Partition: system, [00007A800000 - 00011A800000], size: 0000A0000000 (2.50 GB)
Partition: devinfo, [00011A800000 - 00011B000000], size: 000000800000 (8.00 MB)
Partition: cache, [00011B000000 - 00012B000000], size: 000010000000 (256. MB)
Partition: userdata, [00012B000000 - 000E8BCFBE00], size: 000D60CFBE00 (53.5 GB)
Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB)
Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB)
GPT header successfully parsed
Get firmware version
Brand = xiaomi
Manufacturer = Xiaomi
Device = cereus
Model = Redmi 6
CPU Abi = armeabi-v7a
Android release = 8.1.0
Firmware version = O11019
Miui Version = V10.2.2.0.OCGMIXM
Firmware date = Thu Dec 27 23:17:20 WIB 2018
Backup saved: GD6BMB_B3E1AAB0_20200229_193049.extcsd
Opening file: MT6765_Android_scatter.txt
The new format of scatter
config_version: V1.1.2
platform: MT6765
preloader_cereus.bin
Found 8 supported eMMC CID:
name = 'GD6BMB' hex = 0x474436424D42 [SAMSUNG]
name = 'S0J9B7' hex = 0x53304A394237 [MICRON]
name = 'hB8aP>' hex = 0x68423861503E [SKHYNIX]
name = 'QE63MB' hex = 0x514536334D42 [SAMSUNG]
name = 'HAG4a2' hex = 0x484147346132 [SKHYNIX]
H9TQ17ABJTACUR/16GB @BGA221
name = 'RH64AB' hex = 0x524836344142 [SAMSUNG]
name = 'HCG8a4' hex = 0x484347386134 [SKHYNIX]
name = 'GP6BMB' hex = 0x475036424D42 [SAMSUNG]
The size of the last section has been updated
Backup saved: GD6BMB_B3E1AAB0_20200229_193057.extcsd
Operation: Write by vendor (MediaTek)
Partition name: preloader
Filename: preloader_cereus.bin , Offset: 000000000000 , filesize: 236720 bytes
eMMC switching to ROM3
Writing partition...
Done writing partition. Write speed: 383.16 KB/s
eMMC switching to ROM2
Done writing partition. Write speed: 1040.70 KB/s
Partition name: recovery
Filename: recovery.img , Offset: 000000108000 , filesize: 67108864 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 13621.40 KB/s
Partition name: md1img
Filename: md1img.img , Offset: 000013580000 , filesize: 56768704 bytes
Done writing partition. Write speed: 17495.28 KB/s
Partition name: spmfw
Filename: spmfw.img , Offset: 000019980000 , filesize: 52080 bytes
Done writing partition. Write speed: 2412.57 KB/s
Partition name: scp1
Filename: scp.img , Offset: 000019A80000 , filesize: 564304 bytes
Done writing partition. Write speed: 11263.82 KB/s
Partition name: scp2
Filename: scp.img , Offset: 000019B80000 , filesize: 564304 bytes
Done writing partition. Write speed: 11807.19 KB/s
Partition name: sspm_1
Filename: sspm.img , Offset: 000019C80000 , filesize: 432784 bytes
Done writing partition. Write speed: 5219.97 KB/s
Partition name: sspm_2
Filename: sspm.img , Offset: 000019D80000 , filesize: 432784 bytes
Done writing partition. Write speed: 15286.98 KB/s
Partition name: vbmeta
Filename: vbmeta.img , Offset: 00001FE80000 , filesize: 4096 bytes
Done writing partition. Write speed: 784.50 KB/s
Partition name: lk
Filename: lk.img , Offset: 000020680000 , filesize: 698000 bytes
Done writing partition. Write speed: 8113.53 KB/s
Partition name: lk2
Filename: lk.img , Offset: 000020780000 , filesize: 698000 bytes
Done writing partition. Write speed: 12864.81 KB/s
Partition name: boot
Filename: boot.img , Offset: 000020880000 , filesize: 67108864 bytes
Done writing partition. Write speed: 17459.22 KB/s
Partition name: logo
Filename: logo.bin , Offset: 000024880000 , filesize: 1175344 bytes
Done writing partition. Write speed: 10290.20 KB/s
Partition name: odmdtbo
Filename: odmdtbo.img , Offset: 000028880000 , filesize: 16777216 bytes
Done writing partition. Write speed: 17602.29 KB/s
Partition name: cust
Filename: cust.img , Offset: 000029880000 , filesize: 89043140 bytes
Sparse image found v.1.0 Total chunks: 14
Done writing partition. Write speed: 17430.07 KB/s
Partition name: tee1
Filename: tee.img , Offset: 000049880000 , filesize: 3394272 bytes
Done writing partition. Write speed: 15387.51 KB/s
Partition name: tee2
Filename: tee.img , Offset: 000049D80000 , filesize: 3394272 bytes
Done writing partition. Write speed: 14556.93 KB/s
Partition name: vendor
Filename: vendor.img , Offset: 00004A800000 , filesize: 395776280 bytes
Sparse image found v.1.0 Total chunks: 21
Done writing partition. Write speed: 17332.95 KB/s
Partition name: system
Filename: system.img , Offset: 00007A800000 , filesize: 2546213576 bytes
Sparse image found v.1.0 Total chunks: 57
Done writing partition. Write speed: 17838.05 KB/s
Partition name: cache
Filename: cache.img , Offset: 00011B000000 , filesize: 131220 bytes
Sparse image found v.1.0 Total chunks: 10
Done writing partition. Write speed: 2829.20 KB/s
Partition name: userdata
Filename: userdata.img , Offset: 00012B000000 , filesize: 22995212 bytes
Sparse image found v.1.0 Total chunks: 20
Done writing partition. Write speed: 16100.55 KB/s
Writing DL_Info...
Writing DL_Info done
Writing eMMC Register ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
All done time: [00:03:08:098]
Boot Bus Config: 0x00 , width 1bit
Backup saved: GD6BMB_B3E1AAB0_20200229_193412.extcsd
Firmware info not found
| Chip Detection Issue erial number: 0011-8081-2841
Boot version: 1.03, FW version: 1.10 (Mar 26 2017 14:24:34)
Insertion test... Done.
Init bus...
VCC: 3.3 V, VCCQ: 1.8 V
Bus: 1 bit (SDR 4MHz)
Access mode: sector mode
Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V)
Card/BGA: BGA (Discrete embedded) - High density MMC
Manufacturer ID: 0x90 (SK Hynix)
Product name: %E3009D%hB8aP (0x68423861503e), rev: 0x01, serial number: 0x4D40DA03
Manufacturing date: Nov 2018
CID: 90014A68 42386150 3E014D40 DA03B528
CSD: D0270032 8F5903FF FFFFFFEF 8E400042
EXT_CSD revision: 1.8 (MMC v5.1)
Cannot create file "C:\UFI\backups\hB8aP>_4D40DA03.ext_csd". The filename, directory name, or volume label syntax is incorrect
Partition info:
Boot1: 4096 KiB
Boot2: 4096 KiB
RPMB: 16384 KiB
User area: 29.12 GiB(31,268,536,320 bytes)
Cache size: 2 MiB
Hardware reset function: 1
Partition configuration: 0x48
Boot acknowledge is sent during the boot operation
Boot partition 1 is enabled for boot
Partitioning support: 0x07
Device support partitioning feature
Device partitioning possible
Boot configuration protection: 0x00
Boot bus conditions: 0x02
Bus width: x8 (sdr/ddr), boot mode: sdr(default), reset bus width to x1 sdr(default)
Boot area write protection: 0x00
Power-on write protection: possible
Permanent write protection: possible
Lock status: not locked
ANDROID ROM info:
platform: MT6765, cpu abi:
board: , name:
brand: , model:
build id: , version: ()
Easy JTAG Show All Pins Connection OCR Or Chip DEAD ..I Need TO Backup Security Sector From Chip |
