09-11-2019, 15:04 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 39
Member: 681346 Status: Offline Thanks Meter: 14 | SM-G316HU jtag repair done but no power Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 1787 mV CMD Active Level: 1853 mV EMMC Device Information : EMMC CID: 90014A483447326211017F042A4642EB EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 7F042A46 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_7F042A46_20190911_193137.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB) Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) Partition: WFIXNV1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB) Partition: WFIXNV2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB) Partition: TDFIXNV1, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB) Partition: TDFIXNV2, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB) Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB) Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 (8.00 MB) Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 (8.00 MB) Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 (4.00 MB) Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 (1.00 MB) Partition: WRUNTIMENV1, [000002500000 - 000002600000], size: 000000100000 (1.00 MB) Partition: WRUNTIMENV2, [000002600000 - 000002700000], size: 000000100000 (1.00 MB) Partition: TDRUNTIMENV1, [000002700000 - 000002800000], size: 000000100000 (1.00 MB) Partition: TDRUNTIMENV2, [000002800000 - 000002900000], size: 000000100000 (1.00 MB) Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 (2.00 MB) Partition: EFS, [000002B00000 - 000003F00000], size: 000001400000 (20.0 MB) Partition: PRODNV, [000003F00000 - 000004400000], size: 000000500000 (5.00 MB) Partition: RESERVED2, [000004400000 - 000004500000], size: 000000100000 (1.00 MB) Partition: KERNEL, [000004500000 - 000005500000], size: 000001000000 (16.0 MB) Partition: RECOVERY, [000005500000 - 000006500000], size: 000001000000 (16.0 MB) Partition: CSC, [000006500000 - 000012D00000], size: 00000C800000 (200. MB) Partition: SYSTEM, [000012D00000 - 00005DD00000], size: 00004B000000 (1.17 GB) Partition: HIDDEN, [00005DD00000 - 000065D00000], size: 000008000000 (128. MB) Partition: USERDATA, [000065D00000 - 0000E8FFBE00], size: 0000832FBE00 (2.05 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = vivalto5mve3g Model = SM-G316HU Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 4.4.4 Firmware version = KTU84P.G316HUDXS0AQA2 Firmware date = Sat Jan 7 13:34:20 KST 2017 |
09-11-2019, 15:13 | #2 (permalink) |
Member: 681346 Status: Offline Thanks Meter: 14 | Found 1 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM3) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.3 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 5E4CF6B5CA89F940, ,FW Ver.: 02.44 CMD Pullup Level:1726 mV CMD Active Level:1853 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A483447326211017F042A4642EB eMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DB eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 04/2015 Rev.0x1 eMMC NAME: H4G2b , S/N: 2130979398 eMMC NAME (HEX): 483447326220 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: H4G2b_2130979398_20190911_1940.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7634910 Partition info successfully found Found Data areas (firmware parts) count is: 25 --------------------------------------------- P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB P2 (WFIXNV1) [0x800000 0x100000] Size: 1.0MB P3 (WFIXNV2) [0x900000 0x100000] Size: 1.0MB P4 (TDFIXNV1) [0xa00000 0x100000] Size: 1.0MB P5 (TDFIXNV2) [0xb00000 0x100000] Size: 1.0MB P6 (WDSP) [0xc00000 0x400000] Size: 4.0MB P7 (MODEM) [0x1000000 0x800000] Size: 8.0MB P8 (MODEM2) [0x1800000 0x800000] Size: 8.0MB P9 (TDDSP) [0x2000000 0x400000] Size: 4.0MB P10 (FOTA_SIG) [0x2400000 0x100000] Size: 1.0MB P11 (WRUNTIMENV1) [0x2500000 0x100000] Size: 1.0MB P12 (WRUNTIMENV2) [0x2600000 0x100000] Size: 1.0MB P13 (TDRUNTIMENV1) [0x2700000 0x100000] Size: 1.0MB P14 (TDRUNTIMENV2) [0x2800000 0x100000] Size: 1.0MB P15 (PARAM) [0x2900000 0x200000] Size: 2.0MB P16 (EFS) [0x2b00000 0x1400000] Size: 20.0MB P17 (PRODNV) [0x3f00000 0x500000] Size: 5.0MB P18 (RESERVED2) [0x4400000 0x100000] Size: 1.0MB P19 (KERNEL) [0x4500000 0x1000000] Size: 16.0MB P20 (RECOVERY) [0x5500000 0x1000000] Size: 16.0MB P21 (CSC) [0x6500000 0xc800000] Size: 200.0MB P22 (SYSTEM) [0x12d00000 0x4b000000] Size: 1.171GB P23 (HIDDEN) [0x5dd00000 0x8000000] Size: 128.0MB P24 (USERDATA) [0x65d00000 0x832fbe00] Size: 2.48GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0012D00000 (1.171GB) Build ID: KTU84P Display Build ID: KTU84P.G316HUDXS0AQA2 Release Incremental ID: G316HUDXS0AQA2 Release Base ID: 4.4.4 Device Model: SM-G316HU Device Name: vivalto5mve3gdx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: sc8830 Product ID: vivalto5mve3g Build Description: vivalto5mve3gdx-user 4.4.4 KTU84P G316HUDXS0AQA2 release-keys Samsung CPU: SC7727S --------------------------------------------- Detected USERDATA USERDATA : 0x0065D00000 (2.48GB) Unable to read gesture.key , code 2 Done. Selected eMMC Interface |
