Old 08-27-2019, 07:24   #1 (permalink)
Member: 310155
Thanks Meter: 1,313
G530H dead, only show HS usb qualcom mode
how can fixed this ??
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 10 (64 bit) build 17134 (10.0.17134.858)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = DE661578BC5CC95E
Card Serial = AA820FD9
EasyJTAG Box Firmware = 2.44
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 24 MHz
CMD Pullup Level: 2121 mV
CMD Active Level: 2657 mV
EMMC Device Information :
EMMC CID: FE014E50314A39354B1305E4DB1732C9
EMMC CSD: D06E01320F5913FFFFFFFFEF92400071
EMMC Manufacture : MICRON , EMMC NAME: P1J95K , HEX: 50314A39354B , S/N: 05E4DB17 , rev. 0x13
EMMC Manufacture ID: 0xFE , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 3/2015
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Counter: 25 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: P1J95K_05E4DB17_20190827_121926.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB)
Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB)
Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB)
Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB)
Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB)
Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB)
Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB)
Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB)
Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB)
Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB)
Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB)
Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB)
Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB)
Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB)
Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB)
Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB)
Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB)
Partition: fota, [000009800000 - 000009D00400], size: 000000500400 (5.00 MB)
Partition: backup, [000009D00400 - 00000A3FE000], size: 0000006FDC00 (6.99 MB)
Partition: fsc, [00000A3FE000 - 00000A6FE000], size: 000000300000 (3.00 MB)
Partition: ssd, [00000A6FE000 - 00000A700000], size: 000000002000 (8.00 KB)
Partition: persist, [00000A700000 - 00000AF00000], size: 000000800000 (8.00 MB)
Partition: persdata, [00000AF00000 - 00000B800000], size: 000000900000 (9.00 MB)
Partition: system, [00000B800000 - 000069000000], size: 00005D800000 (1.46 GB)
Partition: cache, [000069000000 - 00007BC00000], size: 000012C00000 (300. MB)
Partition: hidden, [00007BC00000 - 00007F800000], size: 000003C00000 (60.0 MB)
Partition: userdata, [00007F800000 - 0001D1FFBE00], size: 0001527FBE00 (5.29 GB)
GPT header successfully parsed
Get firmware version
Brand = samsung
Manufacturer = samsung
Device = fortuna3g
Model = SM-G530H
Phone platform = msm8916
CPU Abi = armeabi-v7a
Android release = 5.0.2
Firmware version = LRX22G.G530HXXS2BSA2
Firmware date = Fri Jan 18 08:26:26 KST 2019
Old 08-27-2019, 09:31   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
if you try software repair (wrile BL) and nothing has changed, you need try to reball CPU
it may be not software problem
Old 08-27-2019, 10:20   #3 (permalink)
Member: 310155
Thanks Meter: 1,313
it was hang on logo.
i was reset emmc and full flash with bl.
now phone fully dead.
how fixed this ??
Old 08-27-2019, 12:41   #4 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
how fixed this ??
emmc problem dont waste time
Old 09-14-2019, 15:58   #5 (permalink)
Member: 1155715
Sonork: ahmad.derakhshan61
Thanks Meter: 23
it solve only sam emmc
Page generated in 0.15265 seconds with 9 queries
