G316hu boot repair Hello can any friends or supporter help me to repair boot of g316hu i have downloaded file from z3x support there is 4 file boot1.bin, boot2.bin, userarea.bin, ext csd.bin now how can i write this file or how can boot repair pine out is ok connection is ok with box now what to do help plz senior member |
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM9 Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA1A-28FD , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 CMD Pullup Level:1691 mV CMD Active Level:1742 mV Box IO Level:1800 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A483447326211010055004E320C EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 5570638 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB , 0x748000 pages , 0xE9000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _ 5570638_20171013_1409.extcsd ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x10 Power ReadOnly locking: possible Permanent ReadOnly locking: not possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7618526 Found Data areas (firmware parts) count is: 25 Partition info successfully found --------------------------------------------- P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB P2 (WFIXNV1) [0x800000 0x100000] Size: 1.0MB P3 (WFIXNV2) [0x900000 0x100000] Size: 1.0MB P4 (TDFIXNV1) [0xa00000 0x100000] Size: 1.0MB P5 (TDFIXNV2) [0xb00000 0x100000] Size: 1.0MB P6 (WDSP) [0xc00000 0x400000] Size: 4.0MB P7 (MODEM) [0x1000000 0x800000] Size: 8.0MB P8 (MODEM2) [0x1800000 0x800000] Size: 8.0MB P9 (TDDSP) [0x2000000 0x400000] Size: 4.0MB P10 (FOTA_SIG) [0x2400000 0x100000] Size: 1.0MB P11 (WRUNTIMENV1) [0x2500000 0x100000] Size: 1.0MB P12 (WRUNTIMENV2) [0x2600000 0x100000] Size: 1.0MB P13 (TDRUNTIMENV1) [0x2700000 0x100000] Size: 1.0MB P14 (TDRUNTIMENV2) [0x2800000 0x100000] Size: 1.0MB P15 (PARAM) [0x2900000 0x200000] Size: 2.0MB P16 (EFS) [0x2b00000 0x1400000] Size: 20.0MB P17 (PRODNV) [0x3f00000 0x500000] Size: 5.0MB P18 (RESERVED2) [0x4400000 0x100000] Size: 1.0MB P19 (KERNEL) [0x4500000 0x1000000] Size: 16.0MB P20 (RECOVERY) [0x5500000 0x1000000] Size: 16.0MB P21 (CSC) [0x6500000 0xc800000] Size: 200.0MB P22 (SYSTEM) [0x12d00000 0x4b000000] Size: 1.171GB P23 (HIDDEN) [0x5dd00000 0x8000000] Size: 128.0MB P24 (USERDATA) [0x65d00000 0x82400000] Size: 2.35GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0012D00000 (1.171GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Done. |
PROBLEM SOLVED AT Z3X JTAQ Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 CMD Pullup Level:1701 mV CMD Active Level:1732 mV Box IO Level:1800 mV CLK Rate:21000 khz HiPower mode is ON! Compression is ON ---------- eMMC Device Information ---------- EMMC CID : 90014A483447326211010055004E320C EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 5570638 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: H4G2b _ 5570638_20171013_1727.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7618526 Found Data areas (firmware parts) count is: 25 Partition info successfully found --------------------------------------------- P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB P2 (WFIXNV1) [0x800000 0x100000] Size: 1.0MB P3 (WFIXNV2) [0x900000 0x100000] Size: 1.0MB P4 (TDFIXNV1) [0xa00000 0x100000] Size: 1.0MB P5 (TDFIXNV2) [0xb00000 0x100000] Size: 1.0MB P6 (WDSP) [0xc00000 0x400000] Size: 4.0MB P7 (MODEM) [0x1000000 0x800000] Size: 8.0MB P8 (MODEM2) [0x1800000 0x800000] Size: 8.0MB P9 (TDDSP) [0x2000000 0x400000] Size: 4.0MB P10 (FOTA_SIG) [0x2400000 0x100000] Size: 1.0MB P11 (WRUNTIMENV1) [0x2500000 0x100000] Size: 1.0MB P12 (WRUNTIMENV2) [0x2600000 0x100000] Size: 1.0MB P13 (TDRUNTIMENV1) [0x2700000 0x100000] Size: 1.0MB P14 (TDRUNTIMENV2) [0x2800000 0x100000] Size: 1.0MB P15 (PARAM) [0x2900000 0x200000] Size: 2.0MB P16 (EFS) [0x2b00000 0x1400000] Size: 20.0MB P17 (PRODNV) [0x3f00000 0x500000] Size: 5.0MB P18 (RESERVED2) [0x4400000 0x100000] Size: 1.0MB P19 (KERNEL) [0x4500000 0x1000000] Size: 16.0MB P20 (RECOVERY) [0x5500000 0x1000000] Size: 16.0MB P21 (CSC) [0x6500000 0xc800000] Size: 200.0MB P22 (SYSTEM) [0x12d00000 0x4b000000] Size: 1.171GB P23 (HIDDEN) [0x5dd00000 0x8000000] Size: 128.0MB P24 (USERDATA) [0x65d00000 0x82400000] Size: 2.35GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0012D00000 (1.171GB) Build ID: KTU84P Display Build ID: KTU84P.G316HUDXU0AOA4 Release ID: 4.4.4 Device Model: SM-G316HU Device Name: vivalto5mve3gdx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: sc8830 Product ID: vivalto5mve3g Build Description: vivalto5mve3gdx-user 4.4.4 KTU84P G316HUDXU0AOA4 release-keys Samsung CPU: SC7727S --------------------------------------------- Done. |
Repairing process Hi Umar Can you please give the steps of repairing process ? |
Config set from ****l : Vendor:LG Model:P705 Compression is ON Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 01FFA00C3950E5E7, ,FW Ver.: 01.62 CMD Pullup Level:2072 mV CMD Active Level:2629 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A483447326211019D76556CC168 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 12/2014 Rev.0x1 EMMC NAME: H4G2b , S/N: 2641778028 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _2641778028_20180331_2218.extcsd Done. |
Umar can fix it He will fix it , if umar bro will be busy I can Try to doit |
please give the steps of repairing |
Z3X EasyJtag Software ver. 3.6.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 01FFA00C3950E5E7, ,FW Ver.: 01.63 CMD Pullup Level:1804 mV CMD Active Level:2794 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A483447326211011F0A02193246 eMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 03/2015 Rev.0x1 eMMC NAME: H4G2b , S/N: 520749593 eMMC NAME (HEX): 483447326220 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b_ 520749593_20190703_1336.extcsd Done. |
