Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-11-2017, 14:33   #1 (permalink)
Member: 397103
Thanks Meter: 14
G316hu boot repair
Hello can any friends or supporter help me to repair boot of g316hu i have downloaded file from z3x support there is 4 file boot1.bin, boot2.bin, userarea.bin, ext csd.bin now how can i write this file or how can boot repair pine out is ok connection is ok with box now what to do help plz senior member
Old 10-13-2017, 09:40   #2 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 588
EasyJtag Suite Classic ver.: 2.6.0.1 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL
undefined
Android Explorer ver.: 1.0.0.23
eMMC ODIN ver.: 1.0.11.2
Successfully connected to box on COM9
Box S/N: 010070222EE63D88, ,FW Ver.: 01.60
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA1A-28FD , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Compression is ON
Z3X EasyJtag Software ver. 2.6.0.1
Loading eMMC GEN1 Firmware... IO: 1800 mV
CMD Pullup Level:1691 mV
CMD Active Level:1742 mV
Box IO Level:1800 mV
CLK Rate:21000 khz
HiPower mode is ON!
---------- eMMC Device Information ----------
EMMC CID : 90014A483447326211010055004E320C
EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 03/2015 Rev.0x1
EMMC NAME: H4G2b , S/N: 5570638
EMMC NAME (HEX): 48344732622000
EMMC ROM1 (Main User Data) Capacity: 3728 MB , 0x748000 pages , 0xE9000000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2b _ 5570638_20171013_1409.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x08]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x00]
Tag Resources Size [TAG_RES_SIZE: 0x06]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0]
Power off notification [POWER_OFF_LONG_TIME: 0x50]
Cache Size [CACHE_SIZE] is 512 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x13]
Sector Count [SEC_COUNT: 0x00748000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x08]
[MIN_PERF_R_8_52: 0x08]
[MIN_PERF_W_8_26_4_52: 0x08]
[MIN_PERF_R_8_26_4_52: 0x08]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x08]
[MIN_PERF_R_4_26: 0x08]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x01]
Card Type [CARD_TYPE: 0x17]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x08]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x10
Power ReadOnly locking: possible
Permanent ReadOnly locking: not possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x10
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB
Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
First usable sector: 34
Last usable sector: 7618526
Found Data areas (firmware parts) count is: 25
Partition info successfully found
P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB
P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB
P2 (WFIXNV1) [0x800000 0x100000] Size: 1.0MB
P3 (WFIXNV2) [0x900000 0x100000] Size: 1.0MB
P4 (TDFIXNV1) [0xa00000 0x100000] Size: 1.0MB
P5 (TDFIXNV2) [0xb00000 0x100000] Size: 1.0MB
P6 (WDSP) [0xc00000 0x400000] Size: 4.0MB
P7 (MODEM) [0x1000000 0x800000] Size: 8.0MB
P8 (MODEM2) [0x1800000 0x800000] Size: 8.0MB
P9 (TDDSP) [0x2000000 0x400000] Size: 4.0MB
P10 (FOTA_SIG) [0x2400000 0x100000] Size: 1.0MB
P11 (WRUNTIMENV1) [0x2500000 0x100000] Size: 1.0MB
P12 (WRUNTIMENV2) [0x2600000 0x100000] Size: 1.0MB
P13 (TDRUNTIMENV1) [0x2700000 0x100000] Size: 1.0MB
P14 (TDRUNTIMENV2) [0x2800000 0x100000] Size: 1.0MB
P15 (PARAM) [0x2900000 0x200000] Size: 2.0MB
P16 (EFS) [0x2b00000 0x1400000] Size: 20.0MB
P17 (PRODNV) [0x3f00000 0x500000] Size: 5.0MB
P18 (RESERVED2) [0x4400000 0x100000] Size: 1.0MB
P19 (KERNEL) [0x4500000 0x1000000] Size: 16.0MB
P20 (RECOVERY) [0x5500000 0x1000000] Size: 16.0MB
P21 (CSC) [0x6500000 0xc800000] Size: 200.0MB
P22 (SYSTEM) [0x12d00000 0x4b000000] Size: 1.171GB
P23 (HIDDEN) [0x5dd00000 0x8000000] Size: 128.0MB
P24 (USERDATA) [0x65d00000 0x82400000] Size: 2.35GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0012D00000 (1.171GB)
Unable to mount SYSTEM , code : 95
Done.
The Following User Says Thank You to umarmsn For This Useful Post:
Old 10-13-2017, 13:05   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 588
PROBLEM SOLVED AT Z3X JTAQ
CMD Pullup Level:1701 mV
CMD Active Level:1732 mV
CLK Rate:21000 khz
HiPower mode is ON!
Compression is ON
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b _ 5570638_20171013_1727.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Build ID: KTU84P
Display Build ID: KTU84P.G316HUDXU0AOA4
Release ID: 4.4.4
Device Model: SM-G316HU
Device Name: vivalto5mve3gdx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: sc8830
Product ID: vivalto5mve3g
Build Description: vivalto5mve3gdx-user 4.4.4 KTU84P G316HUDXU0AOA4 release-keys
Samsung CPU: SC7727S
Done.
Old 10-13-2017, 13:42   #4 (permalink)
Member: 2463805
Thanks Meter: 18
Repairing process
Hi Umar
Can you please give the steps of repairing process ?
Old 10-13-2017, 14:38   #5 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 588
CLK Rate:21000 khz
HiPower mode is ON!
Compression is ON
GPT: damaged
Build ID: KTU84P
Release ID: 4.4.4
Done.
Old 03-31-2018, 22:13   #6 (permalink)
ben khalifa's Avatar
Member: 1122865
Thanks Meter: 40
Old 04-01-2018, 04:19   #7 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 588
first post your logs then can say procedure
Old 04-02-2018, 12:54   #8 (permalink)
Member: 1122865
Thanks Meter: 40
Config set from ****l : Vendor:LG Model:P705
Compression is ON
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 2.9.0.0
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 01FFA00C3950E5E7, ,FW Ver.: 01.62
CMD Pullup Level:2072 mV
CMD Active Level:2629 mV
Box IO Level:2800 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
EMMC CID : 90014A483447326211019D76556CC168
EMMC Date: 12/2014 Rev.0x1
EMMC NAME: H4G2b , S/N: 2641778028
Backup saved: H4G2b _2641778028_20180331_2218.extcsd
Done.
Old 04-02-2018, 19:32   #9 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 588
Compression is ON
CLK Rate:7000 kHz
Bus Width:1bit,SDR
Done.
yes possible with this logs
Old 04-04-2018, 18:12   #10 (permalink)
Member: 2463805
Thanks Meter: 18
Umar can fix it
He will fix it , if umar bro will be busy I can Try to doit
The Following User Says Thank You to pirunthan7 For This Useful Post:
Page generated in 0.40258 seconds with 7 queries
