05-07-2017, 13:51 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | G530H/DV dead reapir ( emmc repair ) here the log:- Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58 CMD Pullup Level:1815 mV CMD Active Level:2835 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : FE014E50314A39354B134333689C225A EMMC CSD : D06E01320F5913FFFFFFFFEF92400070 EMMC Manufacturer ID: 00FE , OEM ID: 014E EMMC Date: 02/2015 Rev.0x13 EMMC NAME: P1J95K , S/N: 1127442588 EMMC NAME (HEX): 50314A39354B00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: P1J95K_1127442588_20170503_1917.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 15269854 Partition info successfully found --------------------------------------------- P0 (APNHLOS) [0x400000 0xf00000] Size: 15.0MB P1 (MODEM) [0x1300000 0x3970000] Size: 57.437MB P2 (SBL1) [0x4c70000 0x80000] Size: 512.0KB P3 (DDR) [0x4cf0000 0x8000] Size: 32.0KB P4 (ABOOT) [0x4cf8000 0x200000] Size: 2.0MB P5 (RPM) [0x4ef8000 0x80000] Size: 512.0KB P6 (QSEE) [0x4f78000 0x80000] Size: 512.0KB P7 (QHEE) [0x4ff8000 0x80000] Size: 512.0KB P8 (FSG) [0x5078000 0x300000] Size: 3.0MB P9 (SEC) [0x5378000 0x4000] Size: 16.0KB P10 (PAD) [0x537c000 0xa84000] Size: 10.515MB P11 (PARAM) [0x5e00000 0xa00000] Size: 10.0MB P12 (EFS) [0x6800000 0xe00000] Size: 14.0MB P13 (MODEMST1) [0x7600000 0x300000] Size: 3.0MB P14 (MODEMST2) [0x7900000 0x300000] Size: 3.0MB P15 (BOOT) [0x7c00000 0xd00000] Size: 13.0MB P16 (RECOVERY) [0x8900000 0xf00000] Size: 15.0MB P17 (FOTA) [0x9800000 0x500400] Size: 5.0MB P18 (BACKUP) [0x9d00400 0x6fdc00] Size: 6.991MB P19 (FSC) [0xa3fe000 0x300000] Size: 3.0MB P20 (SSD) [0xa6fe000 0x2000] Size: 8.0KB P21 (PERSIST) [0xa700000 0x800000] Size: 8.0MB P22 (PERSDATA) [0xaf00000 0x900000] Size: 9.0MB P23 (SYSTEM) [0xb800000 0x5d800000] Size: 1.460GB P24 (CACHE) [0x69000000 0x12c00000] Size: 300.0MB P25 (HIDDEN) [0x7bc00000 0xa00000] Size: 10.0MB P26 (USERDATA) [0x7c600000 0x1559fb000] Size: 5.336GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000B800000 (1.460GB) Build ID: LRX22G Display Build ID: LRX22G.G530HXCU1BOH3 Release ID: 5.0.2 Device Model: SM-G530H Device Name: fortunave3gxx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: msm8916 Product ID: fortunave3g Build Description: fortunave3gxx-user 5.0.2 LRX22G G530HXCU1BOH3 release-keys Samsung CPU: MSM8216 --------------------------------------------- Done. |
The Following 3 Users Say Thank You to ALI_MAFIA For This Useful Post: |
