Old 12-15-2017, 16:11   #1 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
G531F CMD timeout error
Compression is ON
Z3X EasyJtag Software ver. 2.6.0.1
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.60
CMD Pullup Level:1732 mV
CMD Active Level:2155 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
1,8V and 2,8V disconnected , powered by USB cable .
The Following User Says Thank You to usernome For This Useful Post:
Old 12-16-2017, 23:13   #2 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Can anyone help me ?
Old 12-17-2017, 14:12   #3 (permalink)
laxmi kamlesh's Avatar
Member: 1873645
Thanks Meter: 977
Connection Issue Or Emmc Dead
Old 12-18-2017, 13:43   #4 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
It can't be dead . The phone was working .
The phone died after a downgrade .
Old 12-18-2017, 15:02   #5 (permalink)
Member: 1873645
Thanks Meter: 977
check clk resistance
Old 12-18-2017, 21:26   #6 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
The wire goes directly under the chip , why should I check the resistance ?
Old 12-19-2017, 17:30   #7 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
So , is there any solution ?
Old 12-19-2017, 18:58   #8 (permalink)
Member: 2343170
Thanks Meter: 50
G531f
Same problem is my g531f esayjtag not connected and error
And atf same adapter connected ok
Old 12-20-2017, 14:38   #9 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Is there anybody here ?
You must understand that we cannot keep our customers forever .
Thanks !
Old 12-20-2017, 19:07   #10 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Try to Use pull-up resistor method
Sent from my iPhone using Tapatalk
Old 12-21-2017, 12:58   #11 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
I did that of course ...
Old 12-22-2017, 18:40   #12 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Old 12-27-2017, 13:44   #13 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Old 01-09-2018, 19:20   #14 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Old 01-09-2018, 20:52   #15 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Change cmd resistor or try to connect other side of resistor
Page generated in 0.23718 seconds with 8 queries
