04-20-2018, 12:19 | #362 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | already flashed from other hands so i cant get the exact bootloader,. do you have compilation of different BL for these? can i have atleast some of your bl,. very large file if ill download all files from support,. pls,.. thanks mr,.. |
04-22-2018, 06:45 | #364 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: Dhaka,Uttara.Bangaladash
Member: 1625192 Status: Offline Sonork: 100.1657037 Thanks Meter: 256 | Quote:
EMMC CID: 90014A483847347592011919ACA5B447 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC NAME: H8G4u , Vendor: SKHYNIX , S/N: 1919ACA5 , rev. 01 EMMC NAME (HEX): 483847347500 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot from: ROM2 (Boot partition 1) , width: 1 bit Boot Partition [179] / Bus Config [177] : 0x48 / 0x00 H/W Reset Function [162] : 0x01 , RST_n signal is permanently enabled Partition setting [PARTITION_SETTING_COMPLETE] : 0x00 EMMC Permanent / Temporary Write Protection : No / No Br ios.Hasan Thanks | |
The Following 2 Users Say Thank You to hasan99 For This Useful Post: |
04-22-2018, 09:15 | #365 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | so it means i really need to download all possible firmware to get the exact bootloader needed? |
The Following User Says Thank You to markrempillo For This Useful Post: |
05-30-2018, 10:35 | #372 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | need help G532F hello, i get this error while repair boot need help to fix it Code: Setting frequence to 21 Mhz CMD Pullup Level: 1639 mV CMD Active Level: 1784 mV EMMC Device Information : EMMC CID: 90014A4838473475920111CB2841A4CA EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 11CB2841 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_11CB2841_20180530_151552.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #1 Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #2 Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #3 Too many errors. Writing has been stopped |
