11-03-2018, 12:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: India
Member: 1014826 Status: Offline Thanks Meter: 88 | How To repair Gpt Damage J200 CMD Pullup Level:513 mV CMD Active Level:1682 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A4838473474920120764D0473E1 eMMC CSD : D02701320F5903FFFFFFFFE78A40002B eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 07/2016 Rev.0x1 eMMC NAME: H8G4t , S/N: 544623876 eMMC NAME (HEX): 483847347420 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4t _ 544623876_20181103_1658.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 15269854 Found Data areas (firmware parts) count is: 23 Partition info successfully found --------------------------------------------- P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB P4 (M9KEFS1) [0x2800000 0x400000] Size: 4.0MB P5 (M9KEFS2) [0x2c00000 0x400000] Size: 4.0MB P6 (M9KEFS3) [0x3000000 0x400000] Size: 4.0MB P7 (CARRIER) [0x3400000 0x400000] Size: 4.0MB P8 (PARAM) [0x3800000 0x800000] Size: 8.0MB P9 (BOOT) [0x4000000 0xd00000] Size: 13.0MB P10 (RECOVERY) [0x4d00000 0xf00000] Size: 15.0MB P11 (OTA) [0x5c00000 0x800000] Size: 8.0MB P12 (CDMA-RADIO) [0x6400000 0x400000] Size: 4.0MB P13 (RADIO) [0x6800000 0x2800000] Size: 40.0MB P14 (TOMBSTONES) [0x9000000 0x400000] Size: 4.0MB P15 (TDATA) [0x9400000 0x400000] Size: 4.0MB P16 (PERSISTENT) [0x9800000 0x100000] Size: 1.0MB P17 (PERSDATA) [0x9900000 0xc00000] Size: 12.0MB P18 (RESERVED2) [0xa500000 0x300000] Size: 3.0MB P19 (SYSTEM) [0xa800000 0x90000000] Size: 2.250GB P20 (CACHE) [0x9a800000 0xc800000] Size: 200.0MB P21 (HIDDEN) [0xa7000000 0x2800000] Size: 40.0MB P22 (USERDATA) [0xa9800000 0x128400000] Size: 4.628GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000A800000 (2.250GB) Build ID: LMY47X Display Build ID: LMY47X.J200GDDU2ARJ6 Release ID: 5.1.1 Device Model: SM-J200G Device Name: j2ltedd Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: exynos3 Product ID: j2lte Build Description: j2ltedd-user 5.1.1 LMY47X J200GDDU2ARJ6 release-keys Samsung CPU: exynos3475 --------------------------------------------- Done. |
11-03-2018, 13:11 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Shiraz Iran Age: 37
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | I think that you can create it and it can be one time resize and after one you cant change it! see here: http://forum.gsmhosting.com/vbb/13395961-post8.html |
