Old 04-20-2018, 11:54   #361 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
may you try flash more old boot files what in your phone.
The Following User Says Thank You to blang For This Useful Post:
Old 04-20-2018, 12:19   #362 (permalink)
Member: 665025
Thanks Meter: 44
already flashed from other hands so i cant get the exact bootloader,.
do you have compilation of different BL for these? can i have atleast some of your bl,. very large file if ill download all files from support,.
pls,.. thanks mr,..
Old 04-21-2018, 08:19   #363 (permalink)
Member: 665025
Thanks Meter: 44
still no tested solution?,............................thanks
Old 04-22-2018, 06:45   #364 (permalink)
Member: 1625192
Sonork: 100.1657037
Thanks Meter: 256
EMMC CID: 90014A483847347592011919ACA5B447
EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
EMMC NAME: H8G4u , Vendor: SKHYNIX , S/N: 1919ACA5 , rev. 01
EMMC NAME (HEX): 483847347500
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot from: ROM2 (Boot partition 1) , width: 1 bit
Boot Partition [179] / Bus Config [177] : 0x48 / 0x00
H/W Reset Function [162] : 0x01 , RST_n signal is permanently enabled
Partition setting [PARTITION_SETTING_COMPLETE] : 0x00
EMMC Permanent / Temporary Write Protection : No / No
ios.Hasan
Thanks
The Following 2 Users Say Thank You to hasan99 For This Useful Post:
Old 04-22-2018, 09:15   #365 (permalink)
Member: 665025
Thanks Meter: 44
so it means i really need to download all possible firmware to get the exact bootloader needed?
The Following User Says Thank You to markrempillo For This Useful Post:
Old 04-22-2018, 09:22   #366 (permalink)
Member: 665025
Thanks Meter: 44
pls hasan can you help me to revive this device,. thanks in advance,..
Old 04-22-2018, 11:35   #367 (permalink)
Member: 1625192
Sonork: 100.1657037
Thanks Meter: 256
From my profile you can contact me with my details
Thank you
ios.Hasan
Old 04-23-2018, 01:17   #368 (permalink)
Member: 665025
Thanks Meter: 44
Thank you
ios.Hasan
hi hasan,. if u hav time, pls add me on sonork,. thanks in advance,..
Old 04-25-2018, 02:06   #369 (permalink)
Member: 665025
Thanks Meter: 44
pls help,............................................. ........................
Old 04-25-2018, 06:09   #370 (permalink)
Member: 665025
Thanks Meter: 44
help.,............................................ ..........................
Old 05-28-2018, 07:28   #371 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 117
Originally Posted by pirunthan7 View Post
First Thank you for sharing but have a doubt, is it possible to connect without CLK ? regarding your pic i see there is no connection between CLK can you please explain it.
Thanks
impossible..without clk pulse nothing...
Old 05-30-2018, 10:35   #372 (permalink)
bimes's Avatar
Member: 729381
Thanks Meter: 248
need help G532F
hello,
i get this error while repair boot
need help to fix it
Setting frequence to 21 Mhz
CMD Pullup Level: 1639 mV
CMD Active Level: 1784 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920111CB2841A4CA
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 11CB2841 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_11CB2841_20180530_151552.extcsd
EMMC Init completed.
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #1
Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #2
Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #3
Too many errors. Writing has been stopped
Old 05-31-2018, 13:41   #373 (permalink)
bimes's Avatar
Member: 729381
Thanks Meter: 248
write done with version 1.4.9.0
Old 06-04-2018, 16:24   #374 (permalink)
Member: 2292877
Thanks Meter: 4
Originally Posted by Reliable Shop View Post
HiPower mode is OFF
CMD Pullup Level: 1804 mV
CMD Active Level: 2279 mV
Can't init device. Reason: CMD Timeout Error
same problem..
did u solve it ?
give me a hand please.
thanks
Old 06-21-2018, 17:46   #375 (permalink)
Member: 2711525
Thanks Meter: 21
Samsung G532G Dead Boot Repair Full Guide
http://www.youtube.com/watch?v=S68pWJTfwsE
The Following 2 Users Say Thank You to DroidMaster For This Useful Post:
Page generated in 0.32771 seconds with 10 queries
