Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-20-2018, 02:38   #1 (permalink)
Member: 665025
Thanks Meter: 23
SM-G532F dead boot
it was for unlocking only,.
came from another shop, the tech unlock it using adb and rooting,.
unlock done but after flashed by 4files, device now became dead.
using easy jtag: file from support, rom1 rom2:
info:
eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018)
Microsoft Windows 10 (64 bit) build 10586 (10.0.10586.0)
Looking for EasyJTAG box...
EasyJTAG API ver. 2100
EasyJTAG Box Serial = 0100501F46B1BB65
Card Serial = AA4F8096
EasyJTAG Box Firmware = 1.62
Changelog:
17.04.2018 (ver 1.5.0.0)
Fix: Bugs that have been found through your crash report
Add: Showing Connected Pins for a Socket (Emmc check)
Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor)
Add: SmartReport for Sandisk
Add: Vendor Sony
Add: Automatic backup of the TrimArea partition for Sony (read by vendor)
Add: Grouping of extracted messages by sender (Explorer)
Add: Extract Calendar (Explorer)
Add: Checking FullDiskEncryption from Boot (Explorer)
Add: Scan FullFlash from devices with UFS-memory (Explorer)
Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung)
Add: Ext4 formatting is completely rewritten (write by vendor)
Add: Reading files with emmc errors (Explorer)
Add: Skipping for existing files while saving (Explorer)
Add: Write protection for ROM 2/3
Setting frequence to 21 Mhz
CMD Pullup Level: 1794 mV
CMD Active Level: 1227 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920120A84014B4B2
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 20A84014 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_20A84014_20180419_182007.extcsd
EMMC Init completed.
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-G532F
Phone platform = mt6737t
CPU Abi = armeabi-v7a
Mediatek platform = MT6737T
Android release = 6.0.1
Firmware version = MMB29T.G532FXWU1APJ1
Firmware date = Sat Oct 1 18:25:42 KST 2016
writing:
CMD Pullup Level: 1784 mV
Backup saved: H8G4u_20A84014_20180419_182241.extcsd
Operation: Write Dump
Writing to: ROM1 , start: 0x000000000000 , size: 0x00000C000000
Input file: C:\Users\TRENSH VTC\Desktop\Samsung_SM-G532F_dump_rom1_192mb.bin
eMMC switching to ROM1
Writing partition...
Done writing partition. Write speed: 578.22 KB/s
All done time: [00:05:40:432]
CMD Pullup Level: 1763 mV
CMD Active Level: 1258 mV
Backup saved: H8G4u_20A84014_20180419_182840.extcsd
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Input file: C:\Users\TRENSH VTC\Desktop\bootloader_rom2.bin
eMMC switching to ROM2
Done writing partition. Write speed: 197.50 KB/s
All done time: [00:00:21:152]
STILL DEAD,.
write by vendor with latest BL from support:
Samsung SM-G532F Boot Repair File For Easy Jtag PLUS File Make By Yash Mobile Banswara Rajasthan
Backup saved: H8G4u_20A84014_20180419_183528.extcsd
Opening file: H8G4u_samsung.pit
Pit: H8G4u_samsung.pit
Entry count: 31
The size of the last section has been updated
BL_G532FXXU1AQG2_CL11836556_QB14220797_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
CMD Pullup Level: 1773 mV
CMD Active Level: 1247 mV
Backup saved: H8G4u_20A84014_20180419_183545.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: lk.bin
Unpacking file: param.bin
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
Erasing partition...
Done writing partition. Write speed: 310.74 KB/s
Partition name: EFUSE
Filename: efuse.bin , Offset: 000001B80000 , filesize: 524288 bytes
Done writing partition. Write speed: 574.80 KB/s
Partition name: TEE1
Filename: tee1.bin , Offset: 000001C00000 , filesize: 6291456 bytes
Done writing partition. Write speed: 583.81 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 584.80 KB/s
Check BOOT_PARTITION_EN for the selected vendor
All done time: [00:00:24:498]
insert battery, insert jig, press power on,.
STILL DEAD,.
using another pit and latest BL from support:
CMD Pullup Level: 1732 mV
Backup saved: H8G4u_20A84014_20180419_184155.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 34
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
CMD Active Level: 1268 mV
Backup saved: H8G4u_20A84014_20180419_184216.extcsd
Unpacking file: preloader.img
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
Done writing partition. Write speed: 162.51 KB/s
Partition name: LK
Done writing partition. Write speed: 309.48 KB/s
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 9.81 KB/s
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 568.30 KB/s
Done writing partition. Write speed: 614.36 KB/s
All done time: [00:00:58:186]
pls help team,.. thnks in advance,.
The Following User Says Thank You to markrempillo For This Useful Post:
Old 04-20-2018, 11:54   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 174,910
may you try flash more old boot files what in your phone.
The Following User Says Thank You to blang For This Useful Post:
Old 04-20-2018, 12:19   #3 (permalink)
Member: 665025
Thanks Meter: 23
already flashed from other hands so i cant get the exact bootloader,.
do you have compilation of different BL for these? can i have atleast some of your bl,. very large file if ill download all files from support,.
pls,.. thanks mr,..
Old 04-21-2018, 08:19   #4 (permalink)
Member: 665025
Thanks Meter: 23
still no tested solution?,............................thanks
Old 04-22-2018, 06:45   #5 (permalink)
Member: 1625192
Sonork: 100.1657037
Thanks Meter: 229
EMMC CID: 90014A483847347592011919ACA5B447
EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
EMMC NAME: H8G4u , Vendor: SKHYNIX , S/N: 1919ACA5 , rev. 01
EMMC NAME (HEX): 483847347500
Boot from: ROM2 (Boot partition 1) , width: 1 bit
Boot Partition [179] / Bus Config [177] : 0x48 / 0x00
H/W Reset Function [162] : 0x01 , RST_n signal is permanently enabled
Partition setting [PARTITION_SETTING_COMPLETE] : 0x00
EMMC Permanent / Temporary Write Protection : No / No
ios.Hasan
Thanks
The Following 2 Users Say Thank You to hasan99 For This Useful Post:
Old 04-22-2018, 09:15   #6 (permalink)
Member: 665025
Thanks Meter: 23
so it means i really need to download all possible firmware to get the exact bootloader needed?
Old 04-22-2018, 09:22   #7 (permalink)
Member: 665025
Thanks Meter: 23
pls hasan can you help me to revive this device,. thanks in advance,..
Old 04-22-2018, 11:35   #8 (permalink)
Member: 1625192
Sonork: 100.1657037
Thanks Meter: 229
From my profile you can contact me with my details
Thank you
ios.Hasan
Old 04-23-2018, 01:17   #9 (permalink)
Member: 665025
Thanks Meter: 23
Thank you
ios.Hasan
hi hasan,. if u hav time, pls add me on sonork,. thanks in advance,..
Old 04-25-2018, 02:06   #10 (permalink)
Member: 665025
Thanks Meter: 23
pls help,............................................. ........................
Old 04-25-2018, 06:09   #11 (permalink)
Member: 665025
Thanks Meter: 23
help.,............................................ ..........................
Old 07-19-2018, 08:33   #12 (permalink)
Member: 1536185
Sonork: 100.167.1876
Thanks Meter: 62
g532f dead boot repair error
i need to repair g532f dead boot but this error comes im new to easy jtag what is the problem please help me
Old 07-23-2018, 14:03   #13 (permalink)
Member: 975554
Thanks Meter: 13
adjust your frequence to 12mhz and try again
Old 07-31-2018, 06:05   #14 (permalink)
Member: 775567
Sonork: tybsky
Thanks Meter: 46
g532f bl file wire successfully set not on help
Partition name: LK
Done writing partition. Write speed: 429.79 KB/s
Done writing partition. Write speed: 90.26 KB/s
Done writing partition. Write speed: 639.62 KB/s
Done writing partition. Write speed: 658.59 KB/s
All done time: [00:00:09:614]
Old 07-31-2018, 13:38   #15 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 380
Try This:
samsung G532F Boot repair done but still dead
After Write Please Give Report Here ( With LOG & Screen Shot )
If Problem Not Solve I Will Give Other Solution
Thanks & Regards By:
All TECH 4 You
The Following User Says Thank You to Yashbanswara For This Useful Post:
Page generated in 0.21417 seconds with 7 queries
