Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-08-2019, 12:43   #1 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
G532G dead needs help
hi, can anyone help me about this logs?
this phone is working and it died after i flashed with a lower version firmware.
so i don't think its emmc problem
see logs :
Done.
extCSD Are not selected , skip writing extCSD
Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM1_000000000000_000020000000.bin
Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM2_000000000000_000000400000.bin
Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM3_000000000000_000000400000.bin
Z3X EasyJtag Software ver. 3.6.1.15
Skip loading eMMC Addon Firmware
CMD Pullup Level:3165 mV
CMD Active Level:3269 mV
Input file : C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM1_000000000000_000020000000.bin
Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM)
Error writing address 0x06180000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x0006180000 (Attempt #1)...
Retry Success!
Error writing address 0x0E380000 Error Code:-101 Reason :CARD Ready Timeout Error
Retry writing address 0x000E380000 (Attempt #1)...
Retry Success!
Error writing address 0x131C0000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x00131C0000 (Attempt #1)...
Retry Success!
Error writing address 0x164C0000 Error Code:-101 Reason :CARD Ready Timeout Error
Retry writing address 0x00164C0000 (Attempt #1)...
Retry Success!
Error writing address 0x19280000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x0019280000 (Attempt #1)...
Retry Success!
Error writing address 0x1C540000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x001C540000 (Attempt #1)...
Retry Success!
Error writing address 0x1F740000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x001F740000 (Attempt #1)...
have tried a lot of times, still have this error
i have 3.3v and 21mhz clk
i am using charger as power supply and moorc adapter with power supply also.
Old 11-08-2019, 15:48   #2 (permalink)
Member: 13148
Thanks Meter: 1,337
you did not post info about type of connection, the box version (1 or 2),
and without this data we cannot give you any answer
Old 11-09-2019, 10:51   #3 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
type of connection is via moorc adapter 5 in 1
box type is i really don't know, i bought this box in 2017.. its an old one not yet easy jtag plus but i updated it to plus.
EasyJtag Suite Classic ver.: 3.6.1.15 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA69-xxxx , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
i tried this now : universal format
and i have resoldered all wires
Running:eMMC: Factory Format
CMD Pullup Level:2928 mV
CMD Active Level:3217 mV
Box IO Level:3300 mV
CLK Rate:14000 kHz
Formatting eMMC card, please wait up to 3 min...
Setting Service Mode...
eMMC Format Done.
Done.
and then i try to write all roms again using the 2 file from support with only charger in phone. with 3.3v and 21 mhz clk
and this is logs :
Done.
Checking NAND Image : C:\emmc file repair jtag\g532g\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM1.bin
Autodetected RAW data
Partition info successfully found
Linux partitions is not found in image...
File successefuly loaded!
Found ROM2 and automatically selected.
Processing file...C:\emmc file repair jtag\g532g\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM1.bin
Processing file...C:\emmc file repair jtag\g532g\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM2.bin
ROM3 Are not selected , skip writing ROM3
Input file : C:\emmc file repair jtag\g532g\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM1.bin
Writing 000AC00000 bytes to 0000000000... ROM1 (USER ROM)
Error writing address 0x03000000 Error Code:-1 Reason :CMD Timeout Error
Retry writing address 0x0003000000 (Attempt #1)...
Retry Success!
Error writing address 0x06800000 Error Code:-1 Reason :CMD Timeout Error
Retry writing address 0x0006800000 (Attempt #1)...
Retry Success!
Done, time taken: 123 sec. Average Write Speed: 1464 kB/s
Input file : C:\emmc file repair jtag\g532g\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM2.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 2 sec. Average Write Speed: 703 kB/s
but when i detect the phone again after writing rom, this is the logs :
there is an error see logs :
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 12FF9016CE5F1172, ,FW Ver.: 01.63
CMD Pullup Level:2939 mV
CMD Active Level:3238 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A483847347592010B5A3088A40C
eMMC CSD : D02701320F5903FFFFFFFFE78A40002A
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 10/2017 Rev.0x1
eMMC NAME: H8G4u , S/N: 190460040
eMMC NAME (HEX): 483847347520
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 0 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_ 190460040_20191109_1755.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,15269854
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB)
Unable to mount SYSTEM , code : 95
Detected USERDATA USERDATA : 0x00E9400000 (3.632GB)
Unable to mount USERDATA , code : 95
Done.
then i go to easy jtag plus for write by vendor and this is logs:
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 12FF9016CE5F1172
Card Serial = AA699FF3
EasyJTAG Box Firmware = 1.63
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
HiPower mode is ON
Setting frequence to 21 MHz
CMD Pullup Level: 2939 mV
CMD Active Level: 3227 mV
EMMC Device Information :
EMMC CID: 90014A483847347592010B5A3088A40C
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 0B5A3088 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_0B5A3088_20191109_175746.extcsd
EMMC Init completed.
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 34
The size of the last section has been updated
BL_G532GDXU1AQI2_CL12327063_QB15069235_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
HiPower mode is ON
CMD Active Level: 3238 mV
Backup saved: H8G4u_0B5A3088_20191109_175758.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 330.89 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 490.43 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 56.12 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 836.97 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 863.14 KB/s
Partition CACHE : formatting as EXT4. Please wait ...
Formatting completed
Partition HIDDEN : formatting as EXT4. Please wait ...
Check BootConfig for the selected vendor
All done time: [00:00:31:611]
but phone still dead.
what do i need to do next please?
thank you
ALSO, when i try to do hw partition to write to extCSD
this is error :
Running:JEDEC: Partitions config burn...
CLK Rate:14000 kHz
GP Multiplier: 400000, 4096 Kb, 4Mb
Partition configuration:
No enhanced user data area
User partition write reliability: off
No GP1 partition
GP1 write reliability: on
No GP2 partition
GP2 write reliability: on
No GP3 partition
GP3 write reliability: on
No GP4 partition
GP4 write reliability: on
All GP Partitions are 0 set size of at least one GP Partition
HW Parts Config Fail.
Old 11-09-2019, 11:38   #4 (permalink)
Member: 13148
Thanks Meter: 1,337
FW Ver.: 01.63 - old box, 1st generation
you can set lover freq (14Mhz) if you get errors, and use 2,8 IO
also you can add 2 resistors to adapter ~200 Ohm from CMD and D0 to IO (1,8 line) as at pinouts pictures
When you restore boot via BL files and Plus Software, you need De-select Repartition (it needed when eMMC change)
Now after repair boot you need write only GPT from ane worked dump from same device (write by vendor - from file - select only GPT)
Page generated in 0.27449 seconds with 7 queries
