Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-11-2019, 15:11   #1 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
g610f/dd frp via emmc isp connection
please suggest if i can unlock samsung g610f frp via easy jatag plus emmc isp connection and how?
Old 04-12-2019, 05:24   #2 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
Please someone help, phone is frp locked, only showing custom binary blocked by frp, can frp be unlocked by easy jtag plus?
Old 04-12-2019, 16:56   #3 (permalink)
Member: 2111301
Sonork: 1651880:UzjavaAzizbek
Thanks Meter: 17
Flash ofitsall samsung firmare with home.csc and data will be saved
Old 04-13-2019, 06:44   #4 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
Flashed many firmware from many different countries also but still only rebooting on custom binary blocked by frp.
The Following User Says Thank You to Bhagat20 For This Useful Post:
Old 04-17-2019, 08:30   #5 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
Easy jtag team please help, I was unable to connect g610f with easy jtag... Cmd crc error, maybe problem with soldering, so I decided to desolder isp connections, and connected display to it, but phone not getting on, completely dead, when connecting to PC detecting as exonys 7088.... Please suggest what's wrong?
Old 04-17-2019, 08:38   #6 (permalink)
Member: 818380
Thanks Meter: 36
change pullup cmd resistor and clk resistor
Old 04-17-2019, 10:55   #7 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
sir but now after desoldering all pinouts phone not getting on, completely dead, before phone was just frp locked, i removed pinout also carefully, what is the problem?
Old 04-17-2019, 12:24   #8 (permalink)
Member: 818380
Thanks Meter: 36
do you used hot air to remove metal shield? before solder wire is phone turn on normally ??
often phone dead after solder isp only change those 2 resistor (not resoldering them) after phone will turn on nomally.
Old 04-17-2019, 14:28   #9 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
no sir didn't understand what to do for phone to get back alive? should i change cmd and clk ic on pcb, but where i'll get those ic?
Old 04-17-2019, 15:15   #10 (permalink)
Member: 818380
Thanks Meter: 36
with hight temp iron solder r5005,5007 often broken when solder it.
try to change it.
Old 04-17-2019, 16:20   #11 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
try to change it.
but from where ill get another ic(r5005,5007)
Old Today, 01:56   #12 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 14
Please suggest from where I can get cmd and clk ic? Can I desoldered it from any phones dead board or same model phone's board and solder it on this board?
Page generated in 0.25524 seconds with 7 queries
