08-01-2019, 12:26 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | G610F eMMC has a small size EMMC CID: 150100414A4E42335203F218527854CB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: AJNB3R , HEX: 414A4E423352 , S/N: F2185278 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2017 EMMC ROM 1 (Main User Data) Capacity: 14988 MB (0003A8C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: {param=fsBold}4096 KB{/param} {param=clSilver}(000000400000){/param} Counter: 0 , Response: EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Not change PARTITION_SETTING_COMPLETED]: 0x00 Operation: Changing GP sizes (test mode) ... GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP2 size: 0 MB , WR_REL: 1 , ENH 0 GP3 size: 0 MB , WR_REL: 1 , ENH 0 GP4 size: 0 MB , WR_REL: 1 , ENH 0 Zero sizes. This may damage your eMMC Do you want to continue? HW_PART error. Reason: Card already partitioned Opening file: E:\EASY JTAG\EMMC_AJNB3R_ROM1_000000000000_000020000000.bi n Analyzing Image: EMMC_AJNB3R_ROM1_000000000000_000020000000.bin Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed eMMC has a small size LOG EMMC Info Other Phone work EMMC Device Information : EMMC CID: 150100414A4E42335203442958DD2431 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: AJNB3R , HEX: 414A4E423352 , S/N: 442958DD , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x01 / 0x00 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Any Solution ? |
08-01-2019, 17:32 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Every GP partition allocating space from user area. Normally it take little more space. If GP have a enhanced flag - it take 2x more space from user area. So size difference in this two cards is allocated GP partition. Since eMMC 5.0 standard there is no way to change GP config if it written once. |
The Following 4 Users Say Thank You to NoName® For This Useful Post: |
