10-10-2019, 15:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | g615f hang on samsung logo after boot repair EasyJTAG Box Firmware = 2.48 10/10/2019 6:49:32 PM> Setting interface to EasyJtag2/ISP 10/10/2019 6:49:32 PM> Setting bus width to 1 Bit 10/10/2019 6:49:32 PM> Setting frequence to 18 Mhz 10/10/2019 6:49:32 PM> CMD Pullup Level: 1824 mV 10/10/2019 6:49:32 PM> CMD Active Level: 1881 mV 10/10/2019 6:49:32 PM> eMMC Init returned = 0 10/10/2019 6:49:32 PM> EMMC Device Information : 10/10/2019 6:49:32 PM> EMMC CID: 150100525831344D42000531D387A4D1 10/10/2019 6:49:32 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 10/10/2019 6:49:32 PM> EMMC Manufacture Name: SAMSUNG , EMMC NAME: RX14MB , EMMC NAME (HEX): 525831344D42 , S/N: 0531D387 , rev. 0x00 10/10/2019 6:49:32 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2017 10/10/2019 6:49:32 PM> EMMC ROM 1 (Main User Data) Capacity: 29804 MB (000746C00000) 10/10/2019 6:49:32 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/10/2019 6:49:32 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/10/2019 6:49:32 PM> EMMC GP1 (GP Partition 1) Capacity: 8 MB , ENH , WR_REL (000000800000) 10/10/2019 6:49:32 PM> EMMC Permanent Write Protection: No 10/10/2019 6:49:32 PM> EMMC Temporary Write Protection: No 10/10/2019 6:49:32 PM> Extended CSD Information : 10/10/2019 6:49:32 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/10/2019 6:49:32 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/10/2019 6:49:32 PM> Boot Bus Config: 0x04 , width 1bit 10/10/2019 6:49:32 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/10/2019 6:49:32 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/10/2019 6:49:32 PM> Device supports partitioning features 10/10/2019 6:49:32 PM> Device can have enhanced technological features in partitions and user data area 10/10/2019 6:49:32 PM> Device can have extended partitions attribute 10/10/2019 6:49:32 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 10/10/2019 6:49:32 PM> Backup saved: RX14MB_0531D387_20191010_184932.extcsd 10/10/2019 6:49:32 PM> EMMC Init completed. 10/10/2019 6:49:32 PM> 10/10/2019 6:49:32 PM> Scanning soft partitions 10/10/2019 6:49:32 PM> GPT header is found and is valid 10/10/2019 6:49:32 PM> Partition: lk, [000000400000 - 000000600000], size: 000000200000 10/10/2019 6:49:32 PM> Partition: seccfg, [000000600000 - 000000700000], size: 000000100000 10/10/2019 6:49:32 PM> Partition: efuse, [000000700000 - 000000800000], size: 000000100000 10/10/2019 6:49:32 PM> Partition: nvram, [000000800000 - 000001000000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: tee1, [000001000000 - 000001800000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: BOTA0, [000001800000 - 000001C00000], size: 000000400000 10/10/2019 6:49:32 PM> Partition: BOTA1, [000001C00000 - 000002000000], size: 000000400000 10/10/2019 6:49:32 PM> Partition: BOTA2, [000002000000 - 000002800000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: EFS, [000002800000 - 000003000000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: protect1, [000003000000 - 000003800000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: protect2, [000003800000 - 000004000000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: nvcfg, [000004000000 - 000005800000], size: 000001800000 10/10/2019 6:49:32 PM> Partition: nvdata, [000005800000 - 000007800000], size: 000002000000 10/10/2019 6:49:32 PM> Partition: PARAM, [000007800000 - 000008000000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: recovery, [000008000000 - 000009800000], size: 000001800000 10/10/2019 6:49:32 PM> Partition: boot, [000009800000 - 00000B000000], size: 000001800000 10/10/2019 6:49:32 PM> Partition: md1img, [00000B000000 - 000011400000], size: 000006400000 10/10/2019 6:49:32 PM> Partition: md1dsp, [000011400000 - 000011600000], size: 000000200000 10/10/2019 6:49:32 PM> Partition: md1arm7, [000011600000 - 000011800000], size: 000000200000 10/10/2019 6:49:32 PM> Partition: md3img, [000011800000 - 000012000000], size: 000000800000 10/10/2019 6:49:32 PM> Partition: proinfo, [000012000000 - 000012300000], size: 000000300000 10/10/2019 6:49:32 PM> Partition: boot_para, [000012300000 - 000012400000], size: 000000100000 10/10/2019 6:49:32 PM> Partition: para, [000012400000 - 000012480000], size: 000000080000 10/10/2019 6:49:32 PM> Partition: PERSISTENT, [000012480000 - 000012500000], size: 000000080000 10/10/2019 6:49:32 PM> Partition: STEADY, [000012500000 - 000012900000], size: 000000400000 10/10/2019 6:49:32 PM> Partition: NAD_REFER, [000012900000 - 000012E00000], size: 000000500000 10/10/2019 6:49:32 PM> Partition: RESERVED2, [000012E00000 - 000013000000], size: 000000200000 10/10/2019 6:49:32 PM> Partition: system, [000013000000 - 0000D3000000], size: 0000C0000000 10/10/2019 6:49:32 PM> Partition: cache, [0000D3000000 - 0000EE000000], size: 00001B000000 10/10/2019 6:49:32 PM> Partition: hidden, [0000EE000000 - 0000F4400000], size: 000006400000 10/10/2019 6:49:32 PM> Partition: userdata, [0000F4400000 - 000747800000], size: 000653400000 10/10/2019 6:49:32 PM> GPT header successfully parsed 10/10/2019 6:49:32 PM> 10/10/2019 6:49:32 PM> Get firmware version 10/10/2019 6:49:32 PM> 10/10/2019 6:49:33 PM> Firmware info not found please suggest what need to be done? in recovery mode showing- E:ensure_path_unmounted failed to unmount /efs (Device or resource busy) |
10-10-2019, 17:38 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,949 | mtk samsung devices are strange. it’s very bad that you don’t get rid of the action logs that you did with the device. GP1 partition may interfere with normal operation, it's hard for me to say I'm not clairvoyant maybe the problem is in something else, maybe you damaged something when working with the board |
The Following User Says Thank You to layder For This Useful Post: |
10-10-2019, 17:41 | #4 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,949 | and no need to write a few messages "please help" I read the forum when there is time, I still have the main work, and I can not sit on the forum constantly and help everyone from morning to evening |
10-11-2019, 09:38 | #8 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,949 | Quote:
somttime in null or 33R you can always solder 15-21-27R, all be fine Last edited by layder; 10-12-2019 at 12:46. | |
