Old 07-25-2014, 15:22   #1 (permalink)
Member: 205475
Thanks Meter: 179
g7102 dead after 4.4.2 sdc not work direct emmc
phone was 4.3 after update to 4.4.2 work customer try downgrade it after that dead.
i try sdc not work so i try direct emmc give this error need help plz.
Z3X EasyJtag Software ver. 1.5.6.0
Loading eMMC Addon Firmware... IO: 2850 mV
Box S/N: 0100801AB3C0706E, ,FW Ver.: 01.50
CMD Pullup Level:2041 mV
CMD Active Level:2340 mV
eMMC Device Information
EMMC CID : 15010038574D423352008E0BBA5D5110
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2014 Rev.0x0
EMMC NAME: 8WMB3R , S/N: 2383133277
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Check Data Line !!!
i check data line and everything connect ok
Old 07-25-2014, 22:09   #2 (permalink)
Member: 205475
Thanks Meter: 179
also same result with
Z3X EasyJtag Software ver. 1.5.9.0
Old 07-25-2014, 22:53   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,515
Check Data Line !!!
did you read manual exactly part regarding VCC and VCCq level?
The Following User Says Thank You to blang For This Useful Post:
Old 07-25-2014, 23:41   #4 (permalink)
Member: 205475
Thanks Meter: 179
thanx mr blang but my language arabic and i did not understand exactly what i should to do did u mean i must set voltage tm 2,8 after i soldring all line ?
Old 07-27-2014, 17:41   #5 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Check data line error mean "check dat0 soldering" !!!!!!!!
The Following User Says Thank You to NoName® For This Useful Post:
Old 07-27-2014, 20:56   #6 (permalink)
Member: 205475
Thanks Meter: 179
i have tow grand 2 same condition after update to 4.4.2 customer make downgrade after that became completely dead i try sdc not done so i try emmc direct connect but always give last error.
i confused when i read manual plz can u guide step by step
first i connect all the line
2-connect to box
3-connect usb
4-detect emmc
Check Data Line !!!
The Following User Says Thank You to anasshe For This Useful Post:
Old 07-28-2014, 22:12   #7 (permalink)
mscomp's Avatar
Member: 266158
Sonork: 131654654654
Thanks Meter: 198
use max 3 cm gnd stong wire
The Following 2 Users Say Thank You to mscomp For This Useful Post:
Old 08-09-2014, 11:21   #8 (permalink)
Member: 1683660
Thanks Meter: 14
Please post pinouts emmc g7102
Old 08-09-2014, 12:55   #9 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
download from support. all there
Old 08-11-2014, 13:30   #10 (permalink)
Member: 2149341
Thanks Meter: 31
Use old easyjtag software like 1.0.8
Old 08-11-2014, 23:30   #11 (permalink)
Member: 205475
Thanks Meter: 179
thanx
thanx now box can read the mobile so i write first rom3 thin 2 thin 1 but same until now it is dead i use also jig but same dead i think because it was upgraded to 4.4.2 so we need solution for kitkat dead mobile thanx, i try after that sdc also same not work with kitkat dead mobile
Old 08-11-2014, 23:31   #12 (permalink)
Member: 205475
Thanks Meter: 179
old version not supported g7102 thanx
Old 08-16-2014, 23:50   #13 (permalink)
Member: 2193576
Thanks Meter: 19
hello ..
I updated my grand 2 to 4.4.2. But I found slow net issues.
Then I try to back to 4.3 jellybean. But I flash again by odin.
But suddenly hang in updating. I remove battery. But I put battery now my phone not charge not going to on .
I use many methods to make again download mode. But fail.
I make jtag but fail no boot.
Please give me any way to put back my grand 2 in normal position.
Please help please
Report Post
Old 08-18-2014, 11:13   #14 (permalink)
Mansour Pakdel's Avatar
Member: 2186335
Thanks Meter: 44
Originally Posted by drrami75 View Post
hello ..
Please help please
Report Post
its easy jtag section and you can repair by direct emmc if you not have good knowladge of jtag you can search repair by sd card and there are some method to repair
Old 08-18-2014, 22:49   #15 (permalink)
Member: 205475
Thanks Meter: 179
thanx but i think easy jtag not repair g7102 that updated to 4.4.2 i connect it to emmc and flash all rom from support and same dead until now
Page generated in 0.26882 seconds with 8 queries
