04-11-2020, 02:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | Oppo A3s password unlock Here is the log. EasyJtag Suite Classic ver.: 3.6.1.15 / wxWidgets 3.1.2-W-U started. OS ver.: Windows 10 (build 17763), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.17763.1, are OK Z3X Card Serial : AA8Exx , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM41 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM41) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 02FFA019B6E09005, ,FW Ver.: 01.63 CMD Pullup Level:2433 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E03C79146A8A5C2 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 3348186792 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hB8aP>_3348186792_20200411_0849.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (23.745GB) Unable to mount USERDATA , code : 95 Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 02FFA019B6E09005, ,FW Ver.: 01.63 CMD Pullup Level:2433 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E03C79146A8A5C2 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 3348186792 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB) , formatting... Done. Done. Done. Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 02FFA019B6E09005, ,FW Ver.: 01.63 CMD Pullup Level:2433 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E03C79146A8A5C2 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 3348186792 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x0158000000 (23.745GB) Read EXT fs info Formatting EXT fs... (may take a while...) mmc_write_blocks(0x158004000 , 1000 ), Failed: CARD Ready Timeout Error mmc_write_blocks(0x170005000 , 1000 ), Failed: CMD Timeout Error Returned 5... Read EXT fs info NEW Created filesystem with parameters: Size: 25497153536 Block size: 21474840576 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Ends: 1556480 Label: Trying to mount FS... Shutting down EXT4... Done. Detected (Android Cache)) CACHE : 0x001FB00000 (256.0MB) Read EXT fs info Formatting EXT fs... (may take a while...) mmc_write_blocks(0x27B00000 , 400 ), Failed: CARD Ready Timeout Error mmc_write_blocks(0x27B01000 , 1000 ), Failed: CMD Timeout Error Returned 5... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Inodes: 16384 Label: Trying to mount FS... Shutting down EXT4... Done. --------------------------------------------- Done. Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 02FFA019B6E09005, ,FW Ver.: 01.63 CMD Pullup Level:2423 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E03C79146A8A5C2 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 3348186792 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x0158000000 (23.745GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x001FB00000 (256.0MB) Erasing... Done. --------------------------------------------- Done. |
04-15-2020, 06:44 | #4 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | I am also asking solution for the same problem but easy jtag team have no response, u try this. First backup security areas, then Write dump file or XML file from below link: Dump https://drive.google.com/uc?id=1__EC...xport=download XML https://drive.google.com/uc?id=1gROx...xport=download Then write oppo full factory firmware write by vendor with easy jtag. After that please tell me if this worked, I also have a3s in same condition, but shop is closed that's y I am not able to try this. |
The Following User Says Thank You to Bhagat20 For This Useful Post: |
