06-09-2017, 07:29 | #91 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 2.8V Setting frequence to 21 Mhz HiPower mode is OFF EasyJTAG Box Serial = 16005015120EF521 Card Serial = AA0E-097C EasyJTAG Box Firmware = 01.58 Changelog: 28.05.2017 (ver 1.0.0.47) Fix: Bugs that have been found through your crash report Fix: Searching for partitions when scanning MBR Fix: Searching for MassStorage devices Add: AutoUpdate for the program HiPower mode is OFF CMD Pullup Level: 13148 mV CMD Active Level: 13303 mV EMMC Device Information : EMMC CID: 90014A4838473475920133B8743A24EC EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC NAME: H8G4u , S/N: 33B8743A , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H8G4u_33B8743A_20170609_114741.extcsd EMMC Init completed. Opening file: GRANDPPLTE_CIS_SER.pit Pit: GRANDPPLTE_CIS_SER.pit Entry count: 57582800 The size of the last section has been updated BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img HiPower mode is OFF CMD Pullup Level: 12096 mV CMD Active Level: 11931 mV EMMC Device Information : EMMC CID: 90014A4838473475920133B8743A24EC EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC NAME: H8G4u , S/N: 33B8743A , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H8G4u_33B8743A_20170609_115358.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 183.68 Kb/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 693.96 Kb/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16.66 Kb/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 768.11 Kb/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 761.10 Kb/s All done thanx for the help bro |
06-09-2017, 12:37 | #92 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: meerut
Member: 804463 Status: Offline Thanks Meter: 77 | Quote:
06-09-2017, 13:51 | #93 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.58 CMD Pullup Level:2640 mV CMD Active Level:2763 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.58 CMD Pullup Level:1980 mV CMD Active Level:2268 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4838473475920133B8748F2492 EMMC CSD : D02701320F5903FFFFFFFFE78A40002A EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2017 Rev.0x1 EMMC NAME: H8G4u , S/N: 867726479 EMMC NAME (HEX): 48384734752000 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4u _ 867726479_20170608_1937.extcsd Partition info successfully found --------------------------------------------- P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (NVRAM) [0x800000 0x800000] Size: 8.0MB P2 (LK) [0x1000000 0x200000] Size: 2.0MB P3 (BOTA1) [0x1200000 0x200000] Size: 2.0MB P4 (SECRO) [0x1400000 0x700000] Size: 7.0MB P5 (SECCFG) [0x1b00000 0x80000] Size: 512.0KB P6 (EFUSE) [0x1b80000 0x80000] Size: 512.0KB P7 (TEE1) [0x1c00000 0x600000] Size: 6.0MB P8 (BOTA2) [0x2200000 0x600000] Size: 6.0MB P9 (EFS) [0x2800000 0x800000] Size: 8.0MB P10 (NVDATA) [0x3000000 0x2000000] Size: 32.0MB P11 (PARAM) [0x5000000 0x800000] Size: 8.0MB P12 (RECOVERY) [0x5800000 0x1000000] Size: 16.0MB P13 (BOOT) [0x6800000 0x1000000] Size: 16.0MB P14 (MD1IMG) [0x7800000 0x2000000] Size: 32.0MB P15 (MD1DSP) [0x9800000 0x400000] Size: 4.0MB P16 (KEYSTORE) [0x9c00000 0x800000] Size: 8.0MB P17 (OMEKEYSTORE) [0xa400000 0x380000] Size: 3.500MB P18 (PROINFO) [0xa780000 0x280000] Size: 2.500MB P19 (PARA) [0xaa00000 0x80000] Size: 512.0KB P20 (PERSISTENT) [0xaa80000 0x80000] Size: 512.0KB P21 (STEADY) [0xab00000 0x100000] Size: 1.0MB P22 (PROTECT1) [0xac00000 0x800000] Size: 8.0MB P23 (PROTECT2) [0xb400000 0x800000] Size: 8.0MB P24 (RESERVE2) [0xbc00000 0x400000] Size: 4.0MB P25 (SYSTEM) [0xc000000 0xc0800000] Size: 3.7GB P26 (CACHE) [0xcc800000 0x19000000] Size: 400.0MB P27 (HIDDEN) [0xe5800000 0x3c00000] Size: 60.0MB P28 (USERDATA) [0xe9400000 0xe8800000] Size: 3.632GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB) Build ID: MMB29T Display Build ID: MMB29T.G532GDXU1APJ7 Release ID: 6.0.1 Device Model: SM-G532G Device Name: grandppltedx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: mt6737t Product ID: grandpplte Build Description: grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys Samsung CPU: MT6737T --------------------------------------------- Done. done perfect 6th set done |
06-10-2017, 04:16 | #94 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
The Following User Says Thank You to kothamamun For This Useful Post: |
06-20-2017, 16:27 | #100 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2654484 Status: Offline Thanks Meter: 1 | Its a brand new phone Tested the ISP with easy jtag. After that the screen is blank (no display) once i finish the assembly. Do you think i spoil some component inside while soldering? |
06-22-2017, 13:54 | #101 (permalink) | |
Junior Member Join Date: Nov 2015 Location: Not Yet Found
Member: 2487167 Status: Offline Sonork: 100.1670279 Thanks Meter: 5 | Need EFS Backup Or Full Dump file Quote:
Need EFS Backup Or Full Dump file or please guide me repair imei after emmc repair now phone shows only emergency calls only | |
06-23-2017, 09:49 | #102 (permalink) | |
Member: 2487167 Status: Offline Sonork: 100.1670279 Thanks Meter: 5 | Emergency calls only after write this rom Quote: please help me solve the problem | |
06-23-2017, 11:49 | #103 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: 95.0.206.212 Age: 35
Member: 1095116 Status: Offline Sonork: none Thanks Meter: 17 | thanks thanks but link is not run please add file to another link Quote:
The Following User Says Thank You to salhekmart For This Useful Post: |
06-23-2017, 12:06 | #104 (permalink) | |
Member: 2487167 Status: Offline Sonork: 100.1670279 Thanks Meter: 5 | If You have Full emmc dump file uploade here Quote:
i have network issue in that model | |
