-=P.F.U=- | 09-11-2018 18:36 | finally dead boot repair done ;)
with this small file http://forum.gsmhosting.com/vbb/12976607-post16.html Code:
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial = 06010014FC294D61
Card Serial = AA34-B7FF
EasyJTAG Box Firmware = 1.62
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Setting frequence to 21 Mhz
CMD Pullup Level: 1763 mV
CMD Active Level: 2279 mV
EMMC Device Information :
EMMC CID: 90014A48384734759201C297941E3596
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4u , EMMC NAME (HEX): 483847347500 , S/N: C297941E , rev. 0x01
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: H8G4u_C297941E_20180911_182931.extcsd
EMMC Init completed.
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-G532F
Phone platform = mt6737t
CPU Abi = armeabi-v7a
Mediatek platform = MT6737T
Android release = 6.0.1
Firmware version = MMB29T.G532FXWU1AQG4
Firmware date = Tue Jul 11 21:19:42 KST 2017
Backup saved: H8G4u_C297941E_20180911_183019.extcsd
Operation: Write all eMMC Regions at once
Writing BootConfig ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_QN16BB_ROM2_000000000000_000000400000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 223.46 KB/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_QN16BB_ROM3_000000000000_000000400000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 223.35 KB/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x00000C000000
Filename: EMMC_QN16BB_ROM1_000000000000_00000C000000.bin
eMMC switching to ROM1
Done writing partition. Write speed: 689.89 KB/s
All done time: [00:05:24:901]
CMD Pullup Level: 1773 mV
CMD Active Level: 2299 mV
Backup saved: H8G4u_C297941E_20180911_183744.extcsd
Brand = samsung
Model = SM-G532F
Backup saved: H8G4u_C297941E_20180911_184640.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 34
The size of the last section has been updated
BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
CMD Active Level: 2310 mV
Backup saved: H8G4u_C297941E_20180911_184653.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
Erasing partition...
Done writing partition. Write speed: 181.32 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
Done writing partition. Write speed: 610.59 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 8.57 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 541.37 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 679.72 KB/s
All done time: [00:00:29:945]
Backup saved: H8G4u_C297941E_20180911_184741.extcsd
Brand = samsung
Model = SM-G532F
Backup saved: H8G4u_C297941E_20180911_185005.extcsd
Writing eMMC Register ...
Successfully
Backup saved: H8G4u_C297941E_20180911_185017.extcsd
Done
Done writing partition. Write speed: 223.83 KB/s
Done writing partition. Write speed: 221.86 KB/s
Done writing partition. Write speed: 683.81 KB/s
All done time: [00:05:27:435]
Backup saved: H8G4u_C297941E_20180911_185838.extcsd
Opening file: H8G4u_samsung.pit
Pit: H8G4u_samsung.pit
Entry count: 31
Backup saved: H8G4u_C297941E_20180911_185848.extcsd
Partition name: BOOTLOADER_ROM2
Filename: bootloader_rom2.bin , Offset: 000000000000 , filesize: 4194304 bytes
Done writing partition. Write speed: 222.98 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 2097152 bytes
Done writing partition. Write speed: 696.90 KB/s
Filename: efuse.bin , Offset: 000001B80000 , filesize: 524288 bytes
Done writing partition. Write speed: 693.98 KB/s
Filename: tee1.bin , Offset: 000001C00000 , filesize: 6291456 bytes
Done writing partition. Write speed: 694.83 KB/s
Filename: PARAM.bin , Offset: 000005000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 695.33 KB/s
All done time: [00:01:08:882]
Backup saved: H8G4u_C297941E_20180911_190004.extcsd
Brand = samsung
Model = SM-G532F
Backup saved: H8G4u_C297941E_20180911_190337.extcsd
Get firmware version Brand = samsung
Model = SM-G532F
Firmware date = Tue Jul 11 21:19:42 KST 2017 https://preview.ibb.co/j2r7fU/1.png |
