Old 10-27-2017, 20:23   #196 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
Originally Posted by johnoroo37 View Post
Why no one is talking about my issue...
I need help on this
are you sure wires are good, not so long?
are you sure in EMMC.
also try use search button. there are log thread with G532g boot repair.
The Following User Says Thank You to blang For This Useful Post:
Old 10-28-2017, 05:56   #197 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
Opening file: PIT-SM-G532G-15-03-2017_09-07-10.pit
Pit: PIT-SM-G532G-15-03-2017_09-07-10.pit
Entry count: 34
The size of the last section has been updated
BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 2093 mV
CMD Active Level: 2743 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920123C4491164C0
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX
EMMC Manufacture ID: 0x90 , OEM ID: 014A
EMMC Manufacture Date: 6/2017 , Rev: 01
EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
EMMC NAME (HEX): 483847347592
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_23C44911_20171025_185539.extcsd
EMMC Init completed.
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Error writing at address: 000000000000 ... Retry #1
Writing PIT at address: 000000004400
Error writing at address: 000000004400 ... Retry #1
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Error erasing at address: 000000000000 ... Retry #1
Error erasing at address: 000000180000 ... Retry #1
Error erasing at address: 000000270000 ... Retry #1
Error erasing at address: 000000270000 ... Retry #2
Error erasing at address: 000000270000 ... Retry #3
Too many errors. Erasing has been stopped
HiPower mode is OFF
Frequence: 14 Mhz
CMD Active Level: 2402 mV
Backup saved: H8G4u_23C44911_20171025_185556.extcsd
Writing partition...
Done writing partition. Write speed: 193.40 Kb/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 415.24 Kb/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Error writing at address: 000001B80000 ... Retry #1
Done writing partition. Write speed: 1.80 Kb/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 750.59 Kb/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 761.10 Kb/s
All done
PLEASE I NEED HELP ON WHAT IS WRONG
OR AM I DOING SOMETHING WRONG WHICH I SHOULD KNOW..
always post full log ( softpertition and android version) of easy jitag emmc detection.
plz check vvc and data connection again. if posible check all wire again.
The Following User Says Thank You to ALI_MAFIA For This Useful Post:
Old 10-28-2017, 19:00   #198 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
G532G no download mode after repair
I repaired g532g successfully ,but phone has other issues
-it can't go download mode even using JIG,it powers on directly to recovery !
-in recovery i get this error: E:failed to moun/efs
-I tryed to flash last firmware with 4 files G532G_DXU1AQA4_OLB1AQB1 via jtag but i get too many errors :
28/10/2017 16:04:10> Partition name: BOOTLOADER
28/10/2017 16:04:10> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
28/10/2017 16:04:10> eMMC switching to ROM2
28/10/2017 16:04:10> Erasing partition...
28/10/2017 16:04:18> Writing partition...
28/10/2017 16:04:18> Done writing partition. Write speed: 283,83 Kb/s
28/10/2017 16:04:18> Partition name: LK
28/10/2017 16:04:18> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
28/10/2017 16:04:18> eMMC switching to ROM1
28/10/2017 16:04:19> Erasing partition...
28/10/2017 16:04:20> Writing partition...
28/10/2017 16:04:21> Done writing partition. Write speed: 428,99 Kb/s
28/10/2017 16:04:22> Partition name: SECRO
28/10/2017 16:04:22> Filename: secro.img , Offset: 000001400000 , filesize: 135424 bytes
28/10/2017 16:04:22> eMMC switching to ROM1
28/10/2017 16:04:22> Erasing partition...
28/10/2017 16:04:22> Writing partition...
28/10/2017 16:04:23> Done writing partition. Write speed: 1140,63 Kb/s
28/10/2017 16:04:23> Partition name: EFUSE
28/10/2017 16:04:23> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
28/10/2017 16:04:23> eMMC switching to ROM1
28/10/2017 16:04:23> Erasing partition...
28/10/2017 16:04:23> Writing partition...
28/10/2017 16:04:23> Done writing partition. Write speed: 42,01 Kb/s
28/10/2017 16:04:24> Partition name: TEE1
28/10/2017 16:04:24> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
28/10/2017 16:04:24> eMMC switching to ROM1
28/10/2017 16:04:24> Erasing partition...
28/10/2017 16:04:24> Writing partition...
28/10/2017 16:04:25> Done writing partition. Write speed: 838,78 Kb/s
28/10/2017 16:04:25> Partition name: PARAM
28/10/2017 16:04:25> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
28/10/2017 16:04:25> eMMC switching to ROM1
28/10/2017 16:04:25> Erasing partition...
28/10/2017 16:04:25> Error erasing at address: 000005000000 ... Retry #1
28/10/2017 16:04:26> Writing partition...
28/10/2017 16:04:27> Done writing partition. Write speed: 801,57 Kb/s
28/10/2017 16:04:27> Partition name: RECOVERY
28/10/2017 16:04:27> Filename: recovery.img , Offset: 000005800000 , filesize: 11553040 bytes
28/10/2017 16:04:27> eMMC switching to ROM1
28/10/2017 16:04:27> Erasing partition...
28/10/2017 16:04:28> Writing partition...
28/10/2017 16:04:41> Done writing partition. Write speed: 918,40 Kb/s
28/10/2017 16:04:41> Partition name: BOOT
28/10/2017 16:04:41> Filename: boot.img , Offset: 000006800000 , filesize: 9961744 bytes
28/10/2017 16:04:41> eMMC switching to ROM1
28/10/2017 16:04:41> Erasing partition...
28/10/2017 16:04:42> Writing partition...
28/10/2017 16:04:53> Done writing partition. Write speed: 919,21 Kb/s
28/10/2017 16:04:53> Partition name: MD1IMG
28/10/2017 16:04:53> Filename: md1rom.img , Offset: 000007800000 , filesize: 10519040 bytes
28/10/2017 16:04:53> eMMC switching to ROM1
28/10/2017 16:04:53> Erasing partition...
28/10/2017 16:04:54> Writing partition...
28/10/2017 16:05:06> Done writing partition. Write speed: 908,47 Kb/s
28/10/2017 16:05:06> Partition name: MD1DSP
28/10/2017 16:05:06> Filename: md1dsp.img , Offset: 000009800000 , filesize: 1417728 bytes
28/10/2017 16:05:06> eMMC switching to ROM1
28/10/2017 16:05:06> Erasing partition...
28/10/2017 16:05:07> Writing partition...
28/10/2017 16:05:08> Done writing partition. Write speed: 909,95 Kb/s
28/10/2017 16:05:08> Partition name: SYSTEM
28/10/2017 16:05:08> Filename: system.img , Offset: 00000C000000 , filesize: 3038265680 bytes
28/10/2017 16:05:08> eMMC switching to ROM1
28/10/2017 16:05:09> Erasing partition...
28/10/2017 16:05:32> Error erasing at address: 00003A000000 ... Retry #1
28/10/2017 16:06:38> Error erasing at address: 0000C6880000 ... Retry #1
28/10/2017 16:06:38> Error erasing at address: 0000C6880000 ... Retry #2
28/10/2017 16:06:42> Writing partition...
28/10/2017 16:06:42> Sparse image found v.1.0  Total chunks: 3347
28/10/2017 16:07:45> Error writing at address: 0000123E7000 ... Retry #1
28/10/2017 16:07:45> Error writing at address: 0000123E7000 ... Retry #2
28/10/2017 16:07:45> Error writing at address: 0000123E7000 ... Retry #3
28/10/2017 16:07:45> Too many errors. Writing has been stopped
The Following User Says Thank You to jawad8305 For This Useful Post:
Old 10-29-2017, 07:50   #199 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
i do this operation few times.. it works perfectly
today received g532g unit dead by another shop
it gives this error after load .pit file
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 2041 mV
CMD Active Level: 2289 mV
Can't init device. Reason: CARD Data FIFO Timeout Error
Old 10-29-2017, 20:22   #200 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
10/25/2017 7:26:57 PM> eMMC_tool Suite ver. 1.4.8.0
10/25/2017 7:26:57 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015)
10/25/2017 7:26:57 PM> Looking for EasyJTAG box...
10/25/2017 7:26:57 PM> EasyJTAG API ver. 2008
10/25/2017 7:26:57 PM> Setting IO Levels to 2.8V
10/25/2017 7:26:57 PM> Setting frequence to 21 Mhz
10/25/2017 7:26:57 PM> HiPower mode is OFF
10/25/2017 7:26:58 PM> OpenUSB returned = 0
10/25/2017 7:26:58 PM> Power Controller returned = 0
10/25/2017 7:26:59 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:27:05 PM> Card Serial = AADF-497C
10/25/2017 7:27:05 PM> CardAttr = 3B7D95000080318065B0831148C883009000
10/25/2017 7:27:05 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:27:13 PM> Looking for EasyJTAG box...
10/25/2017 7:27:13 PM> EasyJTAG API ver. 2008
10/25/2017 7:27:13 PM> Setting IO Levels to 2.8V
10/25/2017 7:27:13 PM> Setting frequence to 21 Mhz
10/25/2017 7:27:13 PM> HiPower mode is OFF
10/25/2017 7:27:14 PM> OpenUSB returned = 0
10/25/2017 7:27:14 PM> Power Controller returned = 0
10/25/2017 7:27:15 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:27:15 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:27:15 PM> HiPower mode is OFF
10/25/2017 7:27:15 PM> Frequence: 21 Mhz
10/25/2017 7:27:15 PM> CMD Pullup Level: 2103 mV
10/25/2017 7:27:15 PM> CMD Active Level: 2753 mV
10/25/2017 7:27:15 PM> eMMC Init returned = 0
10/25/2017 7:27:15 PM> EMMC Device Information :
10/25/2017 7:27:15 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:27:15 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:27:15 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:27:15 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:27:15 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:27:15 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:27:15 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:27:15 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:27:15 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:27:15 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:27:15 PM> EMMC Permanent Write Protection: No
10/25/2017 7:27:15 PM> EMMC Temporary Write Protection: No
10/25/2017 7:27:15 PM> Extended CSD Information :
10/25/2017 7:27:15 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:27:15 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:27:15 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:27:15 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:27:15 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:27:15 PM> Device supports partitioning features
10/25/2017 7:27:15 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:27:15 PM> Device can have extended partitions attribute
10/25/2017 7:27:15 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:27:15 PM> Backup saved: H8G4u_23C44911_20171025_192715.extcsd
10/25/2017 7:27:15 PM> EMMC Init completed.
10/25/2017 7:27:15 PM> Get firmware version
10/25/2017 7:27:18 PM> Brand = samsung
10/25/2017 7:27:18 PM> Looking for EasyJTAG box...
10/25/2017 7:27:18 PM> EasyJTAG API ver. 2008
10/25/2017 7:27:18 PM> Setting IO Levels to 2.8V
10/25/2017 7:27:18 PM> Setting frequence to 21 Mhz
10/25/2017 7:27:18 PM> HiPower mode is OFF
10/25/2017 7:27:19 PM> OpenUSB returned = 0
10/25/2017 7:27:19 PM> Power Controller returned = 0
10/25/2017 7:27:20 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:27:20 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:27:20 PM> HiPower mode is OFF
10/25/2017 7:27:20 PM> Frequence: 21 Mhz
10/25/2017 7:27:20 PM> CMD Pullup Level: 2093 mV
10/25/2017 7:27:20 PM> CMD Active Level: 2732 mV
10/25/2017 7:27:20 PM> eMMC Init returned = 0
10/25/2017 7:27:20 PM> EMMC Device Information :
10/25/2017 7:27:20 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:27:20 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:27:20 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:27:20 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:27:20 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:27:20 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:27:20 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:27:20 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:27:20 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:27:20 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:27:20 PM> EMMC Permanent Write Protection: No
10/25/2017 7:27:20 PM> EMMC Temporary Write Protection: No
10/25/2017 7:27:20 PM> Extended CSD Information :
10/25/2017 7:27:20 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:27:20 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:27:20 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:27:20 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:27:21 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:27:21 PM> Device supports partitioning features
10/25/2017 7:27:21 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:27:21 PM> Device can have extended partitions attribute
10/25/2017 7:27:21 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:27:21 PM> Backup saved: H8G4u_23C44911_20171025_192721.extcsd
10/25/2017 7:27:21 PM> EMMC Init completed.
10/25/2017 7:27:27 PM> Reading from: ROM1 , start: 0x000000000000 , size: 0x000000020000
10/25/2017 7:27:27 PM> Output file: C:\Program Files\Z3X\EASYJTAGPLUS\Backups\EMMC_H8G4u_ROM1_000 000000000_000000020000.bin
10/25/2017 7:27:27 PM> eMMC switching to ROM1
10/25/2017 7:27:28 PM> Reading partition...
10/25/2017 7:27:37 PM> Error reading at address: 000000000000 ... Retry #1
10/25/2017 7:27:37 PM> Error result: -4
10/25/2017 7:27:37 PM> Done reading partition. Read speed: 13.01 Kb/s
10/25/2017 7:27:40 PM> Model = SM-G532G
10/25/2017 7:27:40 PM> Phone platform = mt6737t
10/25/2017 7:27:40 PM> CPU Abi = armeabi-v7a
10/25/2017 7:27:40 PM> Mediatek platform = MT6737T
10/25/2017 7:27:40 PM> Android release = 6.0.1
10/25/2017 7:27:40 PM> Firmware version = MMB29T.G532GDXU1APJ3
10/25/2017 7:27:40 PM> Firmware date = Tue Oct 11 21:19:11 KST 2016
10/25/2017 7:28:17 PM>
10/25/2017 7:28:17 PM> Looking for EasyJTAG box...
10/25/2017 7:28:17 PM> EasyJTAG API ver. 2008
10/25/2017 7:28:17 PM> Setting IO Levels to 2.8V
10/25/2017 7:28:17 PM> Setting frequence to 7 Mhz
10/25/2017 7:28:17 PM> HiPower mode is OFF
10/25/2017 7:28:18 PM> OpenUSB returned = 0
10/25/2017 7:28:18 PM> Power Controller returned = 0
10/25/2017 7:28:19 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:28:19 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:28:19 PM> HiPower mode is OFF
10/25/2017 7:28:20 PM> Frequence: 7 Mhz
10/25/2017 7:28:20 PM> CMD Pullup Level: 2093 mV
10/25/2017 7:28:20 PM> CMD Active Level: 2732 mV
10/25/2017 7:28:20 PM> eMMC Init returned = 0
10/25/2017 7:28:20 PM> EMMC Device Information :
10/25/2017 7:28:20 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:28:20 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:28:20 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:28:20 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:28:20 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:28:20 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:28:20 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:28:20 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:28:20 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:28:20 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:28:20 PM> EMMC Permanent Write Protection: No
10/25/2017 7:28:20 PM> EMMC Temporary Write Protection: No
10/25/2017 7:28:20 PM> Extended CSD Information :
10/25/2017 7:28:20 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:28:20 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:28:20 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:28:20 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:28:20 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:28:20 PM> Device supports partitioning features
10/25/2017 7:28:20 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:28:20 PM> Device can have extended partitions attribute
10/25/2017 7:28:20 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:28:20 PM> Backup saved: H8G4u_23C44911_20171025_192820.extcsd
10/25/2017 7:28:20 PM> EMMC Init completed.
10/25/2017 7:28:20 PM> Scan from: H8G4u
10/25/2017 7:28:20 PM> Vendor: Mediatek
10/25/2017 7:28:20 PM> Searching GPT ...
10/25/2017 7:28:20 PM> GPT header is found and is valid
10/25/2017 7:28:22 PM> GPT header successfully parsed
10/25/2017 7:28:22 PM> Scan done
10/25/2017 7:28:22 PM> Mount [efs] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [nvdata] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [protect_f] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [protect_s] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [system] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [cache] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [hidden] successfully PartType: LINUX
10/25/2017 7:28:22 PM> Mount [userdata] successfully PartType: LINUX
10/25/2017 7:28:30 PM> Error reading at address: 0000E9401000 ... Retry #1
10/25/2017 7:28:57 PM>
10/25/2017 7:28:57 PM> Looking for EasyJTAG box...
10/25/2017 7:28:57 PM> EasyJTAG API ver. 2008
10/25/2017 7:28:57 PM> Setting IO Levels to 2.8V
10/25/2017 7:28:57 PM> Setting frequence to 7 Mhz
10/25/2017 7:28:57 PM> HiPower mode is OFF
10/25/2017 7:28:58 PM> OpenUSB returned = 0
10/25/2017 7:28:58 PM> Power Controller returned = 0
10/25/2017 7:28:59 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:28:59 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:28:59 PM> HiPower mode is OFF
10/25/2017 7:28:59 PM> Frequence: 7 Mhz
10/25/2017 7:28:59 PM> CMD Pullup Level: 2103 mV
10/25/2017 7:28:59 PM> CMD Active Level: 2609 mV
10/25/2017 7:28:59 PM> eMMC Init returned = 0
10/25/2017 7:28:59 PM> EMMC Device Information :
10/25/2017 7:28:59 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:28:59 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:28:59 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:28:59 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:28:59 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:28:59 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:28:59 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:28:59 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:28:59 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:28:59 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:28:59 PM> EMMC Permanent Write Protection: No
10/25/2017 7:28:59 PM> EMMC Temporary Write Protection: No
10/25/2017 7:28:59 PM> Extended CSD Information :
10/25/2017 7:28:59 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:28:59 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:28:59 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:28:59 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:28:59 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:28:59 PM> Device supports partitioning features
10/25/2017 7:28:59 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:28:59 PM> Device can have extended partitions attribute
10/25/2017 7:28:59 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:28:59 PM> Backup saved: H8G4u_23C44911_20171025_192859.extcsd
10/25/2017 7:28:59 PM> EMMC Init completed.
10/25/2017 7:28:59 PM> Get firmware version
10/25/2017 7:29:02 PM> Brand = samsung
10/25/2017 7:29:02 PM> Model = SM-G532G
10/25/2017 7:29:02 PM> Phone platform = mt6737t
10/25/2017 7:29:02 PM> CPU Abi = armeabi-v7a
10/25/2017 7:29:02 PM> Mediatek platform = MT6737T
10/25/2017 7:29:02 PM> Android release = 6.0.1
10/25/2017 7:29:02 PM> Firmware version = MMB29T.G532GDXU1APJ3
10/25/2017 7:29:02 PM> Firmware date = Tue Oct 11 21:19:11 KST 2016
10/25/2017 7:29:13 PM>
10/25/2017 7:29:13 PM> Looking for EasyJTAG box...
10/25/2017 7:29:13 PM> EasyJTAG API ver. 2008
10/25/2017 7:29:13 PM> Setting IO Levels to 2.8V
10/25/2017 7:29:13 PM> Setting frequence to 7 Mhz
10/25/2017 7:29:13 PM> HiPower mode is OFF
10/25/2017 7:29:14 PM> OpenUSB returned = 0
10/25/2017 7:29:14 PM> Power Controller returned = 0
10/25/2017 7:29:15 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:29:15 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:29:15 PM> HiPower mode is OFF
10/25/2017 7:29:16 PM> Frequence: 7 Mhz
10/25/2017 7:29:16 PM> CMD Pullup Level: 2103 mV
10/25/2017 7:29:16 PM> CMD Active Level: 2743 mV
10/25/2017 7:29:16 PM> eMMC Init returned = 0
10/25/2017 7:29:16 PM> EMMC Device Information :
10/25/2017 7:29:16 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:29:16 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:29:16 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:29:16 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:29:16 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:29:16 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:29:16 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:29:16 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:29:16 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:29:16 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:29:16 PM> EMMC Permanent Write Protection: No
10/25/2017 7:29:16 PM> EMMC Temporary Write Protection: No
10/25/2017 7:29:16 PM> Extended CSD Information :
10/25/2017 7:29:16 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:29:16 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:29:16 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:29:16 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:29:16 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:29:16 PM> Device supports partitioning features
10/25/2017 7:29:16 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:29:16 PM> Device can have extended partitions attribute
10/25/2017 7:29:16 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:29:16 PM> Backup saved: H8G4u_23C44911_20171025_192916.extcsd
10/25/2017 7:29:16 PM> EMMC Init completed.
10/25/2017 7:29:16 PM> Opening file: C:\Users\JOHNOROO37\Desktop\JTAG ALL\SM-G532G J2 ALL\GRANDPPLTE_CIS_SER.pit
10/25/2017 7:29:16 PM> Pit: GRANDPPLTE_CIS_SER.pit
10/25/2017 7:29:16 PM> Entry count: 34
10/25/2017 7:29:16 PM> The size of the last section has been updated
10/25/2017 7:29:27 PM> Selected file: C:\Users\JOHNOROO37\Desktop\JTAG ALL\SM-G532G J2 ALL\BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_u ser_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:29:27 PM> BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/25/2017 7:29:27 PM> The list of files in the firmware:
10/25/2017 7:29:27 PM> preloader.img
10/25/2017 7:29:27 PM> lk.bin
10/25/2017 7:29:27 PM> param.bin
10/25/2017 7:29:27 PM> trustzone.bin
10/25/2017 7:29:27 PM> efuse.img
10/25/2017 7:29:29 PM> Looking for EasyJTAG box...
10/25/2017 7:29:29 PM> EasyJTAG API ver. 2008
10/25/2017 7:29:29 PM> Setting IO Levels to 2.8V
10/25/2017 7:29:29 PM> Setting frequence to 7 Mhz
10/25/2017 7:29:29 PM> HiPower mode is OFF
10/25/2017 7:29:30 PM> OpenUSB returned = 0
10/25/2017 7:29:30 PM> Power Controller returned = 0
10/25/2017 7:29:31 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:29:31 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:29:31 PM> HiPower mode is OFF
10/25/2017 7:29:32 PM> Frequence: 7 Mhz
10/25/2017 7:29:32 PM> CMD Pullup Level: 2093 mV
10/25/2017 7:29:32 PM> CMD Active Level: 2619 mV
10/25/2017 7:29:32 PM> eMMC Init returned = 0
10/25/2017 7:29:32 PM> EMMC Device Information :
10/25/2017 7:29:32 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:29:32 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:29:32 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:29:32 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:29:32 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:29:32 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:29:32 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:29:32 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:29:32 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:29:32 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:29:32 PM> EMMC Permanent Write Protection: No
10/25/2017 7:29:32 PM> EMMC Temporary Write Protection: No
10/25/2017 7:29:32 PM> Extended CSD Information :
10/25/2017 7:29:32 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:29:32 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:29:32 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:29:32 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:29:32 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:29:32 PM> Device supports partitioning features
10/25/2017 7:29:32 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:29:32 PM> Device can have extended partitions attribute
10/25/2017 7:29:32 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:29:32 PM> Backup saved: H8G4u_23C44911_20171025_192932.extcsd
10/25/2017 7:29:32 PM> EMMC Init completed.
10/25/2017 7:29:32 PM> Operation: Write by vendor (Samsung)
10/25/2017 7:29:32 PM> Creating GPT-partitioninig
10/25/2017 7:29:32 PM> Writing PIT at address: 000000004400
10/25/2017 7:29:32 PM> GPT-partitioning done
10/25/2017 7:29:32 PM> Unpacking file: preloader.img
10/25/2017 7:29:32 PM> Unpacking file: lk.bin
10/25/2017 7:29:32 PM> Unpacking file: efuse.img
10/25/2017 7:29:32 PM> Unpacking file: trustzone.bin
10/25/2017 7:29:32 PM> Unpacking file: param.bin
10/25/2017 7:29:32 PM> Partition name: BOOTLOADER
10/25/2017 7:29:32 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/25/2017 7:29:32 PM> eMMC switching to ROM2
10/25/2017 7:29:32 PM> Erasing partition...
10/25/2017 7:29:50 PM> Writing partition...
10/25/2017 7:29:51 PM> Done writing partition. Write speed: 184.48 Kb/s
10/25/2017 7:29:51 PM> Partition name: LK
10/25/2017 7:29:51 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/25/2017 7:29:51 PM> eMMC switching to ROM1
10/25/2017 7:29:51 PM> Erasing partition...
10/25/2017 7:29:54 PM> Writing partition...
10/25/2017 7:29:55 PM> Done writing partition. Write speed: 386.03 Kb/s
10/25/2017 7:29:55 PM> Partition name: EFUSE
10/25/2017 7:29:55 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/25/2017 7:29:55 PM> eMMC switching to ROM1
10/25/2017 7:29:56 PM> Erasing partition...
10/25/2017 7:29:56 PM> Writing partition...
10/25/2017 7:29:56 PM> Error writing at address: 000001B80000 ... Retry #1
10/25/2017 7:29:57 PM> Done writing partition. Write speed: 1.80 Kb/s
10/25/2017 7:29:57 PM> Partition name: TEE1
10/25/2017 7:29:57 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/25/2017 7:29:57 PM> eMMC switching to ROM1
10/25/2017 7:29:57 PM> Erasing partition...
10/25/2017 7:29:58 PM> Writing partition...
10/25/2017 7:29:59 PM> Done writing partition. Write speed: 678.62 Kb/s
10/25/2017 7:29:59 PM> Partition name: PARAM
10/25/2017 7:29:59 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/25/2017 7:29:59 PM> eMMC switching to ROM1
10/25/2017 7:29:59 PM> Erasing partition...
10/25/2017 7:30:00 PM> Writing partition...
10/25/2017 7:30:01 PM> Done writing partition. Write speed: 717.36 Kb/s
10/25/2017 7:30:01 PM> All done
10/25/2017 7:31:48 PM> Selected file: C:\Users\JOHNOROO37\Desktop\JTAG ALL\SM-G532G J2 ALL\BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_u ser_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:31:48 PM> BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/25/2017 7:31:48 PM> The list of files in the firmware:
10/25/2017 7:31:48 PM> preloader.img
10/25/2017 7:31:48 PM> lk.bin
10/25/2017 7:31:48 PM> param.bin
10/25/2017 7:31:48 PM> trustzone.bin
10/25/2017 7:31:48 PM> efuse.img
10/25/2017 7:31:48 PM> File: preloader.img - skip, as it has already been added
10/25/2017 7:31:48 PM> File: lk.bin - skip, as it has already been added
10/25/2017 7:31:48 PM> File: efuse.img - skip, as it has already been added
10/25/2017 7:31:48 PM> File: trustzone.bin - skip, as it has already been added
10/25/2017 7:31:48 PM> File: param.bin - skip, as it has already been added
10/25/2017 7:32:08 PM> Selected file: C:\Users\JOHNOROO37\Desktop\JTAG ALL\SM-G532G J2 ALL\BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_u ser_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:32:08 PM> Error: This file already exists - BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/25/2017 7:32:50 PM> eMMC_tool Suite ver. 1.4.8.0
10/25/2017 7:32:50 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015)
10/25/2017 7:32:50 PM> Looking for EasyJTAG box...
10/25/2017 7:32:50 PM> EasyJTAG API ver. 2008
10/25/2017 7:32:50 PM> Setting IO Levels to 2.8V
10/25/2017 7:32:50 PM> Setting frequence to 7 Mhz
10/25/2017 7:32:50 PM> HiPower mode is OFF
10/25/2017 7:32:51 PM> OpenUSB returned = 0
10/25/2017 7:32:51 PM> Power Controller returned = 0
10/25/2017 7:32:52 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:32:58 PM> Card Serial = AADF-497C
10/25/2017 7:32:58 PM> CardAttr = 3B7D95000080318065B0831148C883009000
10/25/2017 7:32:58 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:33:30 PM> Looking for EasyJTAG box...
10/25/2017 7:33:31 PM> EasyJTAG API ver. 2008
10/25/2017 7:33:31 PM> Setting IO Levels to 2.8V
10/25/2017 7:33:31 PM> Setting frequence to 14 Mhz
10/25/2017 7:33:31 PM> HiPower mode is OFF
10/25/2017 7:33:32 PM> OpenUSB returned = 0
10/25/2017 7:33:32 PM> Power Controller returned = 0
10/25/2017 7:33:33 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:33:33 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:33:33 PM> HiPower mode is OFF
10/25/2017 7:33:33 PM> Frequence: 14 Mhz
10/25/2017 7:33:33 PM> Error: First select the Pit-file
10/25/2017 7:33:33 PM> CMD Pullup Level: 2093 mV
10/25/2017 7:33:33 PM> CMD Active Level: 2619 mV
10/25/2017 7:33:33 PM> eMMC Init returned = 0
10/25/2017 7:33:33 PM> EMMC Device Information :
10/25/2017 7:33:33 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:33:33 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:33:33 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:33:33 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:33:33 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:33:33 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:33:33 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:33:33 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:33:33 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:33:33 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:33:33 PM> EMMC Permanent Write Protection: No
10/25/2017 7:33:33 PM> EMMC Temporary Write Protection: No
10/25/2017 7:33:33 PM> Extended CSD Information :
10/25/2017 7:33:33 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:33:33 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:33:33 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:33:33 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:33:33 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:33:33 PM> Device supports partitioning features
10/25/2017 7:33:33 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:33:33 PM> Device can have extended partitions attribute
10/25/2017 7:33:33 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:33:33 PM> Backup saved: H8G4u_23C44911_20171025_193333.extcsd
10/25/2017 7:33:33 PM> EMMC Init completed.
10/25/2017 7:33:33 PM> Opening file: C:\Users\JOHNOROO37\Desktop\JTAG ALL\SM-G532G J2 ALL\GRANDPPLTE_CIS_SER.pit
10/25/2017 7:33:33 PM> Pit: GRANDPPLTE_CIS_SER.pit
10/25/2017 7:33:33 PM> Entry count: 34
10/25/2017 7:33:33 PM> The size of the last section has been updated
10/25/2017 7:33:37 PM> Selected file: C:\Users\JOHNOROO37\Desktop\JTAG ALL\SM-G532G J2 ALL\BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_u ser_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:33:37 PM> BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/25/2017 7:33:37 PM> The list of files in the firmware:
10/25/2017 7:33:37 PM> preloader.img
10/25/2017 7:33:37 PM> lk.bin
10/25/2017 7:33:37 PM> param.bin
10/25/2017 7:33:37 PM> trustzone.bin
10/25/2017 7:33:37 PM> efuse.img
10/25/2017 7:33:41 PM> Looking for EasyJTAG box...
10/25/2017 7:33:41 PM> EasyJTAG API ver. 2008
10/25/2017 7:33:41 PM> Setting IO Levels to 2.8V
10/25/2017 7:33:41 PM> Setting frequence to 14 Mhz
10/25/2017 7:33:41 PM> HiPower mode is OFF
10/25/2017 7:33:42 PM> OpenUSB returned = 0
10/25/2017 7:33:42 PM> Power Controller returned = 0
10/25/2017 7:33:43 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:33:43 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:33:43 PM> HiPower mode is OFF
10/25/2017 7:33:43 PM> Frequence: 14 Mhz
10/25/2017 7:33:43 PM> CMD Pullup Level: 2103 mV
10/25/2017 7:33:43 PM> CMD Active Level: 2609 mV
10/25/2017 7:33:43 PM> eMMC Init returned = 0
10/25/2017 7:33:43 PM> EMMC Device Information :
10/25/2017 7:33:43 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:33:43 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:33:43 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:33:43 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:33:43 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:33:43 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:33:43 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:33:43 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:33:43 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:33:43 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:33:43 PM> EMMC Permanent Write Protection: No
10/25/2017 7:33:43 PM> EMMC Temporary Write Protection: No
10/25/2017 7:33:43 PM> Extended CSD Information :
10/25/2017 7:33:43 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:33:43 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:33:43 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:33:43 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:33:43 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:33:43 PM> Device supports partitioning features
10/25/2017 7:33:43 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:33:43 PM> Device can have extended partitions attribute
10/25/2017 7:33:43 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:33:43 PM> Backup saved: H8G4u_23C44911_20171025_193343.extcsd
10/25/2017 7:33:43 PM> EMMC Init completed.
10/25/2017 7:33:43 PM> Operation: Write by vendor (Samsung)
10/25/2017 7:33:43 PM> Creating GPT-partitioninig
10/25/2017 7:33:43 PM> Error writing at address: 000000000000 ... Retry #1
10/25/2017 7:33:44 PM> Writing PIT at address: 000000004400
10/25/2017 7:33:44 PM> Error writing at address: 000000004400 ... Retry #1
10/25/2017 7:33:44 PM> GPT-partitioning done
10/25/2017 7:33:44 PM> Unpacking file: preloader.img
10/25/2017 7:33:44 PM> Unpacking file: lk.bin
10/25/2017 7:33:44 PM> Unpacking file: efuse.img
10/25/2017 7:33:44 PM> Unpacking file: trustzone.bin
10/25/2017 7:33:44 PM> Unpacking file: param.bin
10/25/2017 7:33:44 PM> Partition name: BOOTLOADER
10/25/2017 7:33:44 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/25/2017 7:33:44 PM> eMMC switching to ROM2
10/25/2017 7:33:44 PM> Erasing partition...
10/25/2017 7:33:44 PM> Error erasing at address: 000000000000 ... Retry #1
10/25/2017 7:33:50 PM> Error erasing at address: 000000180000 ... Retry #1
10/25/2017 7:33:52 PM>
10/25/2017 7:33:52 PM> Stopped by User request...
10/25/2017 7:33:58 PM> Looking for EasyJTAG box...
10/25/2017 7:33:58 PM> EasyJTAG API ver. 2008
10/25/2017 7:33:58 PM> Setting IO Levels to 2.8V
10/25/2017 7:33:58 PM> Setting frequence to 14 Mhz
10/25/2017 7:33:58 PM> HiPower mode is OFF
10/25/2017 7:33:59 PM> OpenUSB returned = 0
10/25/2017 7:33:59 PM> Power Controller returned = 0
10/25/2017 7:34:00 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:34:00 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:34:00 PM> HiPower mode is OFF
10/25/2017 7:34:00 PM> Frequence: 14 Mhz
10/25/2017 7:34:00 PM> CMD Pullup Level: 1990 mV
10/25/2017 7:34:00 PM> CMD Active Level: 2371 mV
10/25/2017 7:34:00 PM> eMMC Init returned = -1
10/25/2017 7:34:00 PM> Can't init device. Reason: CMD Timeout Error
10/25/2017 7:34:08 PM> Looking for EasyJTAG box...
10/25/2017 7:34:08 PM> EasyJTAG API ver. 2008
10/25/2017 7:34:08 PM> Setting IO Levels to 2.8V
10/25/2017 7:34:08 PM> Setting frequence to 14 Mhz
10/25/2017 7:34:08 PM> HiPower mode is OFF
10/25/2017 7:34:10 PM> OpenUSB returned = 0
10/25/2017 7:34:10 PM> Power Controller returned = 0
10/25/2017 7:34:11 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:34:11 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:34:11 PM> HiPower mode is OFF
10/25/2017 7:34:11 PM> Frequence: 14 Mhz
10/25/2017 7:34:11 PM> CMD Pullup Level: 2093 mV
10/25/2017 7:34:11 PM> CMD Active Level: 2619 mV
10/25/2017 7:34:11 PM> eMMC Init returned = 0
10/25/2017 7:34:11 PM> EMMC Device Information :
10/25/2017 7:34:11 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:34:11 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:34:11 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:34:11 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:34:11 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:34:11 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:34:11 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:34:11 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:34:11 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:34:11 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:34:11 PM> EMMC Permanent Write Protection: No
10/25/2017 7:34:11 PM> EMMC Temporary Write Protection: No
10/25/2017 7:34:11 PM> Extended CSD Information :
10/25/2017 7:34:11 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:34:11 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:34:11 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:34:11 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:34:11 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:34:11 PM> Device supports partitioning features
10/25/2017 7:34:11 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:34:11 PM> Device can have extended partitions attribute
10/25/2017 7:34:11 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:34:11 PM> Backup saved: H8G4u_23C44911_20171025_193411.extcsd
10/25/2017 7:34:11 PM> EMMC Init completed.
10/25/2017 7:34:11 PM> Operation: Write by vendor (Samsung)
10/25/2017 7:34:11 PM> Creating GPT-partitioninig
10/25/2017 7:34:11 PM> Writing PIT at address: 000000004400
10/25/2017 7:34:11 PM> GPT-partitioning done
10/25/2017 7:34:11 PM> Unpacking file: preloader.img
10/25/2017 7:34:11 PM> Unpacking file: lk.bin
10/25/2017 7:34:11 PM> Unpacking file: efuse.img
10/25/2017 7:34:11 PM> Unpacking file: trustzone.bin
10/25/2017 7:34:11 PM> Unpacking file: param.bin
10/25/2017 7:34:11 PM> Partition name: BOOTLOADER
10/25/2017 7:34:11 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/25/2017 7:34:11 PM> eMMC switching to ROM2
10/25/2017 7:34:12 PM> Erasing partition...
10/25/2017 7:34:25 PM> Writing partition...
10/25/2017 7:34:26 PM> Done writing partition. Write speed: 193.72 Kb/s
10/25/2017 7:34:26 PM> Partition name: LK
10/25/2017 7:34:26 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/25/2017 7:34:26 PM> eMMC switching to ROM1
10/25/2017 7:34:26 PM> Erasing partition...
10/25/2017 7:34:28 PM> Writing partition...
10/25/2017 7:34:29 PM> Done writing partition. Write speed: 414.70 Kb/s
10/25/2017 7:34:29 PM> Partition name: EFUSE
10/25/2017 7:34:29 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/25/2017 7:34:29 PM> eMMC switching to ROM1
10/25/2017 7:34:30 PM> Erasing partition...
10/25/2017 7:34:30 PM> Writing partition...
10/25/2017 7:34:30 PM> Error writing at address: 000001B80000 ... Retry #1
10/25/2017 7:34:31 PM> Done writing partition. Write speed: 1.81 Kb/s
10/25/2017 7:34:31 PM> Partition name: TEE1
10/25/2017 7:34:31 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/25/2017 7:34:31 PM> eMMC switching to ROM1
10/25/2017 7:34:31 PM> Erasing partition...
10/25/2017 7:34:32 PM> Writing partition...
10/25/2017 7:34:32 PM> Done writing partition. Write speed: 748.00 Kb/s
10/25/2017 7:34:32 PM> Partition name: PARAM
10/25/2017 7:34:32 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/25/2017 7:34:32 PM> eMMC switching to ROM1
10/25/2017 7:34:33 PM> Erasing partition...
10/25/2017 7:34:34 PM> Writing partition...
10/25/2017 7:34:35 PM> Done writing partition. Write speed: 760.16 Kb/s
10/25/2017 7:34:35 PM> All done
10/25/2017 7:35:04 PM> Looking for EasyJTAG box...
10/25/2017 7:35:04 PM> EasyJTAG API ver. 2008
10/25/2017 7:35:04 PM> Setting IO Levels to 2.8V
10/25/2017 7:35:04 PM> Setting frequence to 14 Mhz
10/25/2017 7:35:04 PM> HiPower mode is OFF
10/25/2017 7:35:05 PM> OpenUSB returned = 0
10/25/2017 7:35:05 PM> Power Controller returned = 0
10/25/2017 7:35:06 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:35:06 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:35:06 PM> HiPower mode is OFF
10/25/2017 7:35:06 PM> Frequence: 14 Mhz
10/25/2017 7:35:06 PM> CMD Pullup Level: 2103 mV
10/25/2017 7:35:06 PM> CMD Active Level: 2619 mV
10/25/2017 7:35:06 PM> eMMC Init returned = 0
10/25/2017 7:35:06 PM> EMMC Device Information :
10/25/2017 7:35:06 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:35:06 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:35:06 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:35:06 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:35:06 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:35:06 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:35:06 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:35:06 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:35:06 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:35:06 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:35:06 PM> EMMC Permanent Write Protection: No
10/25/2017 7:35:06 PM> EMMC Temporary Write Protection: No
10/25/2017 7:35:06 PM> Extended CSD Information :
10/25/2017 7:35:06 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:35:06 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:35:06 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:35:07 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:35:07 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:35:07 PM> Device supports partitioning features
10/25/2017 7:35:07 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:35:07 PM> Device can have extended partitions attribute
10/25/2017 7:35:07 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:35:07 PM> Backup saved: H8G4u_23C44911_20171025_193507.extcsd
10/25/2017 7:35:07 PM> EMMC Init completed.
10/25/2017 7:35:07 PM> Scanning soft partitions
10/25/2017 7:35:07 PM> GPT header is found and is valid
10/25/2017 7:35:07 PM> Partition: bota0, [000000400000 - 000000800000], size: 000000400000
10/25/2017 7:35:07 PM> Partition: nvram, [000000800000 - 000001000000], size: 000000800000
10/25/2017 7:35:07 PM> Partition: lk, [000001000000 - 000001200000], size: 000000200000
10/25/2017 7:35:07 PM> Partition: bota1, [000001200000 - 000001400000], size: 000000200000
10/25/2017 7:35:07 PM> Partition: secro, [000001400000 - 000001B00000], size: 000000700000
10/25/2017 7:35:07 PM> Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000
10/25/2017 7:35:07 PM> Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000
10/25/2017 7:35:07 PM> Partition: tee1, [000001C00000 - 000002200000], size: 000000600000
10/25/2017 7:35:07 PM> Partition: bota2, [000002200000 - 000002800000], size: 000000600000
10/25/2017 7:35:07 PM> Partition: efs, [000002800000 - 000003000000], size: 000000800000
10/25/2017 7:35:07 PM> Partition: nvdata, [000003000000 - 000005000000], size: 000002000000
10/25/2017 7:35:07 PM> Partition: param, [000005000000 - 000005800000], size: 000000800000
10/25/2017 7:35:07 PM> Partition: recovery, [000005800000 - 000006800000], size: 000001000000
10/25/2017 7:35:07 PM> Partition: boot, [000006800000 - 000007800000], size: 000001000000
10/25/2017 7:35:07 PM> Partition: md1img, [000007800000 - 000009800000], size: 000002000000
10/25/2017 7:35:07 PM> Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000
10/25/2017 7:35:07 PM> Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000
10/25/2017 7:35:07 PM> Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000
10/25/2017 7:35:07 PM> Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000
10/25/2017 7:35:07 PM> Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000
10/25/2017 7:35:07 PM> Partition: persistent, [00000AA80000 - 00000AB00000], size: 000000080000
10/25/2017 7:35:07 PM> Partition: steady, [00000AB00000 - 00000AC00000], size: 000000100000
10/25/2017 7:35:07 PM> Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000
10/25/2017 7:35:07 PM> Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000
10/25/2017 7:35:07 PM> Partition: reserve2, [00000BC00000 - 00000C000000], size: 000000400000
10/25/2017 7:35:07 PM> Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000
10/25/2017 7:35:07 PM> Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000
10/25/2017 7:35:07 PM> Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000
10/25/2017 7:35:07 PM> Partition: userdata, [0000E9400000 - 0001D2000000], size: 0000E8C00000
10/25/2017 7:35:07 PM> GPT header successfully parsed
10/25/2017 7:35:07 PM> Get firmware version
10/25/2017 7:35:10 PM> Brand = samsung
10/25/2017 7:35:10 PM> Model = SM-G532G
10/25/2017 7:35:10 PM> Phone platform = mt6737t
10/25/2017 7:35:10 PM> CPU Abi = armeabi-v7a
10/25/2017 7:35:10 PM> Mediatek platform = MT6737T
10/25/2017 7:35:10 PM> Android release = 6.0.1
10/25/2017 7:35:10 PM> Firmware version = MMB29T.G532GDXU1APJ3
10/25/2017 7:35:10 PM> Firmware date = Tue Oct 11 21:19:11 KST 2016
10/25/2017 7:37:40 PM> Selected file: \\Johnoroo37-dell\c\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SAMSUNG ALL\SM-G532G J2 ALL\SM-G532G_G532GDXU1AQF3_G532GDXU1AQA3_G532GOLB1AQF2__4 FILES_6.0.1\AP_G532GDXU1AQF3_CL11653995_QB14032311 _REV00_user_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:37:46 PM>
10/25/2017 7:37:46 PM> AP_G532GDXU1AQF3_CL11653995_QB14032311_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/25/2017 7:37:46 PM> The list of files in the firmware:
10/25/2017 7:37:46 PM> boot.img
10/25/2017 7:37:46 PM> recovery.img
10/25/2017 7:37:47 PM> system.img
10/25/2017 7:37:47 PM> secro.img
10/25/2017 7:37:47 PM> userdata.img
10/25/2017 7:38:01 PM> Selected file: \\Johnoroo37-dell\c\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SAMSUNG ALL\SM-G532G J2 ALL\SM-G532G_G532GDXU1AQF3_G532GDXU1AQA3_G532GOLB1AQF2__4 FILES_6.0.1\CP_G532GDXU1AQA3_CL10452964_QB12393484 _REV00_user_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:38:01 PM> CP_G532GDXU1AQA3_CL10452964_QB12393484_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/25/2017 7:38:01 PM> The list of files in the firmware:
10/25/2017 7:38:01 PM> md1rom.img
10/25/2017 7:38:01 PM> md1dsp.img
10/25/2017 7:38:06 PM> Selected file: \\Johnoroo37-dell\c\Users\JOHNOROO37\Desktop\ALL PHONE FIRMWARE\SAMSUNG ALL\SM-G532G J2 ALL\SM-G532G_G532GDXU1AQF3_G532GDXU1AQA3_G532GOLB1AQF2__4 FILES_6.0.1\HOME_CSC_OLB_G532GOLB1AQF2_CL11653995_ QB13939435_REV00_user_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:38:06 PM> HOME_CSC_OLB_G532GOLB1AQF2_CL11653995_QB13939435_R EV00_user_low_ship_MULTI_CERT.tar.md5
10/25/2017 7:38:06 PM> The list of files in the firmware:
10/25/2017 7:38:06 PM> cache.img
10/25/2017 7:38:06 PM> hidden.img
10/25/2017 7:38:06 PM> meta-data/
10/25/2017 7:38:06 PM> meta-data/download-list.txt
10/25/2017 7:38:09 PM> Looking for EasyJTAG box...
10/25/2017 7:38:09 PM> EasyJTAG API ver. 2008
10/25/2017 7:38:09 PM> Setting IO Levels to 2.8V
10/25/2017 7:38:09 PM> Setting frequence to 14 Mhz
10/25/2017 7:38:09 PM> HiPower mode is OFF
10/25/2017 7:38:10 PM> OpenUSB returned = 0
10/25/2017 7:38:10 PM> Power Controller returned = 0
10/25/2017 7:38:11 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:38:11 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:38:11 PM> HiPower mode is OFF
10/25/2017 7:38:11 PM> Frequence: 14 Mhz
10/25/2017 7:38:11 PM> CMD Pullup Level: 2103 mV
10/25/2017 7:38:11 PM> CMD Active Level: 2619 mV
10/25/2017 7:38:11 PM> eMMC Init returned = 0
10/25/2017 7:38:11 PM> EMMC Device Information :
10/25/2017 7:38:11 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:38:11 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:38:11 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:38:11 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:38:11 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:38:11 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:38:11 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:38:11 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:38:11 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:38:11 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:38:11 PM> EMMC Permanent Write Protection: No
10/25/2017 7:38:11 PM> EMMC Temporary Write Protection: No
10/25/2017 7:38:11 PM> Extended CSD Information :
10/25/2017 7:38:11 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:38:11 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:38:11 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:38:11 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:38:11 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:38:11 PM> Device supports partitioning features
10/25/2017 7:38:11 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:38:11 PM> Device can have extended partitions attribute
10/25/2017 7:38:11 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:38:11 PM> Backup saved: H8G4u_23C44911_20171025_193811.extcsd
10/25/2017 7:38:11 PM> EMMC Init completed.
10/25/2017 7:38:11 PM> Scanning soft partitions
10/25/2017 7:38:11 PM> GPT header is found and is valid
10/25/2017 7:38:11 PM> Partition: bota0, [000000400000 - 000000800000], size: 000000400000
10/25/2017 7:38:11 PM> Partition: nvram, [000000800000 - 000001000000], size: 000000800000
10/25/2017 7:38:11 PM> Partition: lk, [000001000000 - 000001200000], size: 000000200000
10/25/2017 7:38:11 PM> Partition: bota1, [000001200000 - 000001400000], size: 000000200000
10/25/2017 7:38:11 PM> Partition: secro, [000001400000 - 000001B00000], size: 000000700000
10/25/2017 7:38:11 PM> Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000
10/25/2017 7:38:11 PM> Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000
10/25/2017 7:38:11 PM> Partition: tee1, [000001C00000 - 000002200000], size: 000000600000
10/25/2017 7:38:11 PM> Partition: bota2, [000002200000 - 000002800000], size: 000000600000
10/25/2017 7:38:11 PM> Partition: efs, [000002800000 - 000003000000], size: 000000800000
10/25/2017 7:38:11 PM> Partition: nvdata, [000003000000 - 000005000000], size: 000002000000
10/25/2017 7:38:11 PM> Partition: param, [000005000000 - 000005800000], size: 000000800000
10/25/2017 7:38:11 PM> Partition: recovery, [000005800000 - 000006800000], size: 000001000000
10/25/2017 7:38:11 PM> Partition: boot, [000006800000 - 000007800000], size: 000001000000
10/25/2017 7:38:11 PM> Partition: md1img, [000007800000 - 000009800000], size: 000002000000
10/25/2017 7:38:11 PM> Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000
10/25/2017 7:38:11 PM> Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000
10/25/2017 7:38:11 PM> Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000
10/25/2017 7:38:11 PM> Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000
10/25/2017 7:38:11 PM> Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000
10/25/2017 7:38:11 PM> Partition: persistent, [00000AA80000 - 00000AB00000], size: 000000080000
10/25/2017 7:38:11 PM> Partition: steady, [00000AB00000 - 00000AC00000], size: 000000100000
10/25/2017 7:38:11 PM> Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000
10/25/2017 7:38:11 PM> Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000
10/25/2017 7:38:11 PM> Partition: reserve2, [00000BC00000 - 00000C000000], size: 000000400000
10/25/2017 7:38:11 PM> Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000
10/25/2017 7:38:11 PM> Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000
10/25/2017 7:38:11 PM> Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000
10/25/2017 7:38:11 PM> Partition: userdata, [0000E9400000 - 0001D2000000], size: 0000E8C00000
10/25/2017 7:38:11 PM> GPT header successfully parsed
10/25/2017 7:38:11 PM> Get firmware version
10/25/2017 7:38:12 PM>
10/25/2017 7:38:14 PM> Brand = samsung
10/25/2017 7:38:14 PM> Model = SM-G532G
10/25/2017 7:38:14 PM> Phone platform = mt6737t
10/25/2017 7:38:14 PM> CPU Abi = armeabi-v7a
10/25/2017 7:38:14 PM> Mediatek platform = MT6737T
10/25/2017 7:38:14 PM> Android release = 6.0.1
10/25/2017 7:38:14 PM> Firmware version = MMB29T.G532GDXU1APJ3
10/25/2017 7:38:14 PM> Firmware date = Tue Oct 11 21:19:11 KST 2016
10/25/2017 7:38:18 PM>
10/25/2017 7:38:18 PM> Looking for EasyJTAG box...
10/25/2017 7:38:18 PM> EasyJTAG API ver. 2008
10/25/2017 7:38:18 PM> Setting IO Levels to 2.8V
10/25/2017 7:38:18 PM> Setting frequence to 14 Mhz
10/25/2017 7:38:18 PM> HiPower mode is OFF
10/25/2017 7:38:19 PM> OpenUSB returned = 0
10/25/2017 7:38:19 PM> Power Controller returned = 0
10/25/2017 7:38:20 PM> EasyJTAG Box Serial = 1200D0035CA63064
10/25/2017 7:38:20 PM> EasyJTAG Box Firmware = 01.60
10/25/2017 7:38:20 PM> HiPower mode is OFF
10/25/2017 7:38:20 PM> Frequence: 14 Mhz
10/25/2017 7:38:20 PM> CMD Pullup Level: 2093 mV
10/25/2017 7:38:20 PM> CMD Active Level: 2598 mV
10/25/2017 7:38:20 PM> eMMC Init returned = 0
10/25/2017 7:38:20 PM> EMMC Device Information :
10/25/2017 7:38:20 PM> EMMC CID: 90014A4838473475920123C4491164C0
10/25/2017 7:38:20 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
10/25/2017 7:38:20 PM> EMMC Manufacture Name: SKHYNIX
10/25/2017 7:38:20 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
10/25/2017 7:38:20 PM> EMMC Manufacture Date: 6/2017 , Rev: 01
10/25/2017 7:38:20 PM> EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01
10/25/2017 7:38:20 PM> EMMC NAME (HEX): 483847347592
10/25/2017 7:38:20 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/25/2017 7:38:20 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/25/2017 7:38:20 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/25/2017 7:38:20 PM> EMMC Permanent Write Protection: No
10/25/2017 7:38:20 PM> EMMC Temporary Write Protection: No
10/25/2017 7:38:20 PM> Extended CSD Information :
10/25/2017 7:38:20 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/25/2017 7:38:20 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/25/2017 7:38:20 PM> Boot Bus Config: 0x00 , width 1bit
10/25/2017 7:38:20 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/25/2017 7:38:20 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/25/2017 7:38:20 PM> Device supports partitioning features
10/25/2017 7:38:20 PM> Device can have enhanced technological features in partitions and user data area
10/25/2017 7:38:20 PM> Device can have extended partitions attribute
10/25/2017 7:38:20 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/25/2017 7:38:20 PM> Backup saved: H8G4u_23C44911_20171025_193820.extcsd
10/25/2017 7:38:20 PM> EMMC Init completed.
10/25/2017 7:38:20 PM> Operation: Write by vendor (Samsung)
10/25/2017 7:38:20 PM> Creating GPT-partitioninig
10/25/2017 7:38:21 PM> Writing PIT at address: 000000004400
10/25/2017 7:38:21 PM> GPT-partitioning done
10/25/2017 7:38:21 PM> Unpacking file: preloader.img
10/25/2017 7:38:21 PM> Unpacking file: lk.bin
10/25/2017 7:38:21 PM> Unpacking file: secro.img
10/25/2017 7:38:21 PM> Unpacking file: efuse.img
10/25/2017 7:38:21 PM> Unpacking file: trustzone.bin
10/25/2017 7:38:21 PM> Unpacking file: param.bin
10/25/2017 7:38:21 PM> Unpacking file: recovery.img
10/25/2017 7:38:25 PM> Unpacking file: boot.img
10/25/2017 7:38:28 PM> Unpacking file: md1rom.img
10/25/2017 7:38:31 PM> Unpacking file: md1dsp.img
10/25/2017 7:38:31 PM> Unpacking file: system.img
10/25/2017 7:52:00 PM> Unpacking file: cache.img
10/25/2017 7:52:09 PM> Unpacking file: hidden.img
10/25/2017 7:52:13 PM> Unpacking file: userdata.img
10/25/2017 7:52:28 PM>
10/25/2017 7:52:28 PM> Partition name: BOOTLOADER
10/25/2017 7:52:28 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/25/2017 7:52:28 PM> eMMC switching to ROM2
10/25/2017 7:52:28 PM> Erasing partition...
10/25/2017 7:52:28 PM> Error erasing at address: 000000000000 ... Retry #1
10/25/2017 7:52:28 PM> Error erasing at address: 000000000000 ... Retry #2
10/25/2017 7:52:28 PM> Error erasing at address: 000000000000 ... Retry #3
10/25/2017 7:52:29 PM> Too many errors. Erasing has been stopped
SO PLEASE WHATS STILL THE PROBLEM????
Old 10-30-2017, 13:30   #201 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
try to write after formate EMMC+repaire EXTCSD
Old 10-30-2017, 15:41   #202 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
Done one resistor pullout from board i checked very well and foundout one resistor not der so i just jumper it and phone enter download mode
now hv flashed and all is ok.. Including customer too
Old 10-30-2017, 15:43   #203 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
YOUR SOLUTION IS HERE BRO
The Following 2 Users Say Thank You to johnoroo37 For This Useful Post:
Old 10-30-2017, 19:30   #204 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
which resistor you found pulled out ? is it the resistor connected to 2.8v ?
I have same issue and all resistors are good
Old 10-31-2017, 06:11   #205 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
RESISTOR CLOSE TO CLK WAS PULLED OUT .
SO I JUST JUMPER IT AND EVERYTHING WENT WELL WITHOUT ERRORS
NOTE WHEN WRITING IF EFUSE WRITING SHOWS ERROR. DNT WORRY YOUR DEADBOOT IS RESURRECTED OK
SEE MY PICS BELOW
EFUSE WRITING FAILED BCOS OF THAT RESISTOR
BUT ALL IS OK
GOODLUCK
Old 11-05-2017, 05:29   #206 (permalink)
Member: 525940
Thanks Meter: 213
got new log just now after i put additional power via usb cable to the charging port
HiPower mode is OFF
EasyJTAG Box Serial = 0300F00C83528FA7
Card Serial = AA12-8E22
Changelog:
08.08.2017 (ver 1.4.8.0)
Fix: Bugs that have been found through your crash report
Fix: Saving VCF for contacts
Add: Multiple file selection for Samsung firmware
Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button)
Add: Intel vendor (for easy read/write ROM2/ROM3/GP1)
Add: "Pinouts" tab (taken from the catalog of classic software)
Add: Checker for Sony TrimArea
Add: Speed graph for "Random verify emmc"
Add: Fat16/Fat32/exFat support (Explorer)
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 2062 mV
CMD Active Level: 2660 mV
EMMC CID: 90014A483847347592010DC949235464
EMMC Manufacture Date: 5/2017 , Rev: 01
EMMC NAME: H8G4u , S/N: 0DC94923 , rev. 01
Backup saved: H8G4u_0DC94923_20171105_122822.extcsd
Brand = samsung
Model = SM-G532G
Firmware version = MMB29T.G532GDXU1APL1
Firmware date = Wed Dec 7 21:30:09 KST 2016
Old 11-05-2017, 05:32   #207 (permalink)
Member: 525940
Thanks Meter: 213
can you share here tested firmware and pit file
Old 11-07-2017, 12:12   #208 (permalink)
Member: 2189114
Thanks Meter: 69
g532g dead boot repair done still dead pls help z3x easy jtag team im 100+ repair phone but this phone not work
Old 11-07-2017, 12:12   #209 (permalink)
Member: 2189114
Thanks Meter: 69
The Following User Says Thank You to md masum mia For This Useful Post:
Old 11-11-2017, 13:26   #210 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
same problem bro
same problem bro
please help me any one .........
Page generated in 0.52747 seconds with 10 queries
