Old 11-12-2017, 12:54   #211 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
problem solved many days ago ,I didn't have time to share it
it wasn't hardware problem,just manipulation:
its very easy ,you must insert usb 1st then hold vol down + home + power,keep holding them untill phone reboots ,it will enter bootloader .that's it
Old 11-12-2017, 12:54   #212 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
Old 11-12-2017, 12:55   #213 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
Old 11-12-2017, 12:55   #214 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
don't play with system files so you don't have problems later (imei,baseband...) just write factory bootloader file and do the manipulation .
Old 11-12-2017, 12:57   #215 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
Old 11-13-2017, 12:33   #216 (permalink)
Member: 2090936
Thanks Meter: 27
i have same unit
jtag and flashing done, the phone is alive now but no signal
IMEI on system dos't match to IMEI in phone's sticker
Old 11-14-2017, 17:25   #217 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
Am happy u solved your problem too..
Enjoy
Old 11-15-2017, 10:17   #218 (permalink)
VIBINDAS_INDIA's Avatar
Member: 707582
Sonork: 100.1620432
Thanks Meter: 334
Originally Posted by ilyasrao View Post
before doing any thing first of all try to WRITE BY VENDER pit+BL from firmware repaire file and get ODIN MODE if no success
than
in this model write only ROM1 & ROM2
NOTE: never write ROM3 otherwise phone still death
accidently i wrote rom3
how can i recover my phone?
Old 11-15-2017, 11:58   #219 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
I REALLY LIKE YOUR THIS POST SIR
B.COS YOU GIVE HERE FULL DETAIL
STEP BY STEP...
VERY USEFUL POST SIR jennydahan
Old 11-15-2017, 20:41   #220 (permalink)
ganjbek's Avatar
Member: 1246378
Thanks Meter: 123
After the restoration, will the cert be different?
network will the call be?
how to get your imei back?
Old 11-17-2017, 10:50   #221 (permalink)
Member: 2362072
Thanks Meter: 46
Need G532F dead boot repair file
Pls help me G532F dead boot repair file. I have g532G dead boot repair file. But i need G532F boot repair file.
Old 11-18-2017, 09:24   #222 (permalink)
Member: 2362072
Thanks Meter: 46
Dear team pls share file.
Old 11-18-2017, 14:58   #223 (permalink)
shoaibansari.'s Avatar
Member: 1284209
Sonork: 100.1614938
Thanks Meter: 137
another dead recoverd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 188.17 Kb/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 551.19 Kb/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 23.95 Kb/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 612.42 Kb/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 559.17 Kb/s
All done
Old 11-18-2017, 16:18   #224 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
many liers in this forum
Old 11-18-2017, 19:43   #225 (permalink)
Crazy Poster
Member: 2024815
Thanks Meter: 6
use pit & bl from last firmware
The Following User Says Thank You to hiifi For This Useful Post:
Page generated in 0.18056 seconds with 10 queries
