Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-02-2019, 13:48   #421 (permalink)
Crazy Poster
Member: 850128
Thanks Meter: 4
Setting frequence to 21 Mhz
CMD Pullup Level: 1959 mV
CMD Active Level: 2227 mV
EMMC Device Information :
EMMC CID: 90014A483847347592010458B522451C
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 0458B522 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2002
EMMC ROM 1 (Main User Data) Capacity: 2097152 MB (020000000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.0 (MMC 4.0)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x00
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_0458B522_20190602_143303.extcsd
EMMC Init completed.
eMMC are unusable.
Old 06-03-2019, 00:06   #422 (permalink)
Member: 13148
Thanks Meter: 1,388
you need to replace the eMMC
Old 07-08-2019, 15:38   #423 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 845
g532g dead boot repair done
CMD Pullup Level: 2031 mV
CMD Active Level: 2330 mV
EMMC CID: 90014A4838473475920134E9853E540C
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 34E9853E , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 5/2017
   EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Backup saved: H8G4u_34E9853E_20190708_184741.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 34
The size of the last section has been updated
BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
CMD Active Level: 2320 mV
Backup saved: H8G4u_34E9853E_20190708_184754.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 330.95 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 349.75 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 70.69 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 533.01 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 510.12 KB/s
Partition EFS : formatting as EXT4. Please wait ...
Formatting completed
Partition CACHE : formatting as EXT4. Please wait ...
Partition HIDDEN : formatting as EXT4. Please wait ...
Partition USERDATA : formatting as EXT4. Please wait ...
Check BootConfig for the selected vendor
All done   time: [00:00:44:824]
Old 07-22-2019, 10:00   #424 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 845
g532g boot repair help
CMD Pullup Level: 2010 mV
CMD Active Level: 2310 mV
EMMC CID: 65646F4D204D4F5212A1000006154430
EMMC CSD: D07FFF320F59007FF6DB80001E40001C
EMMC Manufacture :  , EMMC NAME: MMOR , HEX: 4D004D4F5200 , S/N: 00000615 , rev. 0xA1
EMMC Manufacture ID: 0x65 , OEM ID: 0x6F , Device Type: Device (removable) , Date: 4/2017
   EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000)
Extended CSD rev: 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area)
Supported partition features [PARTITIONING_SUPPORT]: 0x03
Backup saved: MMOR_00000615_20190722_230436.extcsd
Warning: Maybe your emmc damaged
eMMC are unusable.
Old 07-22-2019, 10:03   #425 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 268
You need to replace new EMMC ...
The Following User Says Thank You to ChandruChiyyan For This Useful Post:
Old 07-26-2019, 02:57   #426 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 136
G532G dead boot error
hi all
i have g532g dead by flashing lower version i think now is in dead boot state
i tried many BL and no luck to got DL Mode
i have erased all emmc (backuped efs and other uselful partition) and writed ROM1&2 from support and no luck also
this my info
Z3X EasyJtag Software ver. 3.6.1.11
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 14140E12A2C07F42, ,FW Ver.: 01.63
CMD Pullup Level:1784 mV
CMD Active Level:2072 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A483847347592011E67A139156E
eMMC CSD : D02701320F5903FFFFFFFFE78A40002A
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 01/2018  Rev.0x1
eMMC NAME: H8G4u  , S/N:  510107961
eMMC NAME (HEX): 483847347520
EMMC ROM1 (Main User Data)   Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 0 times
EMMC Password Locked: No
  Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_ 510107961_20190726_0149.extcsd
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,15269854
Partition info successfully found
------ Detected 29 partitions ------
P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB
P1 (NVRAM) [0x800000 0x800000] Size: 8.0MB
P2 (LK) [0x1000000 0x200000] Size: 2.0MB
P3 (BOTA1) [0x1200000 0x200000] Size: 2.0MB
P4 (SECRO) [0x1400000 0x700000] Size: 7.0MB
P5 (SECCFG) [0x1b00000 0x80000] Size: 512.0KB
P6 (EFUSE) [0x1b80000 0x80000] Size: 512.0KB
P7 (TEE1) [0x1c00000 0x600000] Size: 6.0MB
P8 (BOTA2) [0x2200000 0x600000] Size: 6.0MB
P9 (EFS) [0x2800000 0x800000] Size: 8.0MB
P10 (NVDATA) [0x3000000 0x2000000] Size: 32.0MB
P11 (PARAM) [0x5000000 0x800000] Size: 8.0MB
P12 (RECOVERY) [0x5800000 0x1000000] Size: 16.0MB
P13 (BOOT) [0x6800000 0x1000000] Size: 16.0MB
P14 (MD1IMG) [0x7800000 0x2000000] Size: 32.0MB
P15 (MD1DSP) [0x9800000 0x400000] Size: 4.0MB
P16 (KEYSTORE) [0x9c00000 0x800000] Size: 8.0MB
P17 (OMEKEYSTORE) [0xa400000 0x380000] Size: 3.500MB
P18 (PROINFO) [0xa780000 0x280000] Size: 2.500MB
P19 (PARA) [0xaa00000 0x80000] Size: 512.0KB
P20 (PERSISTENT) [0xaa80000 0x80000] Size: 512.0KB
P21 (STEADY) [0xab00000 0x100000] Size: 1.0MB
P22 (PROTECT1) [0xac00000 0x800000] Size: 8.0MB
P23 (PROTECT2) [0xb400000 0x800000] Size: 8.0MB
P24 (RESERVE2) [0xbc00000 0x400000] Size: 4.0MB
P25 (SYSTEM) [0xc000000 0xc0800000] Size: 3.7GB
P26 (CACHE) [0xcc800000 0x19000000] Size: 400.0MB
P27 (HIDDEN) [0xe5800000 0x3c00000] Size: 60.0MB
P28 (USERDATA) [0xe9400000 0xe8800000] Size: 3.632GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB)
Unable to mount SYSTEM , code : 95
Detected USERDATA USERDATA : 0x00E9400000 (3.632GB)
Unable to read gesture.key , code 2
Done.
Selected eMMC Interface
i want to know what's mean this exactly if anyone had idea
this is my info on Plus :
Setting frequence to 21 MHz
CMD Pullup Level: 1773 mV
CMD Active Level: 2072 mV
EMMC CID: 90014A483847347592011E67A139156E
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
Backup saved: H8G4u_1E67A139_20190726_015626.extcsd
Scanning soft partitions
GPT header is found and is valid
Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4,00 MB)
Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8,00 MB)
Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2,00 MB)
Partition: bota1, [000001200000 - 000001400000], size: 000000200000 (2,00 MB)
Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7,00 MB)
Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512 KB)
Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512 KB)
Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6,00 MB)
Partition: bota2, [000002200000 - 000002800000], size: 000000600000 (6,00 MB)
Partition: efs, [000002800000 - 000003000000], size: 000000800000 (8,00 MB)
Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32,0 MB)
Partition: param, [000005000000 - 000005800000], size: 000000800000 (8,00 MB)
Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16,0 MB)
Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16,0 MB)
Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32,0 MB)
Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4,00 MB)
Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8,00 MB)
Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3,50 MB)
Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2,50 MB)
Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512 KB)
Partition: persistent, [00000AA80000 - 00000AB00000], size: 000000080000 (512 KB)
Partition: steady, [00000AB00000 - 00000AC00000], size: 000000100000 (1,00 MB)
Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8,00 MB)
Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8,00 MB)
Partition: reserve2, [00000BC00000 - 00000C000000], size: 000000400000 (4,00 MB)
Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3,01 GB)
Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400 MB)
Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60,0 MB)
Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3,63 GB)
GPT header successfully parsed
Get firmware version
Firmware info not found
example of write by vendor (samsung) : show success but no DL Mode
Backup saved: H8G4u_1E67A139_20190726_015740.extcsd
Entry count: 34
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
CMD Pullup Level: 1794 mV
CMD Active Level: 2062 mV
Backup saved: H8G4u_1E67A139_20190726_015754.extcsd
Done writing partition. Write speed: 156,84 KB/s
Partition name: LK
Done writing partition. Write speed: 280,27 KB/s
Done writing partition. Write speed: 14,00 KB/s
Done writing partition. Write speed: 448,37 KB/s
Done writing partition. Write speed: 483,45 KB/s
Operation: Writing BootConfig ...
Reg: 179  Value: 0x48
Reg: 177  Value: 0x00
Reg: 162  Value: 0x01
Done
All done   time: [00:01:00:161]
Old 07-26-2019, 10:09   #427 (permalink)
Member: 13148
Thanks Meter: 1,388
you need write latest version, like AQJ-AQK
or combi file: COMBINATION_OXE_FA60_G532GDXU1AQJ1.zip
also you need use latest plus version (1.6.2)
Old 07-27-2019, 03:18   #428 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 136
same problem even with this firmware (G532GDXU1AQK1_ZZT1AQK1) or this comb (COMBINATION_OXE_FA60_G532GDXU1AQJ1) any idea ?
26/07/2019 16:53:12>
26/07/2019 16:53:12> eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
26/07/2019 16:53:15> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015)
26/07/2019 16:53:15> Looking for EasyJTAG box...
26/07/2019 16:53:15> EasyJTAG API ver. 3307
26/07/2019 16:53:17> OpenUSB returned = 0
26/07/2019 16:53:19> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:53:20> Card Serial = AA95BECE
26/07/2019 16:53:20> EasyJTAG Box Firmware = 1.63
26/07/2019 16:53:32> Looking for EasyJTAG box...
26/07/2019 16:53:32> EasyJTAG API ver. 3307
26/07/2019 16:53:32> Setting IO Levels to 1.8V
26/07/2019 16:53:32> Setting frequence to 21 MHz
26/07/2019 16:53:33> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:53:33> EasyJTAG Box Firmware = 1.63
26/07/2019 16:53:36> Setting frequence to 21 MHz
26/07/2019 16:53:36> CMD Pullup Level: 1794 mV
26/07/2019 16:53:36> CMD Active Level: 2083 mV
26/07/2019 16:53:36> eMMC Init returned = 0
26/07/2019 16:53:36> EMMC Device Information :
26/07/2019 16:53:36> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 16:53:36> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 16:53:36> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 16:53:36> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 16:53:36> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 16:53:36> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 16:53:36> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 16:53:37> EMMC Permanent Write Protection: No
26/07/2019 16:53:37> EMMC Temporary Write Protection: No
26/07/2019 16:53:37> Extended CSD Information :
26/07/2019 16:53:37> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 16:53:37> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 16:53:37> Boot Bus Config: 0x00 , width 1bit
26/07/2019 16:53:37> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 16:53:37> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 16:53:37> Device supports partitioning features
26/07/2019 16:53:37> Device can have enhanced technological features in partitions and user data area
26/07/2019 16:53:37> Device can have extended partitions attribute
26/07/2019 16:53:37> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 16:53:37> Backup saved: H8G4u_1E67A139_20190726_165337.extcsd
26/07/2019 16:53:37> EMMC Init completed.
26/07/2019 16:53:54> Looking for EasyJTAG box...
26/07/2019 16:53:54> EasyJTAG API ver. 3307
26/07/2019 16:53:54> Setting IO Levels to 1.8V
26/07/2019 16:53:54> Setting frequence to 21 MHz
26/07/2019 16:53:56> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:53:56> EasyJTAG Box Firmware = 1.63
26/07/2019 16:53:58> Setting frequence to 21 MHz
26/07/2019 16:53:58> Error: First select the Pit-file
26/07/2019 16:53:58> CMD Pullup Level: 1794 mV
26/07/2019 16:53:58> CMD Active Level: 2083 mV
26/07/2019 16:53:59> eMMC Init returned = 0
26/07/2019 16:53:59> EMMC Device Information :
26/07/2019 16:53:59> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 16:53:59> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 16:53:59> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 16:53:59> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 16:53:59> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 16:53:59> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 16:53:59> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 16:53:59> EMMC Permanent Write Protection: No
26/07/2019 16:53:59> EMMC Temporary Write Protection: No
26/07/2019 16:53:59> Extended CSD Information :
26/07/2019 16:53:59> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 16:53:59> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 16:53:59> Boot Bus Config: 0x00 , width 1bit
26/07/2019 16:53:59> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 16:53:59> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 16:53:59> Device supports partitioning features
26/07/2019 16:53:59> Device can have enhanced technological features in partitions and user data area
26/07/2019 16:53:59> Device can have extended partitions attribute
26/07/2019 16:53:59> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 16:53:59> Backup saved: H8G4u_1E67A139_20190726_165359.extcsd
26/07/2019 16:53:59> EMMC Init completed.
26/07/2019 16:53:59> Opening file: C:\Users\OP\Desktop\G532GDXU1AQK1_ZZT1AQK1\GRANDPP LTE_CIS_SER_HIDDEN100M.pit
26/07/2019 16:53:59> Pit: GRANDPPLTE_CIS_SER_HIDDEN100M.pit
26/07/2019 16:53:59> Entry count: 34
26/07/2019 16:53:59> The size of the last section has been updated
26/07/2019 16:54:09> Selected file: C:\Users\OP\Desktop\G532GDXU1AQK1_ZZT1AQK1\BL_G532 GDXU1AQK1_CL12551713_QB15688219_REV00_user_low_shi p_MULTI_CERT.tar.md5
26/07/2019 16:54:09> BL_G532GDXU1AQK1_CL12551713_QB15688219_REV00_user_ low_ship_MULTI_CERT.tar.md5
26/07/2019 16:54:09> The list of files in the firmware:
26/07/2019 16:54:09> preloader.img
26/07/2019 16:54:09> lk.bin
26/07/2019 16:54:09> param.bin
26/07/2019 16:54:09> trustzone.bin
26/07/2019 16:54:09> efuse.img
26/07/2019 16:54:12> Looking for EasyJTAG box...
26/07/2019 16:54:12> EasyJTAG API ver. 3307
26/07/2019 16:54:12> Setting IO Levels to 1.8V
26/07/2019 16:54:12> Setting frequence to 21 MHz
26/07/2019 16:54:13> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:54:13> EasyJTAG Box Firmware = 1.63
26/07/2019 16:54:16> Setting frequence to 21 MHz
26/07/2019 16:54:16> CMD Pullup Level: 1784 mV
26/07/2019 16:54:16> CMD Active Level: 2072 mV
26/07/2019 16:54:16> eMMC Init returned = 0
26/07/2019 16:54:16> EMMC Device Information :
26/07/2019 16:54:16> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 16:54:16> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 16:54:16> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 16:54:16> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 16:54:16> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 16:54:16> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 16:54:17> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 16:54:17> EMMC Permanent Write Protection: No
26/07/2019 16:54:17> EMMC Temporary Write Protection: No
26/07/2019 16:54:17> Extended CSD Information :
26/07/2019 16:54:17> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 16:54:17> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 16:54:17> Boot Bus Config: 0x00 , width 1bit
26/07/2019 16:54:17> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 16:54:17> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 16:54:17> Device supports partitioning features
26/07/2019 16:54:17> Device can have enhanced technological features in partitions and user data area
26/07/2019 16:54:17> Device can have extended partitions attribute
26/07/2019 16:54:17> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 16:54:17> Backup saved: H8G4u_1E67A139_20190726_165417.extcsd
26/07/2019 16:54:17> EMMC Init completed.
26/07/2019 16:54:17> Operation: Write by vendor (Samsung)
26/07/2019 16:54:17> Creating GPT-partitioninig
26/07/2019 16:54:17> Writing PrimaryGPT at address: 000000000000
26/07/2019 16:54:17> Writing BackupGPT at address: 0001D1FFBE00
26/07/2019 16:54:17> Writing PIT at address: 000000004400
26/07/2019 16:54:17> GPT-partitioning done
26/07/2019 16:54:17> Unpacking file: preloader.img
26/07/2019 16:54:17> Unpacking file: lk.bin
26/07/2019 16:54:17> Unpacking file: efuse.img
26/07/2019 16:54:17> Unpacking file: trustzone.bin
26/07/2019 16:54:17> Unpacking file: param.bin
26/07/2019 16:54:17> Partition name: BOOTLOADER
26/07/2019 16:54:17> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
26/07/2019 16:54:17> eMMC switching to ROM2
26/07/2019 16:54:18> Erasing partition...
26/07/2019 16:54:39> Writing partition...
26/07/2019 16:54:40> Done writing partition. Write speed: 163,43 KB/s
26/07/2019 16:54:40> Partition name: LK
26/07/2019 16:54:40> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
26/07/2019 16:54:40> eMMC switching to ROM1
26/07/2019 16:54:40> Erasing partition...
26/07/2019 16:54:43> Writing partition...
26/07/2019 16:54:45> Done writing partition. Write speed: 299,86 KB/s
26/07/2019 16:54:45> Partition name: EFUSE
26/07/2019 16:54:45> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
26/07/2019 16:54:45> eMMC switching to ROM1
26/07/2019 16:54:45> Erasing partition...
26/07/2019 16:54:46> Writing partition...
26/07/2019 16:54:46> Done writing partition. Write speed: 7,86 KB/s
26/07/2019 16:54:46> Partition name: TEE1
26/07/2019 16:54:46> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
26/07/2019 16:54:46> eMMC switching to ROM1
26/07/2019 16:54:46> Erasing partition...
26/07/2019 16:54:47> Writing partition...
26/07/2019 16:54:48> Done writing partition. Write speed: 464,49 KB/s
26/07/2019 16:54:48> Partition name: PARAM
26/07/2019 16:54:48> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
26/07/2019 16:54:48> eMMC switching to ROM1
26/07/2019 16:54:48> Erasing partition...
26/07/2019 16:54:50> Writing partition...
26/07/2019 16:54:51> Done writing partition. Write speed: 573,94 KB/s
26/07/2019 16:54:52>
26/07/2019 16:54:55> Partition USERDATA : formatting as EXT4. Please wait ...
26/07/2019 16:55:08> Formatting completed
26/07/2019 16:55:08> Check BootConfig for the selected vendor
26/07/2019 16:55:08> All done time: [00:00:50:645]
26/07/2019 16:56:59> Looking for EasyJTAG box...
26/07/2019 16:56:59> EasyJTAG API ver. 3307
26/07/2019 16:56:59> Setting IO Levels to 1.8V
26/07/2019 16:56:59> Setting frequence to 21 MHz
26/07/2019 16:57:00> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:57:00> EasyJTAG Box Firmware = 1.63
26/07/2019 16:57:03> Setting frequence to 21 MHz
26/07/2019 16:57:03> CMD Pullup Level: 1794 mV
26/07/2019 16:57:03> CMD Active Level: 2072 mV
26/07/2019 16:57:03> eMMC Init returned = 0
26/07/2019 16:57:03> EMMC Device Information :
26/07/2019 16:57:03> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 16:57:03> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 16:57:03> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 16:57:03> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 16:57:03> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 16:57:03> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 16:57:03> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 16:57:03> EMMC Permanent Write Protection: No
26/07/2019 16:57:03> EMMC Temporary Write Protection: No
26/07/2019 16:57:04> Extended CSD Information :
26/07/2019 16:57:04> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 16:57:04> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 16:57:04> Boot Bus Config: 0x00 , width 1bit
26/07/2019 16:57:04> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 16:57:04> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 16:57:04> Device supports partitioning features
26/07/2019 16:57:04> Device can have enhanced technological features in partitions and user data area
26/07/2019 16:57:04> Device can have extended partitions attribute
26/07/2019 16:57:04> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 16:57:04> Backup saved: H8G4u_1E67A139_20190726_165704.extcsd
26/07/2019 16:57:04> EMMC Init completed.
26/07/2019 16:57:08> Looking for EasyJTAG box...
26/07/2019 16:57:08> EasyJTAG API ver. 3307
26/07/2019 16:57:08> Setting IO Levels to 1.8V
26/07/2019 16:57:08> Setting frequence to 21 MHz
26/07/2019 16:57:10> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:57:10> EasyJTAG Box Firmware = 1.63
26/07/2019 16:57:12> Setting frequence to 21 MHz
26/07/2019 16:57:12> CMD Pullup Level: 1794 mV
26/07/2019 16:57:12> CMD Active Level: 2072 mV
26/07/2019 16:57:13> eMMC Init returned = 0
26/07/2019 16:57:13> EMMC Device Information :
26/07/2019 16:57:13> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 16:57:13> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 16:57:13> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 16:57:13> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 16:57:13> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 16:57:13> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 16:57:13> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 16:57:13> EMMC Permanent Write Protection: No
26/07/2019 16:57:13> EMMC Temporary Write Protection: No
26/07/2019 16:57:13> Extended CSD Information :
26/07/2019 16:57:13> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 16:57:13> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 16:57:13> Boot Bus Config: 0x00 , width 1bit
26/07/2019 16:57:13> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 16:57:13> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 16:57:13> Device supports partitioning features
26/07/2019 16:57:13> Device can have enhanced technological features in partitions and user data area
26/07/2019 16:57:13> Device can have extended partitions attribute
26/07/2019 16:57:13> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 16:57:13> Backup saved: H8G4u_1E67A139_20190726_165713.extcsd
26/07/2019 16:57:13> EMMC Init completed.
26/07/2019 16:57:13> Get firmware version
26/07/2019 16:57:22> Brand = samsung
26/07/2019 16:57:22> Manufacturer = samsung
26/07/2019 16:57:22> Device = grandpplte
26/07/2019 16:57:22> Model = SM-G532G
26/07/2019 16:57:22> Phone platform = mt6737t
26/07/2019 16:57:22> CPU Abi = armeabi-v7a
26/07/2019 16:57:22> Mediatek platform = MT6737T
26/07/2019 16:57:22> Android release = 6.0.1
26/07/2019 16:57:22> Firmware version = MMB29T.G532GDXU1AQA4
26/07/2019 16:57:22> Firmware date = Mon Jan 23 20:44:01 KST 2017
26/07/2019 16:58:10> Selected file: C:\Users\OP\Desktop\COMBINATION_OXE_FA60_G532GDXU1 AQJ1_OXEFA60_G532GOLB1AQJ1_CL11108991_QB15342015_R EV00_user_mid_noship_MULTI_CERT.tar.md5
26/07/2019 16:58:10> COMBINATION_OXE_FA60_G532GDXU1AQJ1_OXEFA60_G532GOL B1AQJ1_CL11108991_QB15342015_REV00_user_mid_noship _MULTI_CERT.tar.md5
26/07/2019 16:58:10> The list of files in the firmware:
26/07/2019 16:58:10> preloader.img
26/07/2019 16:58:10> lk.bin
26/07/2019 16:58:10> param.bin
26/07/2019 16:58:10> trustzone.bin
26/07/2019 16:58:10> efuse.img
26/07/2019 16:58:10> boot.img
26/07/2019 16:58:10> recovery.img
26/07/2019 16:58:10> system.img
26/07/2019 16:58:10> secro.img
26/07/2019 16:58:10> md1rom.img
26/07/2019 16:58:10> md1dsp.img
26/07/2019 16:58:10> grandpplte_cis_ser.pit
26/07/2019 16:58:10> cache.img
26/07/2019 16:58:17> Looking for EasyJTAG box...
26/07/2019 16:58:17> EasyJTAG API ver. 3307
26/07/2019 16:58:17> Setting IO Levels to 1.8V
26/07/2019 16:58:17> Setting frequence to 21 MHz
26/07/2019 16:58:18> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 16:58:18> EasyJTAG Box Firmware = 1.63
26/07/2019 16:58:21> Setting frequence to 21 MHz
26/07/2019 16:58:21> CMD Pullup Level: 1784 mV
26/07/2019 16:58:21> CMD Active Level: 2072 mV
26/07/2019 16:58:21> eMMC Init returned = 0
26/07/2019 16:58:21> EMMC Device Information :
26/07/2019 16:58:21> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 16:58:21> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 16:58:21> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 16:58:21> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 16:58:21> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 16:58:21> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 16:58:21> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 16:58:21> EMMC Permanent Write Protection: No
26/07/2019 16:58:21> EMMC Temporary Write Protection: No
26/07/2019 16:58:21> Extended CSD Information :
26/07/2019 16:58:21> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 16:58:21> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 16:58:22> Boot Bus Config: 0x00 , width 1bit
26/07/2019 16:58:22> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 16:58:22> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 16:58:22> Device supports partitioning features
26/07/2019 16:58:22> Device can have enhanced technological features in partitions and user data area
26/07/2019 16:58:22> Device can have extended partitions attribute
26/07/2019 16:58:22> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 16:58:22> Backup saved: H8G4u_1E67A139_20190726_165822.extcsd
26/07/2019 16:58:22> EMMC Init completed.
26/07/2019 16:58:22> Operation: Write by vendor (Samsung)
26/07/2019 16:58:22> Creating GPT-partitioninig
26/07/2019 16:58:22> Writing PrimaryGPT at address: 000000000000
26/07/2019 16:58:22> Writing BackupGPT at address: 0001D1FFBE00
26/07/2019 16:58:22> Writing PIT at address: 000000004400
26/07/2019 16:58:22> GPT-partitioning done
26/07/2019 16:58:22> Unpacking file: preloader.img
26/07/2019 16:58:22> Unpacking file: lk.bin
26/07/2019 16:58:22> Unpacking file: secro.img
26/07/2019 16:58:22> Unpacking file: efuse.img
26/07/2019 16:58:22> Unpacking file: trustzone.bin
26/07/2019 16:58:22> Unpacking file: param.bin
26/07/2019 16:58:22> Unpacking file: recovery.img
26/07/2019 16:58:22> Unpacking file: boot.img
26/07/2019 16:58:22> Unpacking file: md1rom.img
26/07/2019 16:58:22> Unpacking file: md1dsp.img
26/07/2019 16:58:22> Unpacking file: system.img
26/07/2019 16:58:35> Unpacking file: cache.img
26/07/2019 16:58:35> Partition name: BOOTLOADER
26/07/2019 16:58:35> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
26/07/2019 16:58:35> eMMC switching to ROM2
26/07/2019 16:58:35> Erasing partition...
26/07/2019 16:58:56> Writing partition...
26/07/2019 16:58:57> Done writing partition. Write speed: 163,27 KB/s
26/07/2019 16:58:57> Partition name: LK
26/07/2019 16:58:57> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
26/07/2019 16:58:57> eMMC switching to ROM1
26/07/2019 16:58:57> Erasing partition...
26/07/2019 16:59:00> Writing partition...
26/07/2019 16:59:02> Done writing partition. Write speed: 308,15 KB/s
26/07/2019 16:59:02> Partition name: SECRO
26/07/2019 16:59:02> Filename: secro.img , Offset: 000001400000 , filesize: 135424 bytes
26/07/2019 16:59:02> eMMC switching to ROM1
26/07/2019 16:59:03> Erasing partition...
26/07/2019 16:59:04> Writing partition...
26/07/2019 16:59:04> Done writing partition. Write speed: 499,00 KB/s
26/07/2019 16:59:04> Partition name: EFUSE
26/07/2019 16:59:04> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
26/07/2019 16:59:04> eMMC switching to ROM1
26/07/2019 16:59:05> Erasing partition...
26/07/2019 16:59:05> Writing partition...
26/07/2019 16:59:05> Done writing partition. Write speed: 13,17 KB/s
26/07/2019 16:59:05> Partition name: TEE1
26/07/2019 16:59:05> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
26/07/2019 16:59:05> eMMC switching to ROM1
26/07/2019 16:59:06> Erasing partition...
26/07/2019 16:59:07> Writing partition...
26/07/2019 16:59:08> Done writing partition. Write speed: 522,38 KB/s
26/07/2019 16:59:08> Partition name: PARAM
26/07/2019 16:59:08> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
26/07/2019 16:59:08> eMMC switching to ROM1
26/07/2019 16:59:08> Erasing partition...
26/07/2019 16:59:10> Writing partition...
26/07/2019 16:59:11> Done writing partition. Write speed: 587,25 KB/s
26/07/2019 16:59:11> Partition name: RECOVERY
26/07/2019 16:59:11> Filename: recovery.img , Offset: 000005800000 , filesize: 10699024 bytes
26/07/2019 16:59:11> eMMC switching to ROM1
26/07/2019 16:59:11> Erasing partition...
26/07/2019 16:59:14> Writing partition...
26/07/2019 16:59:32> Done writing partition. Write speed: 589,37 KB/s
26/07/2019 16:59:32> Partition name: BOOT
26/07/2019 16:59:32> Filename: boot.img , Offset: 000006800000 , filesize: 9548048 bytes
26/07/2019 16:59:32> eMMC switching to ROM1
26/07/2019 16:59:32> Erasing partition...
26/07/2019 16:59:35> Writing partition...
26/07/2019 16:59:51> Done writing partition. Write speed: 586,63 KB/s
26/07/2019 16:59:51> Partition name: MD1IMG
26/07/2019 16:59:51> Filename: md1rom.img , Offset: 000007800000 , filesize: 10506752 bytes
26/07/2019 16:59:51> eMMC switching to ROM1
26/07/2019 16:59:51> Erasing partition...
26/07/2019 16:59:56> Writing partition...
26/07/2019 17:00:13> Done writing partition. Write speed: 589,23 KB/s
26/07/2019 17:00:13> Partition name: MD1DSP
26/07/2019 17:00:13> Filename: md1dsp.img , Offset: 000009800000 , filesize: 1417728 bytes
26/07/2019 17:00:13> eMMC switching to ROM1
26/07/2019 17:00:14> Erasing partition...
26/07/2019 17:00:15> Writing partition...
26/07/2019 17:00:17> Done writing partition. Write speed: 587,80 KB/s
26/07/2019 17:00:17> Partition name: SYSTEM
26/07/2019 17:00:17> Filename: system.img , Offset: 00000C000000 , filesize: 1088833088 bytes
26/07/2019 17:00:17> eMMC switching to ROM1
26/07/2019 17:00:18> Erasing partition...
26/07/2019 17:07:39> Writing partition...
26/07/2019 17:07:39> Sparse image found v.1.0 Total chunks: 2402
26/07/2019 17:38:52> Done writing partition. Write speed: 567,61 KB/s
26/07/2019 17:38:53> Partition name: CACHE
26/07/2019 17:38:53> Filename: cache.img , Offset: 0000CC800000 , filesize: 8266096 bytes
26/07/2019 17:38:53> eMMC switching to ROM1
26/07/2019 17:38:53> Erasing partition...
26/07/2019 17:39:50> Writing partition...
26/07/2019 17:39:50> Sparse image found v.1.0 Total chunks: 21
26/07/2019 17:40:05> Done writing partition. Write speed: 568,89 KB/s
26/07/2019 17:40:05> Check BootConfig for the selected vendor
26/07/2019 17:40:06> All done time: [00:41:30:805]
26/07/2019 17:40:55> Looking for EasyJTAG box...
26/07/2019 17:40:55> EasyJTAG API ver. 3307
26/07/2019 17:40:55> Setting IO Levels to 1.8V
26/07/2019 17:40:55> Setting frequence to 21 MHz
26/07/2019 17:40:56> EasyJTAG Box Serial = 14140E12A2C07F42
26/07/2019 17:40:56> EasyJTAG Box Firmware = 1.63
26/07/2019 17:40:59> Setting frequence to 21 MHz
26/07/2019 17:40:59> CMD Pullup Level: 1794 mV
26/07/2019 17:40:59> CMD Active Level: 2072 mV
26/07/2019 17:40:59> eMMC Init returned = 0
26/07/2019 17:40:59> EMMC Device Information :
26/07/2019 17:40:59> EMMC CID: 90014A483847347592011E67A139156E
26/07/2019 17:40:59> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
26/07/2019 17:40:59> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1E67A139 , rev. 0x01
26/07/2019 17:40:59> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
26/07/2019 17:40:59> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
26/07/2019 17:40:59> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
26/07/2019 17:40:59> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
26/07/2019 17:40:59> EMMC Permanent Write Protection: No
26/07/2019 17:40:59> EMMC Temporary Write Protection: No
26/07/2019 17:40:59> Extended CSD Information :
26/07/2019 17:40:59> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
26/07/2019 17:40:59> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
26/07/2019 17:40:59> Boot Bus Config: 0x00 , width 1bit
26/07/2019 17:40:59> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
26/07/2019 17:40:59> Supported partition features [PARTITIONING_SUPPORT]: 0x07
26/07/2019 17:40:59> Device supports partitioning features
26/07/2019 17:40:59> Device can have enhanced technological features in partitions and user data area
26/07/2019 17:40:59> Device can have extended partitions attribute
26/07/2019 17:41:00> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
26/07/2019 17:41:00> Backup saved: H8G4u_1E67A139_20190726_174100.extcsd
26/07/2019 17:41:00> EMMC Init completed.
26/07/2019 17:41:00> Get firmware version
26/07/2019 17:41:09> Brand = samsung
26/07/2019 17:41:09> Manufacturer = samsung
26/07/2019 17:41:09> Device = grandpplte
26/07/2019 17:41:09> Model = SM-G532G
26/07/2019 17:41:09> Phone platform = mt6737t
26/07/2019 17:41:09> CPU Abi = armeabi-v7a
26/07/2019 17:41:09> Mediatek platform = MT6737T
26/07/2019 17:41:09> Android release = 6.0.1
26/07/2019 17:41:09> Firmware version = MMB29T.FA60_G532GDXU1AQJ1
26/07/2019 17:41:09> Firmware date = Tue Oct 17 13:47:33 KST 2017
Old 07-27-2019, 10:27   #429 (permalink)
Member: 13148
Thanks Meter: 1,388
May be it's a hardware problem.
Try to reball CPU
Old 07-28-2019, 15:56   #430 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 136
ok i will check that thanks
Old 11-03-2019, 07:20   #431 (permalink)
Member: 2222183
Thanks Meter: 31
Unhappy G532G after flashing dead?
see log and how to repair step by step kindly tell me...
Z3X EasyJtag Software ver. 3.6.1.15
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 1616FE04ACD6A1EB, ,FW Ver.: 01.63
CMD Pullup Level:2000 mV
CMD Active Level:2505 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 90014A483847347592012A95B4511522
eMMC NAME: H8G4u , S/N: 714454097
EMMC ROM1 (Main User Data) Capacity: 7456 MB , 0xE90000 pages , 0x1D2000000 bytes
Backup saved: H8G4u_ 714454097_20191103_1118.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x00]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05]
Power off notification [POWER_OFF_LONG_TIME: 0x64]
Cache Size [CACHE_SIZE] is 1024 KiB
------------------------- eMMC v5+ -------------------------
Supported modes [SUPPORTED_MODES: 0x01]
FFU features [FFU_FEATURES: 0x00]
Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00]
FFU Argument [FFU_ARG: 0xfffafff0]
Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0]
Vendor proprietary health report:
[VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x0b]
i.e. Exceeded its maximum estimated device life time
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01]
i.e. 0% - 10% device life time used
Pre EOL information [PRE_EOL_INFO: 0x01]
i.e. Normal
Optimal read size [OPTIMAL_READ_SIZE: 0x40]
Optimal write size [OPTIMAL_WRITE_SIZE: 0x40]
Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x07]
Device version [DEVICE_VERSION: 0x38 - 0x05]
Firmware version:
[FIRMWARE_VERSION[261]]: 0x00
[FIRMWARE_VERSION[260]]: 0x00
[FIRMWARE_VERSION[259]]: 0x00
[FIRMWARE_VERSION[258]]: 0x00
[FIRMWARE_VERSION[257]]: 0x31
[FIRMWARE_VERSION[256]]: 0x30
[FIRMWARE_VERSION[255]]: 0x30
[FIRMWARE_VERSION[254]]: 0x53
Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x01]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x08]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x00e90000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x00]
[MIN_PERF_R_8_52: 0x00]
[MIN_PERF_W_8_26_4_52: 0x00]
[MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x00]
[MIN_PERF_R_4_26: 0x00]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x48]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x50
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x15
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a4
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00
Native sector size [NATIVE_SECTOR_SIZE]: 0x01
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!
Soft (Partitioned) Disk/Image size: 749FDD sectors 3.6 GiB
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,7643135
Detected USERDATA USERDATA : 0x00E9400000 (0.0B)
Unable to mount USERDATA , code : 22
Done.
install rom 1,2
Error writing address 0x039C0000 Error Code:-8 Reason ATA SND CRC Error
Retry writing address 0x00039C0000 (Attempt #1)...
Retry Success!
Error writing address 0x06E40000 Error Code:-8 Reason ATA SND CRC Error
Retry writing address 0x0006E40000 (Attempt #1)...
Retry Success!
Done, time taken: 116 sec. Average Write Speed: 1552 kB/s
Skip loading eMMC Addon Firmware
Input file : C:\Users\akhtar\Desktop\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM2.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 3 sec. Average Write Speed: 691 kB/s
Old 11-03-2019, 09:24   #432 (permalink)
Member: 2170126
Sonork: Whtas & Fb
Thanks Meter: 47
use factory firmware file write by vender
Old 11-03-2019, 09:55   #433 (permalink)
Member: 13148
Thanks Meter: 1,388
You can translate from Russian this help:
Решено Работа с устройствами бренда Samsung
Old 11-08-2019, 12:43   #434 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 247
G532G dead needs help
hi, can anyone help me about this logs?
this phone is working and it died after i flashed with a lower version firmware.
so i don't think its emmc problem
see logs :
Done.
extCSD Are not selected , skip writing extCSD
Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM1_000000000000_000020000000.bin
Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM2_000000000000_000000400000.bin
Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM3_000000000000_000000400000.bin
CMD Pullup Level:3165 mV
CMD Active Level:3269 mV
Input file : C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM1_000000000000_000020000000.bin
Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM)
Error writing address 0x06180000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x0006180000 (Attempt #1)...
Retry Success!
Error writing address 0x0E380000 Error Code:-101 Reason :CARD Ready Timeout Error
Retry writing address 0x000E380000 (Attempt #1)...
Retry Success!
Error writing address 0x131C0000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x00131C0000 (Attempt #1)...
Retry Success!
Error writing address 0x164C0000 Error Code:-101 Reason :CARD Ready Timeout Error
Retry writing address 0x00164C0000 (Attempt #1)...
Retry Success!
Error writing address 0x19280000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x0019280000 (Attempt #1)...
Retry Success!
Error writing address 0x1C540000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x001C540000 (Attempt #1)...
Retry Success!
Error writing address 0x1F740000 Error Code:-8 Reason :DATA SND CRC Error
Retry writing address 0x001F740000 (Attempt #1)...
have tried a lot of times, still have this error
i have 3.3v and 21mhz clk
i am using charger as power supply and moorc adapter with power supply also.
Old 11-08-2019, 15:48   #435 (permalink)
Member: 13148
Thanks Meter: 1,388
you did not post info about type of connection, the box version (1 or 2),
and without this data we cannot give you any answer
Page generated in 0.66165 seconds with 8 queries
