Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-09-2017, 08:29   #91 (permalink)
Member: 1049764
Sonork: 100.1678585
Thanks Meter: 58
eMMC_tool Suite ver. 1.0.0.47
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2008
Setting IO Levels to 2.8V
Setting frequence to 21 Mhz
HiPower mode is OFF
EasyJTAG Box Serial = 16005015120EF521
Card Serial = AA0E-097C
EasyJTAG Box Firmware = 01.58
Changelog:
28.05.2017 (ver 1.0.0.47)
Fix: Bugs that have been found through your crash report
Fix: Searching for partitions when scanning MBR
Fix: Searching for MassStorage devices
Add: AutoUpdate for the program
HiPower mode is OFF
CMD Pullup Level: 13148 mV
CMD Active Level: 13303 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920133B8743A24EC
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX
EMMC NAME: H8G4u , S/N: 33B8743A , rev. 01
EMMC NAME (HEX): 483847347592
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Backup saved: H8G4u_33B8743A_20170609_114741.extcsd
EMMC Init completed.
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 57582800
The size of the last section has been updated
BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
HiPower mode is OFF
CMD Pullup Level: 12096 mV
CMD Active Level: 11931 mV
Backup saved: H8G4u_33B8743A_20170609_115358.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 183.68 Kb/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 693.96 Kb/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 16.66 Kb/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 768.11 Kb/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 761.10 Kb/s
All done
thanx for the help bro
Old 06-09-2017, 13:37   #92 (permalink)
mastana_dk's Avatar
Member: 804463
Thanks Meter: 72
Arrow
HiPower mode is OFF
Changelog:
HiPower mode is OFF
CMD Pullup Level: 12251 mV
CMD Active Level: 12601 mV
Can't init device. Reason: CMD Timeout Error
HiPower mode is OFF
CMD Pullup Level: 13158 mV
CMD Active Level: 13179 mV
HiPower mode is OFF
CMD Pullup Level: 11405 mV
CMD Active Level: 11199 mV
HiPower mode is OFF
CMD Pullup Level: 11828 mV
CMD Active Level: 11498 mV
emmc repair allways cmd timeout error
https://www.mediafire.com/?naod7j6bh2yozcs
use v3 cable for adepter and good soldring waer this wer touch problem 100% work for me
Old 06-09-2017, 14:51   #93 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 640
Z3X EasyJtag Software ver. 2.5.0.9
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 010070222EE63D88, ,FW Ver.: 01.58
CMD Pullup Level:2640 mV
CMD Active Level:2763 mV
Box IO Level:2800 mV
CLK Rate:21000 khz
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Pullup Level:1980 mV
CMD Active Level:2268 mV
CLK Rate:21000 khz
---------- eMMC Device Information ----------
EMMC CID : 90014A4838473475920133B8748F2492
EMMC CSD : D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 02/2017 Rev.0x1
EMMC NAME: H8G4u , S/N: 867726479
EMMC NAME (HEX): 48384734752000
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u _ 867726479_20170608_1937.extcsd
Partition info successfully found
P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB
P1 (NVRAM) [0x800000 0x800000] Size: 8.0MB
P2 (LK) [0x1000000 0x200000] Size: 2.0MB
P3 (BOTA1) [0x1200000 0x200000] Size: 2.0MB
P4 (SECRO) [0x1400000 0x700000] Size: 7.0MB
P5 (SECCFG) [0x1b00000 0x80000] Size: 512.0KB
P6 (EFUSE) [0x1b80000 0x80000] Size: 512.0KB
P7 (TEE1) [0x1c00000 0x600000] Size: 6.0MB
P8 (BOTA2) [0x2200000 0x600000] Size: 6.0MB
P9 (EFS) [0x2800000 0x800000] Size: 8.0MB
P10 (NVDATA) [0x3000000 0x2000000] Size: 32.0MB
P11 (PARAM) [0x5000000 0x800000] Size: 8.0MB
P12 (RECOVERY) [0x5800000 0x1000000] Size: 16.0MB
P13 (BOOT) [0x6800000 0x1000000] Size: 16.0MB
P14 (MD1IMG) [0x7800000 0x2000000] Size: 32.0MB
P15 (MD1DSP) [0x9800000 0x400000] Size: 4.0MB
P16 (KEYSTORE) [0x9c00000 0x800000] Size: 8.0MB
P17 (OMEKEYSTORE) [0xa400000 0x380000] Size: 3.500MB
P18 (PROINFO) [0xa780000 0x280000] Size: 2.500MB
P19 (PARA) [0xaa00000 0x80000] Size: 512.0KB
P20 (PERSISTENT) [0xaa80000 0x80000] Size: 512.0KB
P21 (STEADY) [0xab00000 0x100000] Size: 1.0MB
P22 (PROTECT1) [0xac00000 0x800000] Size: 8.0MB
P23 (PROTECT2) [0xb400000 0x800000] Size: 8.0MB
P24 (RESERVE2) [0xbc00000 0x400000] Size: 4.0MB
P25 (SYSTEM) [0xc000000 0xc0800000] Size: 3.7GB
P26 (CACHE) [0xcc800000 0x19000000] Size: 400.0MB
P27 (HIDDEN) [0xe5800000 0x3c00000] Size: 60.0MB
P28 (USERDATA) [0xe9400000 0xe8800000] Size: 3.632GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB)
Build ID: MMB29T
Display Build ID: MMB29T.G532GDXU1APJ7
Release ID: 6.0.1
Device Model: SM-G532G
Device Name: grandppltedx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: mt6737t
Product ID: grandpplte
Build Description: grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys
Samsung CPU: MT6737T
Done.
done perfect 6th set done
Old 06-10-2017, 05:16   #94 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 924
HiPower mode is OFF
Changelog:
HiPower mode is OFF
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
HiPower mode is OFF
Partition name: LK
All done
post here how solve your problem and who help you .----------
The Following User Says Thank You to kothamamun For This Useful Post:
Old 06-10-2017, 05:31   #95 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 924
[IMG][/IMG]
Old 06-10-2017, 06:08   #96 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 640
Bro I had done my self already more post in successful report
Old 06-17-2017, 08:33   #97 (permalink)
Member: 2599387
Thanks Meter: 5
Hi, after repair it shows mediatek port. no download mode
br
Old 06-20-2017, 05:01   #98 (permalink)
Member: 2654484
black screen after repair
Plz help. The screen is blank after repair
The Following User Says Thank You to maskrider For This Useful Post:
Old 06-20-2017, 16:05   #99 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,797
i think your display problem
please check your display ......
Old 06-20-2017, 17:27   #100 (permalink)
Member: 2654484
Its a brand new phone
Tested the ISP with easy jtag. After that the screen is blank (no display) once i finish the assembly. Do you think i spoil some component inside while soldering?
Old 06-22-2017, 14:54   #101 (permalink)
Member: 2487167
Sonork: 100.1670279
Thanks Meter: 5
Need EFS Backup Or Full Dump file
Originally Posted by ALI_MAFIA View Post
Samsung G532G dead while flash..
done by "MUKTI TELECOM". it also save imei.
here al work log.
Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58
CMD Pullup Level:1753 mV
CMD Active Level:2289 mV
CLK Rate:21000 khz
EMMC CID : 90014A483847347592011D80D8C0243E
EMMC NAME: H8G4u , S/N: 494983360
Backup saved: H8G4u _ 494983360_20170509_1808.extcsd
Caution: invalid backup GPT header, but valid main header!
Caution! After loading partitions, the CRC doesn't check out!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
First usable sector: 34
Last usable sector: 15269854
P32 (⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⠨H꒤ᄂﯻ￿￿﷽ �￿￿﻾￾￿￿﻾￾﻾￾﻾￾﻾￾﻾￾﻾￾﻾￾﻾￾￿￿﷽�粒￿￿﫺￿￿￿￿궭ᆳ⨪J⨪J⨪J⨪J⨪J⨪ Jള䯖櫃ࠫ䚰ܹ鐰ܸ) [0x505051fe50505000 0x404040004040600] Size: 263172.0TB
P33 (﻾￾﻾￾﻾￾﻾￾￿￿﷽�粒￿￿﫺￿￿￿￿궭ᆳ⨪J⨪J⨪J⨪J⨪J⨪Jള䯖櫃ࠫ䚰ܹ鐰ܸ ) [0xfffffffffdfdfc00 0] Size: 0.0B
Build ID: MMB29T
Release ID: 6.0.1
Done.
HiPower mode is OFF
CMD Pullup Level: 1753 mV
CMD Active Level: 2289 mV
EMMC CID: 90014A483847347592011D80D8C0243E
EMMC NAME: H8G4u , S/N: 1D80D8C0 , rev. 01
Backup saved: H8G4u_1D80D8C0_20170509_183832.extcsd
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000
Partition: nvram, [000000800000 - 000001000000], size: 000000800000
Partition: lk, [000001000000 - 000001200000], size: 000000200000
Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000
Partition: secro, [000001400000 - 000001B00000], size: 000000700000
Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000
Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000
Partition: tee1, [000001C00000 - 000002200000], size: 000000600000
Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000
Partition: EFS, [000002800000 - 000003000000], size: 000000800000
Partition: nvdata, [000003000000 - 000005000000], size: 000002000000
Partition: PARAM, [000005000000 - 000005800000], size: 000000800000
Partition: recovery, [000005800000 - 000006800000], size: 000001000000
Partition: boot, [000006800000 - 000007800000], size: 000001000000
Partition: md1img, [000007800000 - 000009800000], size: 000002000000
Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000
Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000
Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000
Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000
Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000
Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000
Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000
Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000
Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000
Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000
Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000
Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000
Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000
Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000
GPT header successfully parsed
Brand = samsung
Model = SM-G532G
Phone platform = mt6737t
Mediatek platform = MT6737T
Android release = 6.0.1
Firmware version = MMB29T.G532GDXU1APJ7
Firmware date = Wed Oct 26 23:36:39 KST 2016
Need EFS Backup Or Full Dump file or please guide me repair imei
after emmc repair now phone shows only emergency calls only
Old 06-23-2017, 10:49   #102 (permalink)
Member: 2487167
Sonork: 100.1670279
Thanks Meter: 5
Emergency calls only after write this rom
after write this rom emmc back to live but shows emergency calls only and after write efs problem not solved
please help me solve the problem
Old 06-23-2017, 12:49   #103 (permalink)
Member: 1095116
Thanks Meter: 15
thanks
thanks but link is not run please add file to another link
Originally Posted by iOS_Shakil View Post
Samsung J2 Prime G532G Dead Boot Repair Done 100% Dead Recovered
First check info
G532G REPAIR FILE
if my post helpful just pass thanks buttons
The Following User Says Thank You to salhekmart For This Useful Post:
Old 06-23-2017, 13:06   #104 (permalink)
Member: 2487167
Sonork: 100.1670279
Thanks Meter: 5
If You have Full emmc dump file uploade here
First check info
G532G REPAIR FILE
If You have Full emmc dump file please uploade here
i have network issue in that model
Old 06-26-2017, 12:39   #105 (permalink)
Member: 2707355
Thanks Meter: 8
goood work boro kepitup
The Following 2 Users Say Thank You to .:GHOSTRIDER:. For This Useful Post:
Page generated in 0.50529 seconds with 8 queries
