Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-29-2017, 16:24   #106 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 817
Originally Posted by learnersoul View Post
If You have Full emmc dump file please uploade here
i have network issue in that model
Fulldump is not the solution, already try 8gb dump but doesn't work! Only the imei change but if you check in *#0011# it's still have error
Sent from my iPhone using Tapatalk
The Following User Says Thank You to Sniper_04 For This Useful Post:
Old 07-07-2017, 15:50   #107 (permalink)
Member: 2077370
Sonork: 100.1616788
Thanks Meter: 256
i need g532g boot repair file kst
Originally Posted by ALI_MAFIA View Post
Samsung G532G dead while flash..
done by "MUKTI TELECOM". it also save imei.
here al work log.
Z3X EasyJtag Software ver. 2.5.0.9
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58
CMD Pullup Level:1753 mV
CMD Active Level:2289 mV
Box IO Level:2800 mV
CLK Rate:21000 khz
HiPower mode is off!
---------- eMMC Device Information ----------
EMMC CID : 90014A483847347592011D80D8C0243E
EMMC CSD : D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 02/2017 Rev.0x1
EMMC NAME: H8G4u , S/N: 494983360
EMMC NAME (HEX): 48384734752000
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u _ 494983360_20170509_1808.extcsd
Caution: invalid backup GPT header, but valid main header!
Caution! After loading partitions, the CRC doesn't check out!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
First usable sector: 34
Last usable sector: 15269854
Partition info successfully found
P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB
P1 (NVRAM) [0x800000 0x800000] Size: 8.0MB
P2 (LK) [0x1000000 0x200000] Size: 2.0MB
P3 (BOTA1) [0x1200000 0x200000] Size: 2.0MB
P4 (SECRO) [0x1400000 0x700000] Size: 7.0MB
P5 (SECCFG) [0x1b00000 0x80000] Size: 512.0KB
P6 (EFUSE) [0x1b80000 0x80000] Size: 512.0KB
P7 (TEE1) [0x1c00000 0x600000] Size: 6.0MB
P8 (BOTA2) [0x2200000 0x600000] Size: 6.0MB
P9 (EFS) [0x2800000 0x800000] Size: 8.0MB
P10 (NVDATA) [0x3000000 0x2000000] Size: 32.0MB
P11 (PARAM) [0x5000000 0x800000] Size: 8.0MB
P12 (RECOVERY) [0x5800000 0x1000000] Size: 16.0MB
P13 (BOOT) [0x6800000 0x1000000] Size: 16.0MB
P14 (MD1IMG) [0x7800000 0x2000000] Size: 32.0MB
P15 (MD1DSP) [0x9800000 0x400000] Size: 4.0MB
P16 (KEYSTORE) [0x9c00000 0x800000] Size: 8.0MB
P17 (OMEKEYSTORE) [0xa400000 0x380000] Size: 3.500MB
P18 (PROINFO) [0xa780000 0x280000] Size: 2.500MB
P19 (PARA) [0xaa00000 0x80000] Size: 512.0KB
P20 (PERSISTENT) [0xaa80000 0x80000] Size: 512.0KB
P21 (STEADY) [0xab00000 0x100000] Size: 1.0MB
P22 (PROTECT1) [0xac00000 0x800000] Size: 8.0MB
P23 (PROTECT2) [0xb400000 0x800000] Size: 8.0MB
P24 (RESERVE2) [0xbc00000 0x400000] Size: 4.0MB
P25 (SYSTEM) [0xc000000 0xc0800000] Size: 3.7GB
P26 (CACHE) [0xcc800000 0x19000000] Size: 400.0MB
P27 (HIDDEN) [0xe5800000 0x3c00000] Size: 60.0MB
P28 (USERDATA) [0xe9400000 0xe8800000] Size: 3.632GB
P32 (⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⠨H꒤ᄂﯻ￿￿﷽ �￿￿﻾￾￿￿﻾￾﻾￾﻾￾﻾￾﻾￾﻾￾﻾￾﻾￾￿￿﷽�粒￿￿﫺￿￿￿￿궭ᆳ⨪J⨪J⨪J⨪J⨪J⨪ Jള䯖櫃ࠫ䚰ܹ鐰ܸ) [0x505051fe50505000 0x404040004040600] Size: 263172.0TB
P33 (﻾￾﻾￾﻾￾﻾￾￿￿﷽�粒￿￿﫺￿￿￿￿궭ᆳ⨪J⨪J⨪J⨪J⨪J⨪Jള䯖櫃ࠫ䚰ܹ鐰ܸ ) [0xfffffffffdfdfc00 0] Size: 0.0B
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB)
Build ID: MMB29T
Display Build ID: MMB29T.G532GDXU1APJ7
Release ID: 6.0.1
Device Model: SM-G532G
Device Name: grandppltedx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: mt6737t
Product ID: grandpplte
Build Description: grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys
Samsung CPU: MT6737T
Done.
HiPower mode is OFF
CMD Pullup Level: 1753 mV
CMD Active Level: 2289 mV
EMMC Device Information :
EMMC CID: 90014A483847347592011D80D8C0243E
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX
EMMC NAME: H8G4u , S/N: 1D80D8C0 , rev. 01
EMMC NAME (HEX): 483847347592
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Backup saved: H8G4u_1D80D8C0_20170509_183832.extcsd
EMMC Init completed.
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000
Partition: nvram, [000000800000 - 000001000000], size: 000000800000
Partition: lk, [000001000000 - 000001200000], size: 000000200000
Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000
Partition: secro, [000001400000 - 000001B00000], size: 000000700000
Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000
Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000
Partition: tee1, [000001C00000 - 000002200000], size: 000000600000
Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000
Partition: EFS, [000002800000 - 000003000000], size: 000000800000
Partition: nvdata, [000003000000 - 000005000000], size: 000002000000
Partition: PARAM, [000005000000 - 000005800000], size: 000000800000
Partition: recovery, [000005800000 - 000006800000], size: 000001000000
Partition: boot, [000006800000 - 000007800000], size: 000001000000
Partition: md1img, [000007800000 - 000009800000], size: 000002000000
Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000
Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000
Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000
Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000
Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000
Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000
Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000
Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000
Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000
Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000
Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000
Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000
Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000
Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000
GPT header successfully parsed
Brand = samsung
Model = SM-G532G
Phone platform = mt6737t
Mediatek platform = MT6737T
Android release = 6.0.1
Firmware version = MMB29T.G532GDXU1APJ7
Firmware date = Wed Oct 26 23:36:39 KST 2016
my info is hare:,
CMD Pullup Level:2041 mV
CMD Active Level:2516 mV
CLK Rate:14000 khz
EMMC CID : 90014A483847347592013313BD2A34AC
EMMC Date: 03/2017 Rev.0x1
EMMC NAME: H8G4u , S/N: 856931626
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: H8G4u _ 856931626_20170707_1855.extcsd
GPT: damaged
Soft (Partitioned) Disk/Image size: 749FDD sectors 3.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Last usable sector: 7643135
Found Data areas (firmware parts) count is: 29
P28 (USERDATA) [0xe9400000 0] Size: 0.0B
Build ID: MMB29T
Release ID: 6.0.1
Done.
Old 07-11-2017, 10:01   #108 (permalink)
Wingstel's Avatar
Member: 1077758
Sonork: 100.1619202
Thanks Meter: 433
Exclamation samsung G532F Boot repair done but still dead
flash after dead
how to solved help anybody
Old 07-11-2017, 10:16   #109 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 186
Originally Posted by Wingstel View Post
flash after dead
detect emmc and upload log for better help
The Following User Says Thank You to ilyasrao For This Useful Post:
Old 07-11-2017, 15:57   #110 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 422
flash after dead
Need full logs with Read Soft Partitions.
Old 07-11-2017, 16:18   #111 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 838
sir see full logs with Read Soft Partitions
Old 07-11-2017, 16:20   #112 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 422
need logs with Easy Jtag tool.
Old 07-11-2017, 16:47   #113 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 838
EasyJtag Suite ver.: 2.3.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7600).
undefined
Android Explorer ver.: 1.0.0.6
eMMC ODIN ver.: 1.0.0.8
Successfully connected to box on COM5
Box S/N: 0CFF4012558EC295, ,FW Ver.: 01.58
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AAE8-ECBB , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [JTAG] : ACTIVATED
Checking NAND Image : C:\Users\nazmul\Desktop\New folder\Samsung_SM-G532F_dump_rom1_192mb\Samsung_SM-G532F_dump_rom1_192mb.bin
File successefuly loaded!
Processing file...C:\Users\nazmul\Desktop\New folder\Samsung_SM-G532F_dump_rom1_192mb\Samsung_SM-G532F_dump_rom1_192mb.bin
Z3X EasyJtag Software ver. 2.3.0.0
CMD Pullup Level:2052 mVCMD Active Level:2310 mV
Input file : C:\Users\nazmul\Desktop\New folder\Samsung_SM-G532F_dump_rom1_192mb\Samsung_SM-G532F_dump_rom1_192mb.binWriting 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 1337 kB/s
Old 07-11-2017, 17:26   #114 (permalink)
Member: 794019
Thanks Meter: 29
detection log sir not flashing log.
Old 07-11-2017, 20:27   #115 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,146
using old firmware will not help always use latest firmware for boot repair
Old 07-11-2017, 21:10   #116 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 130
I checked many time this model for boot repair but all times fail. Easy jtag write by vender have many bugs and complecations.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 07-19-2017, 17:51   #117 (permalink)
Member: 2024815
Thanks Meter: 2
Question G532G no power after boot repair
hi evryone mi probleme is with G532G dead during flash i repaired boot using easyjtag successfully but phone not power also probleme with G532f repair done using rom1 rom2 writh flash direct emmc but phone sttile dead i need helpe of you thanks in advance.
Old 07-19-2017, 17:55   #118 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 130
I was. faced sam problem with easyjtag. I think some thing wrong with this model..
Old 07-19-2017, 17:59   #119 (permalink)
Member: 2024815
Thanks Meter: 2
yes bro same for me i tried with 2 the first after repair just vibrat the second after repair no power
Old 07-19-2017, 18:26   #120 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 130
Did you try with any other box?
Sent from my Phone.
Page generated in 0.48612 seconds with 8 queries
