Old 07-19-2017, 17:28   #121 (permalink)
Crazy Poster
Member: 2024815
Thanks Meter: 6
Originally Posted by Jani-Jan View Post
Did you try with any other box?
Sent from my Phone.
no bro just easyjtag
Old 07-24-2017, 05:36   #122 (permalink)
Member: 2506794
Sonork: 100.1675120
Thanks Meter: 118
same problem..g532g repair done but no power..help z3x team,..
Old 07-24-2017, 06:54   #123 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Originally Posted by hiifi View Post
hi evryone mi probleme is with G532G dead during flash i repaired boot using easyjtag successfully but phone not power also probleme with G532f repair done using rom1 rom2 writh flash direct emmc but phone sttile dead i need helpe of you thanks in advance.
You can follow flowing link and post result
Samsung G532G dead boot repair done
The Following User Says Thank You to maxpro12 For This Useful Post:
Old 07-29-2017, 17:52   #124 (permalink)
Member: 2236331
Thanks Meter: 36
my samsung g532f repair ok but still death..... any solution bro.............
Old 07-29-2017, 19:39   #125 (permalink)
Crazy Poster
Member: 2024815
Thanks Meter: 6
i need help about boot G532g tried with 4 phone dead boot no power after repair can any one help me to solve my problem where is the team ?
Old 07-29-2017, 19:43   #126 (permalink)
Crazy Poster
Member: 2024815
Thanks Meter: 6
Originally Posted by Shohel_sst View Post
Here is repair file
https://www.4shared.com/rar/Ekr7Q9iu...AIR_FILE.html?
After repair flash this file or latest file G532G_DXU1AQA4_OLB1AQB1
download from z3x support.
tried with 4 phone but same problem bro
Old 07-30-2017, 09:16   #127 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
Another g532g dead boot repair done
HiPower mode is OFF
CMD Pullup Level: 2052 mV
CMD Active Level: 2464 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920135C9992034BE
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX
EMMC NAME: H8G4u , S/N: 35C99920 , rev. 01
EMMC NAME (HEX): 483847347592
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Backup saved: H8G4u_35C99920_20170730_141059.extcsd
EMMC Init completed.
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 180.58 Kb/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 711.31 Kb/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 15.64 Kb/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 696.12 Kb/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 743.68 Kb/s
All done
Old 07-30-2017, 11:54   #128 (permalink)
Crazy Poster
Member: 2024815
Thanks Meter: 6
also tried with this but still dead somthing is worrong i need support from team
Old 07-30-2017, 11:55   #129 (permalink)
Crazy Poster
Member: 2024815
Thanks Meter: 6
HiPower mode is OFF
Partition name: LK
All done
can you give me litle help
Old 08-02-2017, 07:45   #130 (permalink)
Member: 570373
Thanks Meter: 236
eMMC_tool Suite ver. 1.0.0.47
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2008
Setting IO Levels to 2.8V
Setting frequence to 14 Mhz
HiPower mode is OFF
EasyJTAG Box Serial = 0800200
Card Serial = AA9
EasyJTAG Box Firmware = 01.58
Changelog:
28.05.2017 (ver 1.0.0.47)
Fix: Bugs that have been found through your crash report
Fix: Searching for partitions when scanning MBR
Fix: Searching for MassStorage devices
Add: AutoUpdate for the program
HiPower mode is OFF
CMD Pullup Level: 2815 mV
CMD Active Level: 2774 mV
Can't init device. Reason: CMD Timeout Error
HiPower mode is OFF
CMD Pullup Level: 3196 mV
CMD Active Level: 3031 mV
pls help me
Old 08-03-2017, 05:07   #131 (permalink)
WINDA's Avatar
Member: 804772
Thanks Meter: 129
please i need pit for samsung g532 j2 prime sir
Old 08-04-2017, 05:39   #132 (permalink)
Member: 2459405
Thanks Meter: 17
is this pinout same with g532g/ds?
I tried but did not..always Can't init device. Reason: CMD Timeout Error
Old 08-04-2017, 05:53   #133 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
make sure you connection problem.
Old 08-04-2017, 05:54   #134 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
check pinout may be your connection problem
The Following User Says Thank You to Shohel_sst For This Useful Post:
Old 08-06-2017, 15:17   #135 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
HiPower mode is OFF
CMD Pullup Level: 2103 mV
CMD Active Level: 2897 mV
EMMC CID: 90014A4838473475920120E6ACFC549C
EMMC NAME: H8G4u , S/N: 20E6ACFC , rev. 01
Backup saved: H8G4u_20E6ACFC_20170806_201351.extcsd
Done writing partition. Write speed: 201.36 Kb/s
Partition name: LK
Done writing partition. Write speed: 721.74 Kb/s
Done writing partition. Write speed: 15.82 Kb/s
Done writing partition. Write speed: 740.26 Kb/s
Done writing partition. Write speed: 748.00 Kb/s
All done
Page generated in 0.23985 seconds with 10 queries
