12-05-2019, 16:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: @India
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | Getting Error In Flashing Oppo A3s Using ISP Pinout Need Help!!! Model-A3s Here Is Log Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 1887 mV CMD Active Level: 2052 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 MHz CMD Pullup Level: 1980 mV CMD Active Level: 2681 mV EMMC Device Information : EMMC CID: 150100514536334D42039981CEDE457A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 9981CEDE , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_9981CEDE_20191205_210049.extcsd EMMC Init completed. Get firmware version Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Brand = OPPO Device = CPH1803 Model = CPH1803 Firmware version = CPH1803EX_11_A.20 Firmware date = Mon Sep 23 22:31:13 CST 2019 Setting frequence to 21 MHz CMD Pullup Level: 1980 mV CMD Active Level: 2670 mV EMMC Device Information : EMMC CID: 150100514536334D42039981CEDE457A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 9981CEDE , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_9981CEDE_20191205_210109.extcsd EMMC Init completed. Opening file: rawprogram0.xml The size of the last section has been updated Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2670 mV EMMC Device Information : EMMC CID: 150100514536334D42039981CEDE457A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 9981CEDE , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_9981CEDE_20191205_210117.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: -7 , DATA SND Timeout Error ... Retry #1 Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #2 Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped |
12-05-2019, 17:20 | #2 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,075 | 1st Scan soft partitions. if not found write .extcsd file (Boot cfg) again Scan soft partitions if found. then write file |
The Following User Says Thank You to raisalina For This Useful Post: |
12-05-2019, 17:43 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | try to read sticked topics http://forum.gsmhosting.com/vbb/f672...ution-2585863/ |
The Following User Says Thank You to layder For This Useful Post: |
12-07-2019, 12:14 | #4 (permalink) | |
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | Quote:
Operation not allowed , confirmation password not match! | |
12-08-2019, 12:30 | #6 (permalink) |
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | Running:JEDEC: Partitions config burn... Z3X EasyJtag Software ver. 3.6.1.15 Skip loading eMMC Addon Firmware CMD Pullup Level:2021 mV CMD Active Level:3104 mV Box IO Level:3300 mV CLK Rate:14000 kHz GP Multiplier: 800000, 8192 Kb, 8Mb Partition configuration: No enhanced user data area User partition write reliability: off No GP1 partition GP1 write reliability: on No GP2 partition GP2 write reliability: off No GP3 partition GP3 write reliability: off No GP4 partition GP4 write reliability: off All GP Partitions are 0 set size of at least one GP Partition HW Parts Config Fail. |
12-08-2019, 14:30 | #7 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Philippines
Member: 405730 Status: Offline Thanks Meter: 184 | Quote:
go to setting tab and check ( allow creat gpp zero ) | |
12-12-2019, 13:50 | #8 (permalink) |
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | Running:JEDEC: Partitions config burn... Z3X EasyJtag Software ver. 3.6.1.15 Skip loading eMMC Addon Firmware CMD Pullup Level:2000 mV CMD Active Level:2475 mV Box IO Level:3300 mV CLK Rate:14000 kHz GP Multiplier: 800000, 8192 Kb, 8Mb Partition configuration: No enhanced user data area User partition write reliability: off No GP1 partition GP1 write reliability: on No GP2 partition GP2 write reliability: off No GP3 partition GP3 write reliability: off No GP4 partition GP4 write reliability: off Card does not support host controlled partition write reliability settings HW Parts Config Fail. |
