05-06-2022, 15:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | vivo y20 stuck on vivo logo and press any key to shutdown support team please help, one vivo y20 stuck on *press any key to shutdown* and vivo logo i flashed ufs bga with this file (PD2034F_EX_A_1.71.4_vivo_qcom_LA.UM.8.15.r1-02500-KAMORTA_split) but problem still same please help bahri |
05-17-2022, 14:37 | #5 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | vivo y20 v2029 ufs / after flash same problem : press any key to shutdown 17-05-2022 12:11:49> eMMC_tool ver. 2.0.1.0 (release date: 05.05.2021) 17-05-2022 12:11:49> Microsoft Windows 10 (64 bit) build 19043 (10.0.19041.1706) 17-05-2022 12:11:49> 17-05-2022 12:11:49> Looking for EasyJTAG box... 17-05-2022 12:11:49> EasyJTAG API ver. 3403 17-05-2022 12:11:50> OpenUSB return = 0 17-05-2022 12:11:50> EasyJTAG Box Serial = 7117BF7844FC6CC4 17-05-2022 12:11:51> Card Serial = AA8CC7CE 17-05-2022 12:11:51> EasyJTAG Box Firmware = 2.5302 17-05-2022 12:11:51> 17-05-2022 12:11:53> 17-05-2022 12:12:33> Operation: Connect to Z3X EasyJtagPlus 17-05-2022 12:12:33> 17-05-2022 12:12:34> Setting Interface to EasyJtag2/E-Socket 17-05-2022 12:12:34> Setting IO Levels to 2.8V 17-05-2022 12:12:34> Setting Frequence to 1 Mhz 17-05-2022 12:12:34> Setting BusWidth to Auto 17-05-2022 12:12:35> Setting HS Timing to Enabled 17-05-2022 12:12:35> 17-05-2022 12:12:35> OpenUSB return = -17 17-05-2022 12:12:35> Can't init device. Error: -17. Reason: Command Index Error 17-05-2022 12:12:35> 17-05-2022 12:12:53> Canceled 17-05-2022 12:12:53> 17-05-2022 12:13:08> OpenUFS return = -51 17-05-2022 12:13:17> Operation: Connect to Z3X EasyJtagPlus 17-05-2022 12:13:17> 17-05-2022 12:13:18> OpenUFS return = -51 17-05-2022 12:13:18> Setting Interface to EasyJtag2/UFS-Socket 17-05-2022 12:13:18> Setting IO Levels to Low 17-05-2022 12:13:18> Setting Frequence to 66 Mhz 17-05-2022 12:13:18> 17-05-2022 12:13:18> Can't init device. Error: -51. Reason: BOX: Socket not detected 17-05-2022 12:13:18> 17-05-2022 12:13:32> Operation: Connect to Z3X EasyJtagPlus 17-05-2022 12:13:32> 17-05-2022 12:13:35> Setting Interface to EasyJtag2/UFS-Socket 17-05-2022 12:13:35> Setting IO Levels to Low 17-05-2022 12:13:35> Setting Frequence to 66 Mhz 17-05-2022 12:13:35> 17-05-2022 12:13:52> Socket Information : 17-05-2022 12:13:52> Socket Mark: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 17-05-2022 12:13:52> Socket Serial: 0123687D97CA215DEE 17-05-2022 12:13:52> Socket Type: UFS_SOCKET_3_IN_1 17-05-2022 12:13:52> UFS Power Information : 17-05-2022 12:13:52> Mode: Low, VCC: 3222 mV, VCCQ2: 1791 mV 17-05-2022 12:13:52> UFS Device Information : 17-05-2022 12:13:52> UFS Manufacturer: SKhynix, UFS ProductName: H9HQ53ACPMMDAR 17-05-2022 12:13:52> UFS OemID: 01AD, UFS SerialNumber: 0x0DB068E4BA88 17-05-2022 12:13:52> Maximum Number of LUs: 32, Number of LUs found: 6, Number of WLUs found: 1, LUs Re-configure: Enabled 17-05-2022 12:13:52> RPMB Counter: 62327 17-05-2022 12:13:52> UFS LUN 0 Capacity: 59912 MB (000EA0800000) 17-05-2022 12:13:52> UFS LUN 1 (Boot A) Capacity: 8 MB (000000800000) 17-05-2022 12:13:52> UFS LUN 2 (Boot B) Capacity: 8 MB (000000800000) 17-05-2022 12:13:52> UFS LUN 3 Capacity: 32 MB (000002000000) 17-05-2022 12:13:53> UFS LUN 4 Capacity: 1024 MB (000040000000) 17-05-2022 12:13:53> UFS LUN 5 Capacity: 32 MB (000002000000) 17-05-2022 12:13:53> UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000) 17-05-2022 12:13:53> 17-05-2022 12:13:53> Device Life Time Estimation B: 0x01 0% - 10% device life time used 17-05-2022 12:13:53> Device Life Time Estimation A: 0x01 0% - 10% device life time used 17-05-2022 12:13:53> Pre EOL information: 0x01 Normal (Consumed less then 80% of reserved block) 17-05-2022 12:13:53> 17-05-2022 12:13:53> Do not turn the socket before you press "Close Session" button 17-05-2022 12:13:53> 17-05-2022 12:13:53> Connected successfully 17-05-2022 12:13:53> 17-05-2022 12:13:54> Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write) 17-05-2022 12:13:54> 17-05-2022 12:13:54> Scanning soft partitions from LUN 0 17-05-2022 12:13:54> GPT header is found 17-05-2022 12:14:05> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:14:05> Partition: ssd, [000000006000 - 000000008000], Size: 000000002000 (8.00 KB), Type: Raw 17-05-2022 12:14:06> Partition: persist, [000000008000 - 000002008000], Size: 000002000000 (32.00 MB), Type: Linux (/persist) 17-05-2022 12:14:06> Partition: misc, [000002008000 - 000002108000], Size: 000000100000 (1.00 MB), Type: Raw 17-05-2022 12:14:06> Partition: keystore, [000002108000 - 000002188000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:14:06> Partition: frp, [000002188000 - 000002208000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:14:07> Partition: metadata, [000002208000 - 000003208000], Size: 000001000000 (16.00 MB), Type: Linux 17-05-2022 12:14:07> Partition: rawdump, [000003208000 - 00000B208000], Size: 000008000000 (128.00 MB), Type: Blank 17-05-2022 12:14:07> Partition: storage, [00000B208000 - 00000F208000], Size: 000004000000 (64.00 MB), Type: Raw 17-05-2022 12:14:07> Partition: recovery, [00000F208000 - 000015208000], Size: 000006000000 (96.00 MB), Type: Boot 17-05-2022 12:14:07> Partition: survival, [000015208000 - 00001B208000], Size: 000006000000 (96.00 MB), Type: Boot 17-05-2022 12:14:07> Partition: seed, [00001B208000 - 00001B608000], Size: 000000400000 (4.00 MB), Type: Blank 17-05-2022 12:14:07> Partition: apanic, [00001B608000 - 00001C008000], Size: 000000A00000 (10.00 MB), Type: Blank 17-05-2022 12:14:07> Partition: backup, [00001C008000 - 00001CA08000], Size: 000000A00000 (10.00 MB), Type: Raw 17-05-2022 12:14:07> Partition: reserved, [00001CA08000 - 00001D408000], Size: 000000A00000 (10.00 MB), Type: Blank 17-05-2022 12:14:08> Partition: vgc, [00001D408000 - 000029C08000], Size: 00000C800000 (200.00 MB), Type: Linux (/vgc) 17-05-2022 12:14:08> Partition: oem, [000029C08000 - 00002DC08000], Size: 000004000000 (64.00 MB), Type: Linux (/oem) 17-05-2022 12:14:09> Partition: vbmeta_system, [00002DC08000 - 00002DC18000], Size: 000000010000 (64.00 KB), Type: Raw 17-05-2022 12:14:09> Partition: super, [00002DC18000 - 00024DC18000], Size: 000220000000 (8.50 GB), Type: Super 17-05-2022 12:14:09> Partition: system, [00002DD18000 - 00013B5C2000], Size: 00010D8AA000 (4.21 GB), Type: Linux 17-05-2022 12:14:09> Partition: vendor, [00013B618000 - 000177401000], Size: 00003BDE9000 (957.91 MB), Type: Linux 17-05-2022 12:14:09> Partition: cache, [00024DC18000 - 00025DC18000], Size: 000010000000 (256.00 MB), Type: Linux (/cache) 17-05-2022 12:14:09> Partition: userdata, [00025DC18000 - 000EA07FB000], Size: 000C42BE3000 (49.04 GB), Type: Blank 17-05-2022 12:14:10> Partition: BackupGPT, [000EA07FB000 - 000EA0800000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:14:10> GPT header successfully parsed 17-05-2022 12:14:10> 17-05-2022 12:14:10> Scanning soft partitions from LUN 1 (Boot A) 17-05-2022 12:14:10> GPT header is found 17-05-2022 12:14:13> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:14:13> Partition: xbl, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw 17-05-2022 12:14:13> Partition: xbl_config, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:14:13> Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank 17-05-2022 12:14:13> Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:14:13> GPT header successfully parsed 17-05-2022 12:14:13> 17-05-2022 12:14:13> Scanning soft partitions from LUN 2 (Boot B) 17-05-2022 12:14:14> GPT header is found 17-05-2022 12:14:16> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:14:16> Partition: xblbak, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw 17-05-2022 12:14:16> Partition: xbl_configbak, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:14:16> Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank 17-05-2022 12:14:17> Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:14:17> GPT header successfully parsed 17-05-2022 12:14:17> 17-05-2022 12:14:17> Scanning soft partitions from LUN 3 17-05-2022 12:14:17> GPT header is found 17-05-2022 12:14:20> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:14:20> Partition: ALIGN_TO_128K_1, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank 17-05-2022 12:14:20> Partition: cdt, [000000020000 - 000000040000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:14:20> Partition: ddr, [000000040000 - 000000140000], Size: 000000100000 (1.00 MB), Type: Raw 17-05-2022 12:14:20> Partition: last_parti, [000000140000 - 000001FFB000], Size: 000001EBB000 (30.73 MB), Type: Blank 17-05-2022 12:14:21> Partition: BackupGPT, [000001FFB000 - 000002000000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:14:21> GPT header successfully parsed 17-05-2022 12:14:21> 17-05-2022 12:14:21> Scanning soft partitions from LUN 4 17-05-2022 12:14:21> GPT header is found 17-05-2022 12:14:39> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:14:39> Partition: rpm, [000000006000 - 000000086000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:14:39> Partition: tz, [000000086000 - 000000486000], Size: 000000400000 (4.00 MB), Type: Raw 17-05-2022 12:14:39> Partition: hyp, [000000486000 - 000000506000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:14:39> Partition: modem, [000000506000 - 000010506000], Size: 000010000000 (256.00 MB), Type: Fat16 17-05-2022 12:14:39> Partition: bluetooth, [000010506000 - 000010606000], Size: 000000100000 (1.00 MB), Type: Fat16 17-05-2022 12:14:39> Partition: mdtpsecapp, [000010606000 - 000010A06000], Size: 000000400000 (4.00 MB), Type: Blank 17-05-2022 12:14:39> Partition: mdtp, [000010A06000 - 000012A06000], Size: 000002000000 (32.00 MB), Type: Blank 17-05-2022 12:14:40> Partition: abl, [000012A06000 - 000016A06000], Size: 000004000000 (64.00 MB), Type: Raw 17-05-2022 12:14:40> Partition: dsp, [000016A06000 - 000018A06000], Size: 000002000000 (32.00 MB), Type: Linux 17-05-2022 12:14:40> Partition: keymaster, [000018A06000 - 000018A86000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:14:40> Partition: boot, [000018A86000 - 00001EA86000], Size: 000006000000 (96.00 MB), Type: Boot 17-05-2022 12:14:40> Partition: cmnlib, [00001EA86000 - 00001EB06000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:14:41> Partition: cmnlib64, [00001EB06000 - 00001EB86000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:14:41> Partition: devcfg, [00001EB86000 - 00001EBA6000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:14:41> Partition: qupfw, [00001EBA6000 - 00001EBB6000], Size: 000000010000 (64.00 KB), Type: Raw 17-05-2022 12:14:41> Partition: vbmeta, [00001EBB6000 - 00001EBC6000], Size: 000000010000 (64.00 KB), Type: Raw 17-05-2022 12:14:41> Partition: dtbo, [00001EBC6000 - 0000203C6000], Size: 000001800000 (24.00 MB), Type: Raw 17-05-2022 12:14:41> Partition: imagefv, [0000203C6000 - 0000205C6000], Size: 000000200000 (2.00 MB), Type: Raw 17-05-2022 12:14:41> Partition: featenabler, [0000205C6000 - 0000205E6000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:14:41> Partition: uefisecapp, [0000205E6000 - 0000207E6000], Size: 000000200000 (2.00 MB), Type: Raw 17-05-2022 12:14:42> Partition: devinfo, [0000207E6000 - 0000207E7000], Size: 000000001000 (4.00 KB), Type: Raw 17-05-2022 12:14:42> Partition: dip, [0000207E7000 - 0000208E7000], Size: 000000100000 (1.00 MB), Type: Blank 17-05-2022 12:14:42> Partition: apdp, [0000208E7000 - 000020927000], Size: 000000040000 (256.00 KB), Type: Raw 17-05-2022 12:14:42> Partition: spunvm, [000020927000 - 000021127000], Size: 000000800000 (8.00 MB), Type: Blank 17-05-2022 12:14:42> Partition: splash, [000021127000 - 0000231CB000], Size: 0000020A4000 (32.64 MB), Type: Blank 17-05-2022 12:14:42> Partition: limits, [0000231CB000 - 0000231CC000], Size: 000000001000 (4.00 KB), Type: Blank 17-05-2022 12:14:42> Partition: toolsfv, [0000231CC000 - 0000232CC000], Size: 000000100000 (1.00 MB), Type: Blank 17-05-2022 12:14:42> Partition: logfs, [0000232CC000 - 000023ACC000], Size: 000000800000 (8.00 MB), Type: Fat12 17-05-2022 12:14:43> Partition: cateloader, [000023ACC000 - 000023CCC000], Size: 000000200000 (2.00 MB), Type: Blank 17-05-2022 12:14:43> Partition: logdump, [000023CCC000 - 000027CCC000], Size: 000004000000 (64.00 MB), Type: Raw 17-05-2022 12:14:43> Partition: storsec, [000027CCC000 - 000027CEC000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:14:43> Partition: multiimgoem, [000027CEC000 - 000027CF4000], Size: 000000008000 (32.00 KB), Type: Raw 17-05-2022 12:14:43> Partition: multiimgqti, [000027CF4000 - 000027CFC000], Size: 000000008000 (32.00 KB), Type: Raw 17-05-2022 12:14:43> Partition: uefivarstore, [000027CFC000 - 000027D7C000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:14:43> Partition: secdata, [000027D7C000 - 000027D83000], Size: 000000007000 (28.00 KB), Type: Raw 17-05-2022 12:14:44> Partition: catefv, [000027D83000 - 000027E03000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:14:44> Partition: catecontentfv, [000027E03000 - 000027F03000], Size: 000000100000 (1.00 MB), Type: Blank 17-05-2022 12:14:44> Partition: last_parti, [000027F03000 - 00003FFFB000], Size: 0000180F8000 (384.97 MB), Type: Blank 17-05-2022 12:14:44> Partition: BackupGPT, [00003FFFB000 - 000040000000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:14:44> GPT header successfully parsed 17-05-2022 12:14:44> 17-05-2022 12:14:44> Scanning soft partitions from LUN 5 17-05-2022 12:14:45> GPT header is found 17-05-2022 12:14:48> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:14:48> Partition: ALIGN_TO_128K_2, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank 17-05-2022 12:14:49> Partition: modemst1, [000000020000 - 000000320000], Size: 000000300000 (3.00 MB), Type: Blank 17-05-2022 12:14:49> Partition: modemst2, [000000320000 - 000000620000], Size: 000000300000 (3.00 MB), Type: Blank 17-05-2022 12:14:49> Partition: fsg, [000000620000 - 000000920000], Size: 000000300000 (3.00 MB), Type: Raw 17-05-2022 12:14:49> Partition: fsc, [000000920000 - 000000940000], Size: 000000020000 (128.00 KB), Type: Blank 17-05-2022 12:14:49> Partition: last_parti, [000000940000 - 000001FFB000], Size: 0000016BB000 (22.73 MB), Type: Blank 17-05-2022 12:14:49> Partition: BackupGPT, [000001FFB000 - 000002000000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:14:49> GPT header successfully parsed 17-05-2022 12:14:58> 17-05-2022 12:14:58> Operation: Scan PartitionTable from Source (Vendor: Qualcomm) 17-05-2022 12:14:58> 17-05-2022 12:14:58> Scanning soft partitions from LUN 0 17-05-2022 12:14:58> GPT header is found 17-05-2022 12:15:09> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:15:09> Partition: ssd, [000000006000 - 000000008000], Size: 000000002000 (8.00 KB), Type: Raw 17-05-2022 12:15:10> Partition: persist, [000000008000 - 000002008000], Size: 000002000000 (32.00 MB), Type: Linux (/persist) 17-05-2022 12:15:10> Partition: misc, [000002008000 - 000002108000], Size: 000000100000 (1.00 MB), Type: Raw 17-05-2022 12:15:10> Partition: keystore, [000002108000 - 000002188000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:15:10> Partition: frp, [000002188000 - 000002208000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:15:11> Partition: metadata, [000002208000 - 000003208000], Size: 000001000000 (16.00 MB), Type: Linux 17-05-2022 12:15:11> Partition: rawdump, [000003208000 - 00000B208000], Size: 000008000000 (128.00 MB), Type: Blank 17-05-2022 12:15:11> Partition: storage, [00000B208000 - 00000F208000], Size: 000004000000 (64.00 MB), Type: Raw 17-05-2022 12:15:11> Partition: recovery, [00000F208000 - 000015208000], Size: 000006000000 (96.00 MB), Type: Boot 17-05-2022 12:15:11> Partition: survival, [000015208000 - 00001B208000], Size: 000006000000 (96.00 MB), Type: Boot 17-05-2022 12:15:11> Partition: seed, [00001B208000 - 00001B608000], Size: 000000400000 (4.00 MB), Type: Blank 17-05-2022 12:15:12> Partition: apanic, [00001B608000 - 00001C008000], Size: 000000A00000 (10.00 MB), Type: Blank 17-05-2022 12:15:12> Partition: backup, [00001C008000 - 00001CA08000], Size: 000000A00000 (10.00 MB), Type: Raw 17-05-2022 12:15:12> Partition: reserved, [00001CA08000 - 00001D408000], Size: 000000A00000 (10.00 MB), Type: Blank 17-05-2022 12:15:12> Partition: vgc, [00001D408000 - 000029C08000], Size: 00000C800000 (200.00 MB), Type: Linux (/vgc) 17-05-2022 12:15:13> Partition: oem, [000029C08000 - 00002DC08000], Size: 000004000000 (64.00 MB), Type: Linux (/oem) 17-05-2022 12:15:13> Partition: vbmeta_system, [00002DC08000 - 00002DC18000], Size: 000000010000 (64.00 KB), Type: Raw 17-05-2022 12:15:13> Partition: super, [00002DC18000 - 00024DC18000], Size: 000220000000 (8.50 GB), Type: Super 17-05-2022 12:15:13> Partition: system, [00002DD18000 - 00013B5C2000], Size: 00010D8AA000 (4.21 GB), Type: Linux 17-05-2022 12:15:14> Partition: vendor, [00013B618000 - 000177401000], Size: 00003BDE9000 (957.91 MB), Type: Linux 17-05-2022 12:15:14> Partition: cache, [00024DC18000 - 00025DC18000], Size: 000010000000 (256.00 MB), Type: Linux (/cache) 17-05-2022 12:15:14> Partition: userdata, [00025DC18000 - 000EA07FB000], Size: 000C42BE3000 (49.04 GB), Type: Blank 17-05-2022 12:15:14> Partition: BackupGPT, [000EA07FB000 - 000EA0800000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:15:14> GPT header successfully parsed 17-05-2022 12:15:15> 17-05-2022 12:15:15> Scanning soft partitions from LUN 1 (Boot A) 17-05-2022 12:15:15> GPT header is found 17-05-2022 12:15:18> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:15:18> Partition: xbl, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw 17-05-2022 12:15:18> Partition: xbl_config, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:15:18> Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank 17-05-2022 12:15:18> Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:15:18> GPT header successfully parsed 17-05-2022 12:15:18> 17-05-2022 12:15:18> Scanning soft partitions from LUN 2 (Boot B) 17-05-2022 12:15:19> GPT header is found 17-05-2022 12:15:21> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:15:21> Partition: xblbak, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw 17-05-2022 12:15:22> Partition: xbl_configbak, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:15:22> Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank 17-05-2022 12:15:22> Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:15:22> GPT header successfully parsed 17-05-2022 12:15:22> 17-05-2022 12:15:22> Scanning soft partitions from LUN 3 17-05-2022 12:15:23> GPT header is found 17-05-2022 12:15:25> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:15:25> Partition: ALIGN_TO_128K_1, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank 17-05-2022 12:15:26> Partition: cdt, [000000020000 - 000000040000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:15:26> Partition: ddr, [000000040000 - 000000140000], Size: 000000100000 (1.00 MB), Type: Raw 17-05-2022 12:15:26> Partition: last_parti, [000000140000 - 000001FFB000], Size: 000001EBB000 (30.73 MB), Type: Blank 17-05-2022 12:15:26> Partition: BackupGPT, [000001FFB000 - 000002000000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:15:26> GPT header successfully parsed 17-05-2022 12:15:26> 17-05-2022 12:15:26> Scanning soft partitions from LUN 4 17-05-2022 12:15:27> GPT header is found 17-05-2022 12:15:44> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:15:44> Partition: rpm, [000000006000 - 000000086000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:15:45> Partition: tz, [000000086000 - 000000486000], Size: 000000400000 (4.00 MB), Type: Raw 17-05-2022 12:15:45> Partition: hyp, [000000486000 - 000000506000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:15:45> Partition: modem, [000000506000 - 000010506000], Size: 000010000000 (256.00 MB), Type: Fat16 17-05-2022 12:15:45> Partition: bluetooth, [000010506000 - 000010606000], Size: 000000100000 (1.00 MB), Type: Fat16 17-05-2022 12:15:45> Partition: mdtpsecapp, [000010606000 - 000010A06000], Size: 000000400000 (4.00 MB), Type: Blank 17-05-2022 12:15:45> Partition: mdtp, [000010A06000 - 000012A06000], Size: 000002000000 (32.00 MB), Type: Blank 17-05-2022 12:15:46> Partition: abl, [000012A06000 - 000016A06000], Size: 000004000000 (64.00 MB), Type: Raw 17-05-2022 12:15:46> Partition: dsp, [000016A06000 - 000018A06000], Size: 000002000000 (32.00 MB), Type: Linux 17-05-2022 12:15:46> Partition: keymaster, [000018A06000 - 000018A86000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:15:46> Partition: boot, [000018A86000 - 00001EA86000], Size: 000006000000 (96.00 MB), Type: Boot 17-05-2022 12:15:47> Partition: cmnlib, [00001EA86000 - 00001EB06000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:15:47> Partition: cmnlib64, [00001EB06000 - 00001EB86000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:15:47> Partition: devcfg, [00001EB86000 - 00001EBA6000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:15:47> Partition: qupfw, [00001EBA6000 - 00001EBB6000], Size: 000000010000 (64.00 KB), Type: Raw 17-05-2022 12:15:47> Partition: vbmeta, [00001EBB6000 - 00001EBC6000], Size: 000000010000 (64.00 KB), Type: Raw 17-05-2022 12:15:47> Partition: dtbo, [00001EBC6000 - 0000203C6000], Size: 000001800000 (24.00 MB), Type: Raw 17-05-2022 12:15:48> Partition: imagefv, [0000203C6000 - 0000205C6000], Size: 000000200000 (2.00 MB), Type: Raw 17-05-2022 12:15:48> Partition: featenabler, [0000205C6000 - 0000205E6000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:15:48> Partition: uefisecapp, [0000205E6000 - 0000207E6000], Size: 000000200000 (2.00 MB), Type: Raw 17-05-2022 12:15:48> Partition: devinfo, [0000207E6000 - 0000207E7000], Size: 000000001000 (4.00 KB), Type: Raw 17-05-2022 12:15:48> Partition: dip, [0000207E7000 - 0000208E7000], Size: 000000100000 (1.00 MB), Type: Blank 17-05-2022 12:15:48> Partition: apdp, [0000208E7000 - 000020927000], Size: 000000040000 (256.00 KB), Type: Raw 17-05-2022 12:15:49> Partition: spunvm, [000020927000 - 000021127000], Size: 000000800000 (8.00 MB), Type: Blank 17-05-2022 12:15:49> Partition: splash, [000021127000 - 0000231CB000], Size: 0000020A4000 (32.64 MB), Type: Blank 17-05-2022 12:15:49> Partition: limits, [0000231CB000 - 0000231CC000], Size: 000000001000 (4.00 KB), Type: Blank 17-05-2022 12:15:49> Partition: toolsfv, [0000231CC000 - 0000232CC000], Size: 000000100000 (1.00 MB), Type: Blank 17-05-2022 12:15:49> Partition: logfs, [0000232CC000 - 000023ACC000], Size: 000000800000 (8.00 MB), Type: Fat12 17-05-2022 12:15:49> Partition: cateloader, [000023ACC000 - 000023CCC000], Size: 000000200000 (2.00 MB), Type: Blank 17-05-2022 12:15:50> Partition: logdump, [000023CCC000 - 000027CCC000], Size: 000004000000 (64.00 MB), Type: Raw 17-05-2022 12:15:50> Partition: storsec, [000027CCC000 - 000027CEC000], Size: 000000020000 (128.00 KB), Type: Raw 17-05-2022 12:15:50> Partition: multiimgoem, [000027CEC000 - 000027CF4000], Size: 000000008000 (32.00 KB), Type: Raw 17-05-2022 12:15:50> Partition: multiimgqti, [000027CF4000 - 000027CFC000], Size: 000000008000 (32.00 KB), Type: Raw 17-05-2022 12:15:50> Partition: uefivarstore, [000027CFC000 - 000027D7C000], Size: 000000080000 (512.00 KB), Type: Raw 17-05-2022 12:15:51> Partition: secdata, [000027D7C000 - 000027D83000], Size: 000000007000 (28.00 KB), Type: Raw 17-05-2022 12:15:51> Partition: catefv, [000027D83000 - 000027E03000], Size: 000000080000 (512.00 KB), Type: Blank 17-05-2022 12:15:51> Partition: catecontentfv, [000027E03000 - 000027F03000], Size: 000000100000 (1.00 MB), Type: Blank 17-05-2022 12:15:51> Partition: last_parti, [000027F03000 - 00003FFFB000], Size: 0000180F8000 (384.97 MB), Type: Blank 17-05-2022 12:15:51> Partition: BackupGPT, [00003FFFB000 - 000040000000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:15:51> GPT header successfully parsed 17-05-2022 12:15:51> 17-05-2022 12:15:52> Scanning soft partitions from LUN 5 17-05-2022 12:15:52> GPT header is found 17-05-2022 12:15:56> Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT 17-05-2022 12:15:56> Partition: ALIGN_TO_128K_2, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank 17-05-2022 12:15:56> Partition: modemst1, [000000020000 - 000000320000], Size: 000000300000 (3.00 MB), Type: Blank 17-05-2022 12:15:56> Partition: modemst2, [000000320000 - 000000620000], Size: 000000300000 (3.00 MB), Type: Blank 17-05-2022 12:15:56> Partition: fsg, [000000620000 - 000000920000], Size: 000000300000 (3.00 MB), Type: Raw 17-05-2022 12:15:57> Partition: fsc, [000000920000 - 000000940000], Size: 000000020000 (128.00 KB), Type: Blank 17-05-2022 12:15:57> Partition: last_parti, [000000940000 - 000001FFB000], Size: 0000016BB000 (22.73 MB), Type: Blank 17-05-2022 12:15:57> Partition: BackupGPT, [000001FFB000 - 000002000000], Size: 000000005000 (20.00 KB), Type: BackupGPT 17-05-2022 12:15:57> GPT header successfully parsed 17-05-2022 12:16:33> 17-05-2022 12:16:33> Operation: Opening Firmware (Qualcomm) 17-05-2022 12:16:33> 17-05-2022 12:16:33> Firmware: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\ 17-05-2022 12:16:36> 17-05-2022 12:16:37> Rom: LUN 0, File: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rawprogram_unsparse0.xml 17-05-2022 12:16:39> 17-05-2022 12:16:39> LUN 0: The size of the "USERDATA" partition has been increased 17-05-2022 12:16:39> 17-05-2022 12:16:40> Rom: LUN 1 (Boot A), File: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rawprogram1.xml 17-05-2022 12:16:40> 17-05-2022 12:16:40> LUN 1 (Boot A): The size of the "LAST_PARTI" partition has been increased 17-05-2022 12:16:40> 17-05-2022 12:16:40> Rom: LUN 2 (Boot B), File: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rawprogram2.xml 17-05-2022 12:16:40> 17-05-2022 12:16:40> LUN 2 (Boot B): The size of the "LAST_PARTI" partition has been increased 17-05-2022 12:16:40> 17-05-2022 12:16:41> Rom: LUN 3, File: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rawprogram3.xml 17-05-2022 12:16:41> 17-05-2022 12:16:41> LUN 3: The size of the "LAST_PARTI" partition has been increased 17-05-2022 12:16:41> 17-05-2022 12:16:41> Rom: LUN 4, File: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rawprogram4.xml 17-05-2022 12:16:42> 17-05-2022 12:16:42> LUN 4: The size of the "LAST_PARTI" partition has been increased 17-05-2022 12:16:42> 17-05-2022 12:16:43> Rom: LUN 5, File: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rawprogram5.xml 17-05-2022 12:16:43> 17-05-2022 12:16:43> LUN 5: The size of the "LAST_PARTI" partition has been increased 17-05-2022 12:16:43> 17-05-2022 12:16:46> If the "rawprogram" files are selected incorrectly - you can select them manually 17-05-2022 12:16:47> Double-click on ROM file, change the file type to "Firmware files" and select the correct rawprogram 17-05-2022 12:16:47> 17-05-2022 12:16:47> Opening firmware completed 17-05-2022 12:16:47> 17-05-2022 12:17:25> Operation: Writing by Vendor (Qualcomm) 17-05-2022 12:17:25> Write/Erase check: Disabled 17-05-2022 12:17:25> 17-05-2022 12:17:26> Repartitioning ... 17-05-2022 12:17:26> Rom: LUN 0, Part: PrimaryGPT, Address: 000000000000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_main0.bin 17-05-2022 12:17:27> Rom: LUN 0, Part: BackupGPT, Address: 000EA07FB000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_backup0.bin 17-05-2022 12:17:28> Rom: LUN 1 (Boot A), Part: PrimaryGPT, Address: 000000000000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_main1.bin 17-05-2022 12:17:28> Rom: LUN 1 (Boot A), Part: BackupGPT, Address: 0000007FB000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_backup1.bin 17-05-2022 12:17:29> Rom: LUN 2 (Boot B), Part: PrimaryGPT, Address: 000000000000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_main2.bin 17-05-2022 12:17:30> Rom: LUN 2 (Boot B), Part: BackupGPT, Address: 0000007FB000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_backup2.bin 17-05-2022 12:17:31> Rom: LUN 3, Part: PrimaryGPT, Address: 000000000000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_main3.bin 17-05-2022 12:17:32> Rom: LUN 3, Part: BackupGPT, Address: 000001FFB000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_backup3.bin 17-05-2022 12:17:33> Rom: LUN 4, Part: PrimaryGPT, Address: 000000000000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_main4.bin 17-05-2022 12:17:33> Rom: LUN 4, Part: BackupGPT, Address: 00003FFFB000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_backup4.bin 17-05-2022 12:17:34> Rom: LUN 5, Part: PrimaryGPT, Address: 000000000000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_main5.bin 17-05-2022 12:17:35> Rom: LUN 5, Part: BackupGPT, Address: 000001FFB000, Filename: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\gpt_backup5.bin 17-05-2022 12:17:36> Repartitioning done 17-05-2022 12:17:36> 17-05-2022 12:17:36> Writing: LUN 0, Partition: persist, Offset: 0x000000008000, Size: 0x000002000000 (32.00 MB) 17-05-2022 12:17:36> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\persist_1.img, Offset: 0x000000000000, Size: 0x000000008000 (32.00 KB) 17-05-2022 12:17:37> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\persist_2.img, Offset: 0x000000105000, Size: 0x000000007000 (28.00 KB) 17-05-2022 12:17:38> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\persist_3.img, Offset: 0x00000050B000, Size: 0x000000049000 (292.00 KB) 17-05-2022 12:17:39> Done writing partition (Write speed: 144.02 Kb/s) 17-05-2022 12:17:39> Writing: LUN 0, Partition: storage, Offset: 0x00000B208000, Size: 0x000004000000 (64.00 MB) 17-05-2022 12:17:39> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\firmware.bin, Offset: 0x000000000000, Size: 0x000001000000 (16.00 MB) 17-05-2022 12:17:43> Done writing partition (Write speed: 3942.05 Kb/s) 17-05-2022 12:17:43> Writing: LUN 0, Partition: recovery, Offset: 0x00000F208000, Size: 0x000006000000 (96.00 MB) 17-05-2022 12:17:43> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\recovery.img, Offset: 0x000000000000, Size: 0x000006000000 (96.00 MB) 17-05-2022 12:18:05> Done writing partition (Write speed: 4434.92 Kb/s) 17-05-2022 12:18:05> Writing: LUN 0, Partition: survival, Offset: 0x000015208000, Size: 0x000006000000 (96.00 MB) 17-05-2022 12:18:06> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\survival.img, Offset: 0x000000000000, Size: 0x000006000000 (96.00 MB) 17-05-2022 12:18:28> Done writing partition (Write speed: 4398.32 Kb/s) 17-05-2022 12:18:28> Writing: LUN 0, Partition: vgc, Offset: 0x00001D408000, Size: 0x00000C800000 (200.00 MB) 17-05-2022 12:18:28> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vgc_1.img, Offset: 0x000000000000, Size: 0x000000012000 (72.00 KB) 17-05-2022 12:18:29> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vgc_2.img, Offset: 0x000000637000, Size: 0x000000010000 (64.00 KB) 17-05-2022 12:18:29> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vgc_3.img, Offset: 0x000008000000, Size: 0x000000002000 (8.00 KB) 17-05-2022 12:18:30> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vgc_4.img, Offset: 0x00000800E000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:18:31> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vgc_5.img, Offset: 0x00000C4C3000, Size: 0x000000322000 (3.13 MB) 17-05-2022 12:18:32> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vgc_6.img, Offset: 0x00000C7FF000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:18:32> Done writing partition (Write speed: 736.29 Kb/s) 17-05-2022 12:18:33> Writing: LUN 0, Partition: oem, Offset: 0x000029C08000, Size: 0x000004000000 (64.00 MB) 17-05-2022 12:18:33> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\oem_1.img, Offset: 0x000000000000, Size: 0x000000016000 (88.00 KB) 17-05-2022 12:18:33> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\oem_2.img, Offset: 0x0000003F6000, Size: 0x0000002B2000 (2.70 MB) 17-05-2022 12:18:35> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\oem_3.img, Offset: 0x000003EEB000, Size: 0x000000102000 (1.01 MB) 17-05-2022 12:18:35> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\oem_4.img, Offset: 0x000003FFF000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:18:36> Done writing partition (Write speed: 1141.53 Kb/s) 17-05-2022 12:18:36> Writing: LUN 0, Partition: vbmeta_system, Offset: 0x00002DC08000, Size: 0x000000010000 (64.00 KB) 17-05-2022 12:18:36> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vbmeta_system.img, Offset: 0x000000000000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:18:37> Done writing partition (Write speed: 5.91 Kb/s) 17-05-2022 12:18:37> Writing: LUN 0, Partition: super, Offset: 0x00002DC18000, Size: 0x000220000000 (8.50 GB) 17-05-2022 12:18:37> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\super_1.img, Offset: 0x000000000000, Size: 0x000000023000 (140.00 KB) 17-05-2022 12:18:38> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\super_2.img, Offset: 0x000000100000, Size: 0x00011C16A000 (4.44 GB) 17-05-2022 12:35:43> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\super_3.img, Offset: 0x00011C300000, Size: 0x00003B8D3000 (952.82 MB) 17-05-2022 12:39:19> Done writing partition (Write speed: 4534.22 Kb/s) 17-05-2022 12:39:19> Writing: LUN 0, Partition: cache, Offset: 0x00024DC18000, Size: 0x000010000000 (256.00 MB) 17-05-2022 12:39:20> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\cache_1.img, Offset: 0x000000000000, Size: 0x000000014000 (80.00 KB) 17-05-2022 12:39:20> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\cache_2.img, Offset: 0x000000813000, Size: 0x000000006000 (24.00 KB) 17-05-2022 12:39:21> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\cache_3.img, Offset: 0x000008000000, Size: 0x000000002000 (8.00 KB) 17-05-2022 12:39:22> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\cache_4.img, Offset: 0x000008011000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:39:22> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\cache_5.img, Offset: 0x000008813000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:39:23> Done writing partition (Write speed: 29.75 Kb/s) 17-05-2022 12:39:23> Writing: LUN 0, Partition: userdata, Offset: 0x00025DC18000, Size: 0x000C42BE3000 (49.04 GB) 17-05-2022 12:39:23> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_1.img, Offset: 0x000000000000, Size: 0x000000002000 (8.00 KB) 17-05-2022 12:39:24> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_2.img, Offset: 0x000000200000, Size: 0x000000008000 (32.00 KB) 17-05-2022 12:39:25> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_3.img, Offset: 0x0000003FF000, Size: 0x000000002000 (8.00 KB) 17-05-2022 12:39:25> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_4.img, Offset: 0x000000405000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:39:26> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_5.img, Offset: 0x000000600000, Size: 0x000000094000 (592.00 KB) 17-05-2022 12:39:27> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_6.img, Offset: 0x000000A00000, Size: 0x000000003000 (12.00 KB) 17-05-2022 12:39:27> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_7.img, Offset: 0x000005200000, Size: 0x000000819000 (8.10 MB) 17-05-2022 12:39:30> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_8.img, Offset: 0x0000061E2000, Size: 0x000000001000 (4.00 KB) 17-05-2022 12:39:31> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_9.img, Offset: 0x000007200000, Size: 0x000000003000 (12.00 KB) 17-05-2022 12:39:32> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_10.img, Offset: 0x000007800000, Size: 0x000000005000 (20.00 KB) 17-05-2022 12:39:32> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_11.img, Offset: 0x000007A00000, Size: 0x000000013000 (76.00 KB) 17-05-2022 12:39:33> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_12.img, Offset: 0x000007C00000, Size: 0x00000009D000 (628.00 KB) 17-05-2022 12:39:34> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_13.img, Offset: 0x000007E00000, Size: 0x000012C28000 (300.16 MB) 17-05-2022 12:40:42> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_14.img, Offset: 0x00001AC00000, Size: 0x00006E9FD000 (1.73 GB) 17-05-2022 12:47:22> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_15.img, Offset: 0x000089600000, Size: 0x00007BC00000 (1.93 GB) 17-05-2022 12:54:48> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\userdata_16.img, Offset: 0x000105400000, Size: 0x000004C50000 (76.31 MB) 17-05-2022 12:55:05> Done writing partition (Write speed: 4495.44 Kb/s) 17-05-2022 12:55:05> Writing: LUN 1 (Boot A), Partition: xbl, Offset: 0x000000006000, Size: 0x000000700000 (7.00 MB) 17-05-2022 12:55:06> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\xbl.elf, Offset: 0x000000000000, Size: 0x0000002F917D (2.97 MB) 17-05-2022 12:55:08> Done writing partition (Write speed: 1221.40 Kb/s) 17-05-2022 12:55:08> Writing: LUN 1 (Boot A), Partition: xbl_config, Offset: 0x000000706000, Size: 0x000000020000 (128.00 KB) 17-05-2022 12:55:09> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\xbl_config.elf, Offset: 0x000000000000, Size: 0x00000000A81C (42.03 KB) 17-05-2022 12:55:10> Done writing partition (Write speed: 27.72 Kb/s) 17-05-2022 12:55:10> Writing: LUN 2 (Boot B), Partition: xblbak, Offset: 0x000000006000, Size: 0x000000700000 (7.00 MB) 17-05-2022 12:55:10> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\xbl.elf, Offset: 0x000000000000, Size: 0x0000002F917D (2.97 MB) 17-05-2022 12:55:12> Done writing partition (Write speed: 1257.64 Kb/s) 17-05-2022 12:55:13> Writing: LUN 2 (Boot B), Partition: xbl_configbak, Offset: 0x000000706000, Size: 0x000000020000 (128.00 KB) 17-05-2022 12:55:13> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\xbl_config.elf, Offset: 0x000000000000, Size: 0x00000000A81C (42.03 KB) 17-05-2022 12:55:14> Done writing partition (Write speed: 32.13 Kb/s) 17-05-2022 12:55:14> Writing: LUN 4, Partition: rpm, Offset: 0x000000006000, Size: 0x000000080000 (512.00 KB) 17-05-2022 12:55:14> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\rpm.mbn, Offset: 0x000000000000, Size: 0x0000000381D0 (224.45 KB) 17-05-2022 12:55:16> Done writing partition (Write speed: 150.82 Kb/s) 17-05-2022 12:55:16> Writing: LUN 4, Partition: tz, Offset: 0x000000086000, Size: 0x000000400000 (4.00 MB) 17-05-2022 12:55:16> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\tz.mbn, Offset: 0x000000000000, Size: 0x0000002D4070 (2.83 MB) 17-05-2022 12:55:18> Done writing partition (Write speed: 1205.28 Kb/s) 17-05-2022 12:55:18> Writing: LUN 4, Partition: hyp, Offset: 0x000000486000, Size: 0x000000080000 (512.00 KB) 17-05-2022 12:55:19> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\hyp.mbn, Offset: 0x000000000000, Size: 0x00000005C908 (370.26 KB) 17-05-2022 12:55:20> Done writing partition (Write speed: 281.11 Kb/s) 17-05-2022 12:55:20> Writing: LUN 4, Partition: modem, Offset: 0x000000506000, Size: 0x000010000000 (256.00 MB) 17-05-2022 12:55:20> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\NON-HLOS.bin, Offset: 0x000000000000, Size: 0x000007437000 (116.21 MB) 17-05-2022 12:55:47> Done writing partition (Write speed: 4408.21 Kb/s) 17-05-2022 12:55:47> Writing: LUN 4, Partition: bluetooth, Offset: 0x000010506000, Size: 0x000000100000 (1.00 MB) 17-05-2022 12:55:48> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\BTFM.bin, Offset: 0x000000000000, Size: 0x0000000E7000 (924.00 KB) 17-05-2022 12:55:49> Done writing partition (Write speed: 604.32 Kb/s) 17-05-2022 12:55:49> Writing: LUN 4, Partition: abl, Offset: 0x000012A06000, Size: 0x000004000000 (64.00 MB) 17-05-2022 12:55:49> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\abl.elf, Offset: 0x000000000000, Size: 0x000000403000 (4.01 MB) 17-05-2022 12:55:50> Done writing partition (Write speed: 3017.33 Kb/s) 17-05-2022 12:55:50> Writing: LUN 4, Partition: dsp, Offset: 0x000016A06000, Size: 0x000002000000 (32.00 MB) 17-05-2022 12:55:51> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\dspso.bin, Offset: 0x000000000000, Size: 0x000001FFF000 (32.00 MB) 17-05-2022 12:55:58> Done writing partition (Write speed: 4236.28 Kb/s) 17-05-2022 12:55:58> Writing: LUN 4, Partition: keymaster, Offset: 0x000018A06000, Size: 0x000000080000 (512.00 KB) 17-05-2022 12:55:59> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\km4.mbn, Offset: 0x000000000000, Size: 0x00000003920A (228.51 KB) 17-05-2022 12:56:00> Done writing partition (Write speed: 188.78 Kb/s) 17-05-2022 12:56:00> Writing: LUN 4, Partition: boot, Offset: 0x000018A86000, Size: 0x000006000000 (96.00 MB) 17-05-2022 12:56:00> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\boot.img, Offset: 0x000000000000, Size: 0x000006000000 (96.00 MB) 17-05-2022 12:56:25> Done writing partition (Write speed: 3835.25 Kb/s) 17-05-2022 12:56:26> Writing: LUN 4, Partition: devcfg, Offset: 0x00001EB86000, Size: 0x000000020000 (128.00 KB) 17-05-2022 12:56:26> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\devcfg.mbn, Offset: 0x000000000000, Size: 0x00000000A7AC (41.92 KB) 17-05-2022 12:56:27> Done writing partition (Write speed: 36.91 Kb/s) 17-05-2022 12:56:27> Writing: LUN 4, Partition: qupfw, Offset: 0x00001EBA6000, Size: 0x000000010000 (64.00 KB) 17-05-2022 12:56:27> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\qupv3fw.elf, Offset: 0x000000000000, Size: 0x00000000D211 (52.52 KB) 17-05-2022 12:56:28> Done writing partition (Write speed: 47.31 Kb/s) 17-05-2022 12:56:28> Writing: LUN 4, Partition: vbmeta, Offset: 0x00001EBB6000, Size: 0x000000010000 (64.00 KB) 17-05-2022 12:56:29> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\vbmeta.img, Offset: 0x000000000000, Size: 0x000000002000 (8.00 KB) 17-05-2022 12:56:29> Done writing partition (Write speed: 10.18 Kb/s) 17-05-2022 12:56:29> Writing: LUN 4, Partition: dtbo, Offset: 0x00001EBC6000, Size: 0x000001800000 (24.00 MB) 17-05-2022 12:56:30> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\dtbo.img, Offset: 0x000000000000, Size: 0x000001800000 (24.00 MB) 17-05-2022 12:56:35> Done writing partition (Write speed: 4075.27 Kb/s) 17-05-2022 12:56:36> Writing: LUN 4, Partition: imagefv, Offset: 0x0000203C6000, Size: 0x000000200000 (2.00 MB) 17-05-2022 12:56:37> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\imagefv.elf, Offset: 0x000000000000, Size: 0x000000005000 (20.00 KB) 17-05-2022 12:56:37> Done writing partition (Write speed: 14.02 Kb/s) 17-05-2022 12:56:37> Writing: LUN 4, Partition: featenabler, Offset: 0x0000205C6000, Size: 0x000000020000 (128.00 KB) 17-05-2022 12:56:38> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\featenabler.mbn, Offset: 0x000000000000, Size: 0x0000000150D3 (84.21 KB) 17-05-2022 12:56:39> Done writing partition (Write speed: 68.90 Kb/s) 17-05-2022 12:56:39> Writing: LUN 4, Partition: uefisecapp, Offset: 0x0000205E6000, Size: 0x000000200000 (2.00 MB) 17-05-2022 12:56:39> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\uefi_sec.mbn, Offset: 0x000000000000, Size: 0x00000001E56D (121.36 KB) 17-05-2022 12:56:40> Done writing partition (Write speed: 94.43 Kb/s) 17-05-2022 12:56:40> Writing: LUN 4, Partition: apdp, Offset: 0x0000208E7000, Size: 0x000000040000 (256.00 KB) 17-05-2022 12:56:41> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\dp_AP_signed_minidump.mbn, Offset: 0x000000000000, Size: 0x000000010000 (64.00 KB) 17-05-2022 12:56:41> Done writing partition (Write speed: 80.82 Kb/s) 17-05-2022 12:56:41> Writing: LUN 4, Partition: logfs, Offset: 0x0000232CC000, Size: 0x000000800000 (8.00 MB) 17-05-2022 12:56:42> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\logfs_ufs_8mb.bin, Offset: 0x000000000000, Size: 0x000000004000 (16.00 KB) 17-05-2022 12:56:42> Done writing partition (Write speed: 20.11 Kb/s) 17-05-2022 12:56:42> Writing: LUN 4, Partition: storsec, Offset: 0x000027CCC000, Size: 0x000000020000 (128.00 KB) 17-05-2022 12:56:43> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\storsec.mbn, Offset: 0x000000000000, Size: 0x00000000501A (20.03 KB) 17-05-2022 12:56:44> Done writing partition (Write speed: 15.91 Kb/s) 17-05-2022 12:56:44> Writing: LUN 4, Partition: multiimgoem, Offset: 0x000027CEC000, Size: 0x000000008000 (32.00 KB) 17-05-2022 12:56:44> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\multi_image.mbn, Offset: 0x000000000000, Size: 0x000000008000 (32.00 KB) 17-05-2022 12:56:45> Done writing partition (Write speed: 41.85 Kb/s) 17-05-2022 12:56:45> Writing: LUN 4, Partition: secdata, Offset: 0x000027D7C000, Size: 0x000000007000 (28.00 KB) 17-05-2022 12:56:45> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\sec.elf, Offset: 0x000000000000, Size: 0x0000000031C8 (12.45 KB) 17-05-2022 12:56:46> Done writing partition (Write speed: 10.44 Kb/s) 17-05-2022 12:56:46> Writing: LUN 5, Partition: modemst1, Offset: 0x000000020000, Size: 0x000000300000 (3.00 MB) 17-05-2022 12:56:47> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\modemst.mbn, Offset: 0x000000000000, Size: 0x000000177000 (1.46 MB) 17-05-2022 12:56:48> Done writing partition (Write speed: 950.36 Kb/s) 17-05-2022 12:56:48> Writing: LUN 5, Partition: modemst2, Offset: 0x000000320000, Size: 0x000000300000 (3.00 MB) 17-05-2022 12:56:49> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\modemst.mbn, Offset: 0x000000000000, Size: 0x000000177000 (1.46 MB) 17-05-2022 12:56:50> Done writing partition (Write speed: 1012.87 Kb/s) 17-05-2022 12:56:50> Writing: LUN 5, Partition: fsg, Offset: 0x000000620000, Size: 0x000000300000 (3.00 MB) 17-05-2022 12:56:51> Writing file: H:\vivo\v2029\PD2034BF_EX_A_1.8.14_vivo_qcom_LA.UM .8.15.r1-02500-KAMORTA_split\PD2034F_EX_A_1.8.14_vivo_qcom_LA.UM. 8.15.r1-02500-KAMORTA_split\PD2034F_EX_fs_image.tar.gz.mbn.img, Offset: 0x000000000000, Size: 0x00000002569C (149.65 KB) 17-05-2022 12:56:52> Done writing partition (Write speed: 89.25 Kb/s) 17-05-2022 12:56:52> 17-05-2022 12:56:52> All done 17-05-2022 12:56:52> 17-05-2022 12:57:07> Disconnected 17-05-2022 12:57:07> |
