07-15-2013, 10:54 | #1 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | GPS Navigators, Pinouts, Dumps, Connection, Tips At this moment GPS navigators READ/WRITE supported via DIRECT EMMC connection. In theory supported all navigators based on EMMC. Lets start this Hope EASY-JTAG will help repair unbrick lot ot GPS devices. Last edited by blang; 07-15-2013 at 19:10. |
The Following 11 Users Say Thank You to blang For This Useful Post: |
07-16-2013, 20:41 | #6 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1713721 Status: Offline Thanks Meter: 8 | Hello, you are creating a way eMMC finder, like jtag finder?, To find the points CMD, DAT0-to 4, CLK, 1.8 v and 2.8 v? Where you can find some example information pinouts on Garmin GPSs? Most I know Garmin GPS: Nuvi, outdoor, edge and forerunner use eMMC. Greetings .. |
07-22-2013, 00:07 | #7 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
The Following 3 Users Say Thank You to NoName® For This Useful Post: |
07-22-2013, 08:44 | #8 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
we have emmc direct pinout for 2 navigators 1 mio and 1 garmin. soon will be uploaded to support. | |
The Following 5 Users Say Thank You to blang For This Useful Post: |
07-22-2013, 19:19 | #9 (permalink) |
Member: 1713721 Status: Offline Thanks Meter: 8 | Not everyone has an oscilloscope at home to find the points. But I think they'd be grateful if you put a small tutorial on how to find the points with an oscilloscope eMMC simple. There are some cheap oscilloscopes, via USB. On the other hand, I think I have spotted a standard JTAG port all garmin models. I want to buy the box and check it. I saw on the specifications of the box, it is possible to make debugger, reading registers, and put breakpoints. I have not seen any post regarding these features. A greeting. |
The Following 3 Users Say Thank You to haute For This Useful Post: |
07-27-2013, 13:53 | #10 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | Garmin C330 Any chance of JTAG on a Nand memory GPS? I picked up a Garmin C330 for very cheap just so I can start playing with GPS JTAG/ repair... I know it is not Emmc but is there a way we can still use JTAG to read/write ? The GPS is stuck on boot logo after the original owner tried flashing new maps. I tried Hard reset ..does not work. Nand memory used is here: K9W8G08U1M datasheet, Pinout ,application circuits 512m X 8 Bit / 256m X 16 Bit Nand Flash Memory Semiconductor |
The Following User Says Thank You to spagman For This Useful Post: |
07-27-2013, 19:40 | #11 (permalink) |
Member: 1713721 Status: Offline Thanks Meter: 8 | spagman, you can put the detailed photos of the two sides of the PCB? Maybe, I can help to find jtag port. A greeting. |
The Following User Says Thank You to haute For This Useful Post: |
07-27-2013, 22:07 | #13 (permalink) |
Member: 1713721 Status: Offline Thanks Meter: 8 | Hello, in the top right of the MicroSD card slot, there are 8-pin row. 1 - 2 - Tms 3 - 4 - Tdi 5 - Gnd 6 - 7 - 8 - Tck I think the order of the pins is the show. I think it is a standard JTAG connector on garmin gps. Jtag_finder Mode Testing and coments us the results. Another option, is to be the connector on the top left of the PCB. An 8-pin connector. Check if pin 5 is Gnd. A greeting. Last edited by haute; 07-27-2013 at 22:15. |
07-27-2013, 23:15 | #14 (permalink) | |
