Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 02-01-2019, 18:29   #31 (permalink)
Member: 1713721
Thanks Meter: 7
Originally Posted by flierace View Post
Good day! With great interest I read this topic, because I'm trying to find a solution to the issue of restoring garmin astro 320. I replaced it with emmc and sta2065, but the navigator does not turn on and does not load into the pre-boot. Did you find the chip in which the boot firmware is stored? Thanks for the reply, colleague!
Hi, i think the structure of emmc is:
Astro 320 Hwid:1339
Regions Found: 10
Region Offset Size
(0x2b) 43, 0x00000000, 0x00010000 X-Loader
(0x05) 5, 0x00010000, 0x00040000 U-Boot
(0x10) 16, 0x00050000, 0x00100000 Logo
(0x22) 34, 0x00150000, 0x00020000
(0x29) 41, 0x00170000, 0x00440000 NV (non-vol memory region)
(0x5b) 91, 0x005b0000, 0x000c0000
(0x2d) 45, 0x00670000, 0x00020000
(0x0e) 14, 0x00690000, 0x00900000 Firmware
(0x53) 83, 0x02300000, 0x00000000 Filesystem (Fat32)
(0x30) 48, 0x02300000, 0x00000000 Filesystem (Fat32) Virtual?
The most important regions are the first two and the NV.
If these regions are corrupt you can not turn on the GPS, nor update it.
Make a backup of the emmc memory and maybe I can confirm this.
Some gps models have the important regions in a Nand memory and the filesystem in the emmc, but they are few cases, such as the Etrex20 / 30.
You can also post a photo of the pcb board and so we can see if there is any memory nand or just emmc.
If it is the case that only one emmc takes, the problem could be that emmc is damaged, but you could replace it with another equal or larger, with a backup of another that works (same gps model).
Unfortunately the creators of easyjtag do not give much support to Garmin GPS, it's a shame, because there is a lot of information to do it.
A greeting.
Old 02-03-2019, 11:58   #32 (permalink)
Member: 1713721
Thanks Meter: 7
These are the emmc regions of the Garmin Nuvi 2x5W, it is the model known emmc pins, in the easy-jtag database.
Nuvi2x5W Hwid:827/851/932
Regions Found: 11
Region Offset Size
(0x2b) 43, 0x00000000, 0x00020000 X-Loader
(0x05) 5, 0x00020000, 0x00040000 U-Boot
(0x10) 16, 0x00060000, 0x00080000 Logo
(0x22) 34, 0x000e0000, 0x00020000
(0x29) 41, 0x00100000, 0x00400000 NV (non-vol memory region)
(0x2d) 45, 0x00500000, 0x00020000
(0x0e) 14, 0x00520000, 0x00880000 Firmware
(0x56) 86, 0x00da0000, 0x00080000
(0x5b) 91, 0x00e20000, 0x00080000
(0x0f) 15, 0x00ea0000, 0x00560000
(0x30) 48, 0x01400000, 0x00000000 Filesystem (Fat32)
Page generated in 0.17677 seconds with 7 queries
