Old 12-02-2015, 11:36   #1 (permalink)
Member: 2452660
Thanks Meter: 22
I9060 boot repair done but no download mode
Hi, I am a new user of Easy Jtag box. Let me know where i did mistake? here all success info but i can't go in download mode. Thank you
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0D01501BFF72D50C, ,FW Ver.: 01.52
Warning: CMD Pullup Level (268 mV) too low , check cables etc.!
CMD Active Level:1103 mV
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
Z3X EasyJtag Software ver. 2.0.6.0
CMD Pullup Level:2083 mV
CMD Active Level:2413 mV
eMMC Device Information
EMMC CID : 1501004B375530304D0861EA70B180FA
EMMC CSD : D02701320F5903FFF6DBFFE18E404028
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 08/2013 Rev.0x8
EMMC NAME: K7U00M , S/N: 1642754225
EMMC NAME (HEX): 4B375530304D00
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: K7U00M_1642754225_20151103_1511.extcsd
Done.
CMD Active Level:2402 mV
Done.
Checking NAND Image : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM1_00000000_20000000 .bin
File successefuly loaded!
Found ROM2 and automatically selected.
Found EXT CSD and automatically selected.
Checking NAND Image : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin
Checking NAND Image : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\K7XVMB_ 892425646_20150302_1442.extcsd
Found ROM1 and automatically selected.
Processing file...D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM1_00000000_20000000 .bin
Processing file...D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin
ROM3 Are not selected , skip writing ROM2
Processing file...D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\K7XVMB_ 892425646_20150302_1442.extcsd
Skip loading eMMC Addon Firmware
Input file : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM1_00000000_20000000 .bin
Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 2572 kB/s
Input file : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin
Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 896 kB/s
Running:Repair extCSD...
Writing...
Done.
Old 12-03-2015, 08:15   #2 (permalink)
Member: 2452660
Thanks Meter: 22
Still no reply from team and senior members. Pls help me
Old 12-04-2015, 00:44   #3 (permalink)
Crazy Poster
Member: 2486603
Thanks Meter: 5
use jig cable for dawnload mode
Old 12-04-2015, 15:04   #4 (permalink)
Member: 2452660
Thanks Meter: 22
Already tired bro but same
Strange....! team have no time to them client's. Thank u
Old 12-04-2015, 15:49   #5 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
Try to jack if download load mode not come and blue or black screen then insert usb cable and checked with Odin if detected then just flash even if download mod not showing but you can do flash the phone ...
Old 12-06-2015, 09:33   #6 (permalink)
Member: 2452660
Thanks Meter: 22
I know about it bro but nothing happens when power ON phone on battery or power supply. No detection by PC. Any more suggestion ?
Old 01-08-2016, 11:04   #7 (permalink)
sachinpatel's Avatar
Member: 1749874
Sonork: 100.1663210QQ:20249255921
Thanks Meter: 437
same prob i have
all process done but not show dl mode
Old 12-12-2016, 22:18   #8 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
Hello. I have the same problem. Anybody can help me?
Old 12-13-2016, 10:55   #9 (permalink)
Member: 1753851
Thanks Meter: 32
Check This Here Is Solution .... Follow All Steps Correctly ... I think This Will Solve Your Problem
Old 12-30-2017, 15:12   #10 (permalink)
Member: 1532909
Thanks Meter: 6
Not work:
Work:
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
And just write boot1,2,3 dumps
Page generated in 0.19109 seconds with 8 queries
