03-11-2017, 14:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Algeria
Member: 695274 Status: Offline Thanks Meter: 814 | First in the world xiaomi redmi note 2 emmc repair by easy jtag 1- the client say its dead When I was watching youtube then not power on and with power suplay cost 0.09 ma and with SP FLASH TOOL say error : HW-STORAGE NONE so the problem is EMMC damaged the problem no EMMC pinout for this model !!! 1- step i remove the emmc from pcb and i try to serche for pinout and not found in pcb [/SIZE][/B] 2- i reball original EMMC and try to ditect it with adapter but not ditected at all , so i cant get original configuration for replace with other emmc 3- i get one KMVTU000LM-B503 from damaged pcb and reball it now wher is configuration!!!!!! all MTK boot configuration in ROM 2 I USE EasyJTAG Plus AND SET MTK BOOT configuration now we need boot patition resize and Patch CID for toshiba emmc and after many search i get one log from one sucessfuly flashed by UFST anddroid Tools i serch in log and get : Code: PR MMC CID: 15010041474E44335201C9E8B81592C9 [AGND3R] PR Version: 3.2 [0x92] (5) eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000003A3E00000 [15.634.268.160] eMMC CID : 15010041474E44335201C9E8B81592C9 [AGND3R] ERAM Size : 0x0000000080000000 [2.147.483.648] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 7ECEED1A47ECC1F4D2A2C841F400226C PMT (GPT) Found : 20 Partition Entries Scatter Saved as: MT6795_Scatter_Xiomi Note 2.txt 3- i PATCHED THE CID FOR S3 EMMC KMVTU000LM-B503 TO BE TOSHIBA 4- i CONFIGURED AND RESIZE BOOT PARTITION FOR THE S3 EMMC KMVTU000LM-B503 TO BE LIKE THIS : Code: EMMC CID : 11010030313647373200CB9928CF7100 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 07/2014 Rev.0x0 EMMC NAME: 016G72 , S/N: 3415812303 EMMC NAME (HEX): 30313647373200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 016G72_3415812303_20170309_1357.extcsd ============================================= 6- I SOLDER THE EMMC AND PHONE ALIVE AND ALL OK |
The Following 15 Users Say Thank You to foufou34 For This Useful Post: |
