10-02-2018, 15:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Shiraz Iran Age: 37
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | how repair " GPT: damaged" 2.how can fix or modify it? 3.if it was damagedT so phone cant booted? for example bellow log: Code: Compression is ON Z3X EasyJtag Software ver. 3.2.0.3 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 1515041DE29734E2, ,FW Ver.: 01.63 CMD Pullup Level:2103 mV CMD Active Level:2165 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A48344732611102599B362023FE eMMC CSD : D02701320F5903FFF6DBFFE18E404028 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2016 Rev.0x2 eMMC NAME: H4G2a , S/N: 1503344160 eMMC NAME (HEX): 483447326120 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000800] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2a _1503344160_20181002_1750.extcsd Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: E8FFDD sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E First usable sector: 34 Last usable sector: 15269887 Found Data areas (firmware parts) count is: 31 Partition info successfully found --------------------------------------------- P0 (MCUIMAGE) [0x80000 0x40000] Size: 256.0KB P1 (TEEOS) [0xc0000 0x80000] Size: 512.0KB P2 (LOG) [0x140000 0x40000] Size: 256.0KB P3 (ROUND) [0x180000 0x80000] Size: 512.0KB P4 (FASTBOOT2) [0x200000 0x200000] Size: 2.0MB P5 (MISC) [0x400000 0x200000] Size: 2.0MB P6 (MODEMNVBKUP) [0x600000 0x200000] Size: 2.0MB P7 (NVME) [0x800000 0x400000] Size: 4.0MB P8 (OEMINFO) [0xc00000 0x2000000] Size: 32.0MB P9 (SPLASH) [0x2c00000 0x800000] Size: 8.0MB P10 (MODEMNVM1) [0x3400000 0x800000] Size: 8.0MB P11 (MODEMNVM2) [0x3c00000 0x800000] Size: 8.0MB P12 (MODEMIMAGE) [0x4400000 0x4000000] Size: 64.0MB P13 (DSP) [0x8400000 0x800000] Size: 8.0MB P14 (HIFI) [0x8c00000 0x400000] Size: 4.0MB P15 (MODEMLOG) [0x9000000 0x1000000] Size: 16.0MB P16 (BOOT) [0xa000000 0x1000000] Size: 16.0MB P17 (RECOVERY) [0xb000000 0x1000000] Size: 16.0MB P18 (RECOVERY2) [0xc000000 0x1000000] Size: 16.0MB P19 (SPLASH2) [0xd000000 0x4000000] Size: 64.0MB P20 (CACHE) [0x11000000 0x10000000] Size: 256.0MB P21 (3RDMODEM) [0x21000000 0x8000000] Size: 128.0MB P22 (HISITEST0) [0x29000000 0x200000] Size: 2.0MB P23 (HISITEST1) [0x29200000 0x200000] Size: 2.0MB P24 (HISITEST2) [0x29400000 0x400000] Size: 4.0MB P25 (3RDMODEMNVM) [0x29800000 0x2000000] Size: 32.0MB P26 (3RDMODEMNVMBKP) [0x2b800000 0x1000000] Size: 16.0MB P27 (SYSTEM) [0x2c800000 0x60000000] Size: 1.500GB P28 (CUST) [0x8c800000 0x20000000] Size: 512.0MB P29 (APLOG) [0xac800000 0x8000000] Size: 128.0MB P30 (USERDATA) [0xb4800000 0x11d800000] Size: 4.460GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x002C800000 (1.500GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Done Backup saved: H4G2a _1503344160_20181002_1750.extcsd Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: E8FFDD sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E First usable sector: 34 Last usable sector: 15269887 Found Data areas (firmware parts) count is: 31 Partition info successfully found ------------------------------------------ |
The Following User Says Thank You to CoMoBat For This Useful Post: |
10-02-2018, 23:05 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) You can try to fix GPT errors by press "Repair Tables" at "Region" Tab 3) Yes. Cpu may doun't find boot partition if table seriously damaged | |
The Following 5 Users Say Thank You to layder For This Useful Post: |
10-03-2018, 09:02 | #3 (permalink) | |
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | Quote:
My phone is H30-L02 and his emmc was damagedI used B309 for test that maybe it can work on phone I changed boot config and changed CID for convert emmc ... Now show me GPT errors I try to repair it by "Repair table" in region menu and show me bellow log: Code: Compression is ON Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Data partitions (firmware parts) count is 31 (dec) Meta partitions (partitions storing partition table) count is 1 (dec) Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: E8FFDD sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E First usable sector: 34 Last usable sector: 15269887 Partitions list is successefuly loaded! Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Repairing partitions... Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: E8FFDD sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E First usable sector: 34 Last usable sector: 15269887 Caution: The CRC for the backup partition table is invalid. This table may be corrupt. This program will automatically create a new backup partition table when you save your partitions. Problem: The secondary header's self-pointer indicates that it doesn't reside at the end of the disk. If you've added a disk to a RAID array, use the 'e' option on the experts' menu to adjust the secondary header's and partition table's locations. Problem: main GPT header's current LBA pointer 1 doesn'tmatch the backup GPT header's alternate LBA pointer 0 Problem: main GPT header's backup LBA pointer (E8FFFF) doesn'tmatch the backup GPT header's current LBA pointer (0) The 'e' option on the experts' menu may fix this problem. Problem: main GPT header's first usable LBA pointer (22) doesn'tmatch the backup GPT header's first usable LBA pointer (0) Problem: main GPT header's last usable LBA pointer (E8FFFF) doesn'tmatch the backup GPT header's last usable LBA pointer (0) The 'e' option on the experts' menu can probably fix this problem. You should use the 'b' or 'd' option on the recovery & transformation menu to select one or the other header. Caution! Secondary header was placed beyond the disk's limits! Fixing... Aborting write operation! Aborting write of new partition table. Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Data partitions (firmware parts) count is 31 (dec) Meta partitions (partitions storing partition table) count is 1 (dec) Partitions list is successefuly loaded! whats wrong?! Is it possible because I used B309 emmc? | |
10-03-2018, 12:16 | #5 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Wrong emmc ....use supported emmc with same or higher storage Quote:
The Following User Says Thank You to nagesss For This Useful Post: |
10-06-2018, 14:36 | #7 (permalink) |
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Check it out....to check in this site for compatible emmc. http://emmchelper.com/ Sent from my Redmi Note 4 using Tapatalk |
The Following 3 Users Say Thank You to nagesss For This Useful Post: |
10-07-2018, 06:57 | #8 (permalink) | |
Also I use it: ???? ??????? ????? ?? ???? ?? ?? dr-emmc ?????? - Dr-Emmc.Org | |
10-13-2018, 18:01 | #9 (permalink) | |
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | If u had searched more easy jtag soft ware it self has information of compatible emmcs and models in utility tab.. Quote:
