03-10-2014, 10:23 | #61 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | ( i9300 successfully repaired with your method .. then write pit file with odin now total dead) |
03-16-2014, 13:36 | #62 (permalink) |
Major Poster Join Date: Jul 2008 Location: kingdom of saudi arabia
Member: 804793 Status: Offline Sonork: perotskie Thanks Meter: 3 | i agree with this solution this method working for s3 i9300 No: Product Name it easy to use... 1-steep buy z3x jtag box 2-install the driver 3-modified the box u can find here http://forum.gsmhosting.com/vbb/f672...nnect-1691327/ now Connect the pinout to the PCB then follow the instruction of Dr.javeed. when the eMMC formating is done do upgrade ur mobile using latest odin and latest firmware u dont need to use PIT just use the Single file firmware. after done then finally ur mobile is alive now rewrite the imie and s/n u can see at the back sticker of ur mobile..after done do unlock...done all goodluck guys. thanks to Z3X Developer. |
03-17-2014, 08:49 | #63 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | note ii n7100 successfully repair no product Running:Repair extCSD... <br>Successfully connected to box on COM4<b> Box S/N: 000000000000FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... CMD Pullup Level:1206 mV CMD Active Level:1701 mV EMMC CID 15010056545530304D08AC5C3AC490A3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/1997 FW rev.0x8 EMMC NAME: <b>VTU00M</b> , S/N: 2891725508 EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! Running:SAMSUNG: BOOT and RPMB resize... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!</font> CMD Active Level:1691 mV EMMC CID 15010056545530304D08AC5C3AC490A3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/1997 FW rev.0x8 EMMC NAME: <b>VTU00M</b> , S/N: 2891725508 EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2891725508_20140200_1158.extcsd Sending Internal Reconfiguration Request for BOOT ... Waiting for configuration Apply!!! Sending Internal Reconfiguration Request for RPMB ... BOOT1 and BOOT2 Size Set to : 2048 KB RPMB Size Set to : 128 KB Waiting for configuration Apply!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!</font> CMD Active Level:1691 mV EMMC CID 15010056545530304D08AC5C3AC490A3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/1997 FW rev.0x8 EMMC NAME: <b>VTU00M</b> , S/N: 2891725508 EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2891725508_20140200_1204.extcsd Done. Running:Repair extCSD... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1680 mV EMMC CID 15010056545530304D08AC5C3AC490A3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/1997 FW rev.0x8 EMMC NAME: <b>VTU00M</b> , S/N: 2891725508 EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1691 mV EMMC CID 15010056545530304D08AC5C3AC490A3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/1997 FW rev.0x8 EMMC NAME: <b>VTU00M</b> , S/N: 2891725508 EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 222 kB/s Done !!! <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1701 mV EMMC CID 15010056545530304D08AC5C3AC490A3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/1997 FW rev.0x8 EMMC NAME: <b>VTU00M</b> , S/N: 2891725508 EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 308 kB/s Done !!! note ii n7100 must repartition then ok |
The Following User Says Thank You to drjaved_akhter For This Useful Post: |
03-18-2014, 12:33 | #64 (permalink) |
Junior Member Join Date: Apr 2013 Location: Paraguay
Member: 1915610 Status: Offline Thanks Meter: 2 | One step Missing sorry for my ignorance in this matter, but the file needed for this operation is created in one of the steps ? thats why its in backup folder ? thanks for reply |
03-18-2014, 14:32 | #66 (permalink) |
Member: 1915610 Status: Offline Thanks Meter: 2 | i9300 no product people this is what im getting: Successfully connected to box on COM324 Box S/N: 15010014xxxxxxxx, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.105.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (278 mV) too low , check cables etc.!!! CMD Active Level:794 mV Warning: CMD Active Level Low !!! eMMC ACK Error ( Check Connection ) eMMC Card initialisation error! have recently received z3x pro with gpg adaptor with mini usb connector |
03-18-2014, 14:39 | #67 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
03-19-2014, 12:28 | #68 (permalink) |
Freak Poster Join Date: May 2011 Location: Pilipinas
Member: 1574276 Status: Offline Thanks Meter: 37 | Just want to ask this question i also have the emmc adapter Like this one Just want to know or can anyone can tell me Where is this pin-out from adapter or can anyone name the pin Of this adapter from DATO/CLK/CMD/VCC/VCCQ/GND thanks regard's Last edited by FULL_ERASE; 03-19-2014 at 12:33. |
03-19-2014, 20:48 | #70 (permalink) |
Member: 1574276 Status: Offline Thanks Meter: 37 | Can this thread post again the picture or guide To the software i succesfully connect the unit (I9300) But sadly i dont know whats the next step regard's |
03-19-2014, 21:35 | #72 (permalink) |
No Life Poster Join Date: May 2010
Member: 1300483 Status: Offline Thanks Meter: 27 | bro this is you next step http://forum.gsmhosting.com/vbb/f672...nside-1774468/ loook its step by step |
03-19-2014, 21:47 | #73 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | Hello Hi, still there is not full instructions about what to do. Should battery be connected - should usb cable be connected - software tips should be implied for easy undersatnding. Thanks and have a nice day. |
03-20-2014, 14:10 | #75 (permalink) | ||
Member: 1574276 Status: Offline Thanks Meter: 37 | I have a problem in the last procedure which is writing emmc I read all the logs all of them writing and had a emmc_bin like this Quote:
Instead of this like others (Writing 000000200000 bytes to 00000000) Can anyone tell me if i do it wrong Here's my logs Quote:
