Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 02-13-2014, 17:38   #46 (permalink)
Member: 647430
Thanks Meter: 2
emmc name 000000. cant repair?????????
The Following User Says Thank You to tstcom For This Useful Post:
Old 02-14-2014, 18:33   #47 (permalink)
Member: 133927
Thanks Meter: 20
Old 02-15-2014, 09:59   #48 (permalink)
Member: 1233181
Originally Posted by drjaved_akhter View Post
i use two power supply external
are you use emmc adapter
two power supply?
Old 02-15-2014, 15:50   #49 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 763
two power supply?
no i use tow power supply ...................
Old 02-17-2014, 13:51   #50 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 864
Originally Posted by blang View Post
for repair empty product code 1st. need try write rom2. product code there.
if after rom2 writing no any changes, then problem with emmc.
you can try Format emmc.
after format emmc goto factory status and need repair exscd.
after repair excsd need flash again rom1 and rom2.
and then flash via odin.
if something wrong while this steps - then unknown problem with emmc and cant be fixed.
From my test and report of users: 70% of problems with DIRECT EMMC read/write - long wires, GND wire bad, voltage not stable or not right, bad soldering. Remember connect direct emmc is more complicated than JTAG connect.
today i upgrade my phone with arabic firmware 4.3
and its show me prodect code=i9300
butt still showCUSTOM DOWNLAOD BINARY:2564566545.
i was dead repair it via clone sd
Old 02-17-2014, 22:17   #51 (permalink)
Member: 1228446
Can someone help me. I am new to easy jtag box. I have many galaxy i747 phones that turn on and off within 10 seconds. I cant even get phone into download mode and phone shuts off. is there anyway to repair these phones with z3x easy jtag. I have gpg easy jtag cables. I connect to easy repair and it does the whole process and when its says all done I try it and it does the same thing again. please help. I am new to this. any step by step would really help me a lot. thanks
Old 02-18-2014, 00:12   #52 (permalink)
Member: 21937
Thanks Meter: 279
your problem may be something else .....
maybe only power switch ....
Old 02-18-2014, 19:58   #53 (permalink)
Member: 939467
Thanks Meter: 50
any solution for this problem?
Originally Posted by elfadelmed View Post
Loading eMMC Addon Firmware...
CMD Pullup Level:1443 mV
CMD Active Level:1773 mV
Can't Init EMMC !!! ( Ready Condition TIMEOUT! )
eMMC Card initialisation error!
Same error on several phones.
i have the same problem
any advice?
is it bad connection or what?
Old 02-22-2014, 08:49   #54 (permalink)
Member: 585807
Thanks Meter: 763
one more repair
<br>Successfully connected to box on COM4<b>
Box S/N: *******************,FW Ver.: 01.48
CMD Pullup Level:1258 mV
CMD Active Level:1711 mV
EMMC CID 15010056545530304DF1592E569B8F13
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 08/2012 FW rev.0xf1
EMMC NAME: <b>VTU00M</b> , S/N: 1496209051
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_1496209051_20140104_0817.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48
CMD Pullup Level:1247 mV
CMD Active Level:1701 mV
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
<font color="red">Please don't forget to repair extCSD from backup!!!</font>
Running:SAMSUNG: MoviNAND Format...
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Done.
Running:Repair extCSD...
CMD Pullup Level:1237 mV
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
CMD Pullup Level:1227 mV
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 222 kB/s
Done !!!
Writing 000020000000 bytes to 00000000 ...ROM1
Done !!!
Old 02-22-2014, 16:22   #55 (permalink)
Member: 1607116
Sonork: 100.1617729
Thanks Meter: 49
samsung gt-i9300 no product hang on logo repair
logs
CMD Active Level:1722 mV
EMMC CID 15010056545530304DF1F5C216FF6F5F
EMMC Date: 06/2012 FW rev.0xf1
EMMC NAME: <b>VTU00M</b> , S/N: 4123137791
Backup saved: VTU00M_4123137791_20140102_1034.extcsd
Done.
Backup saved: VTU00M_4123137791_20140102_1035.extcsd
Done.
Done.
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Done !!!
CMD Active Level:1732 mV
Done !!!
brother did everything letter and ends all good, but when assembled the phone and I put the battery does not turn on or enter download mode,
even a kind i9300 disarmament and works to make a backup of BOOT, and select read eMMC Card and now no power on
Old 02-23-2014, 02:30   #56 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 13
yes power switch stuck, just change the power switch problem solve
Old 02-23-2014, 02:35   #57 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 13
you have to reset custom binary count to:no
if not your device will behave strange
Old 02-26-2014, 15:48   #58 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 155
? about erase emmc
erase emmc option daed my phone
Old 03-03-2014, 15:26   #59 (permalink)
janzir's Avatar
Member: 1726910
Sonork: 100.1623945
Thanks Meter: 41
hi
i have problem with my gt-i9300 which has no product code
i followed ur method, but i couldn't do " novinand format" ,, result emmc ask error!!
i also get these values even if i write rom1 & rom2 images (from shell):
EMMC ROM1 (Main User Data) Capacity: 16384 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
is my EMMC diffected, or am i doing something wrong?
thanks
Old 03-10-2014, 07:39   #60 (permalink)
mscomp's Avatar
Member: 266158
Thanks Meter: 197
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
Extended pleaz help i cant partition always 0 ko
Page generated in 0.46190 seconds with 8 queries
