Old 03-10-2014, 10:23   #61 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 318
akhter.. after boot repair which file for using for flashing ..ple
( i9300 successfully repaired with your method .. then write pit file with odin now total dead)
Old 03-16-2014, 13:36   #62 (permalink)
Member: 804793
Sonork: perotskie
Thanks Meter: 3
i agree with this solution
this method working for s3 i9300
No: Product Name
it easy to use...
1-steep buy z3x jtag box
2-install the driver
3-modified the box u can find here http://forum.gsmhosting.com/vbb/f672...nnect-1691327/
now Connect the pinout to the PCB
then follow the instruction of Dr.javeed.
when the eMMC formating is done
do upgrade ur mobile using latest odin and latest firmware
u dont need to use PIT just use the Single file firmware.
after done then finally ur mobile is alive now rewrite the imie and s/n
u can see at the back sticker of ur mobile..after done do unlock...done all
goodluck guys.
thanks to Z3X Developer.
Old 03-17-2014, 08:49   #63 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
note ii n7100 successfully repair no product
Running:Repair extCSD...
<br>Successfully connected to box on COM4<b>
Box S/N: 000000000000FW Ver.: 01.48
Z3X EasyJtag Software ver. 1.0.105.0
Loading eMMC Addon Firmware...
CMD Pullup Level:1206 mV
CMD Active Level:1701 mV
EMMC CID 15010056545530304D08AC5C3AC490A3
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 09/1997 FW rev.0x8
EMMC NAME: <b>VTU00M</b> , S/N: 2891725508
EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Running:SAMSUNG: BOOT and RPMB resize...
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48
<font color="red">Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!</font>
CMD Active Level:1691 mV
Backup saved: VTU00M_2891725508_20140200_1158.extcsd
Sending Internal Reconfiguration Request for BOOT ...
Waiting for configuration Apply!!!
Sending Internal Reconfiguration Request for RPMB ...
BOOT1 and BOOT2 Size Set to : 2048 KB
RPMB Size Set to : 128 KB
Done.
<font color="red">Please don't forget to repair extCSD from backup!!!</font>
Backup saved: VTU00M_2891725508_20140200_1204.extcsd
Done.
<font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font>
CMD Active Level:1680 mV
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 222 kB/s
Done !!!
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 308 kB/s
Done !!!
note ii n7100 must repartition then ok
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 03-18-2014, 12:33   #64 (permalink)
Member: 1915610
Thanks Meter: 2
One step Missing
sorry for my ignorance in this matter, but the file needed for this operation is created in one of the steps ? thats why its in backup folder ?
thanks for reply
Old 03-18-2014, 12:58   #65 (permalink)
Member: 1999375
Sonork: sarfaraz
i have z3x samsung plastic box can i active easy jtag in same box ????
Old 03-18-2014, 14:32   #66 (permalink)
Member: 1915610
Thanks Meter: 2
i9300 no product
people this is what im getting:
Successfully connected to box on COM324
Box S/N: 15010014xxxxxxxx, ,FW Ver.: 01.48
Warning: CMD Pullup Level (278 mV) too low , check cables etc.!!!
CMD Active Level:794 mV
Warning: CMD Active Level Low !!!
eMMC ACK Error ( Check Connection )
eMMC Card initialisation error!
have recently received z3x pro with gpg adaptor with mini usb connector
Old 03-18-2014, 14:39   #67 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
problem with connection. search problem there.
Old 03-19-2014, 12:28   #68 (permalink)
FULL_ERASE's Avatar
Member: 1574276
Thanks Meter: 37
Just want to ask this question i also have the emmc adapter
Like this one
Just want to know or can anyone can tell me
Where is this pin-out from adapter or can anyone name the pin
Of this adapter from
DATO/CLK/CMD/VCC/VCCQ/GND
thanks
regard's
Old 03-19-2014, 17:15   #69 (permalink)
mr.6630's Avatar
Member: 148424
Sonork: 100.93619
Thanks Meter: 112
just like that
br
The Following User Says Thank You to mr.6630 For This Useful Post:
Old 03-19-2014, 20:48   #70 (permalink)
FULL_ERASE's Avatar
Member: 1574276
Thanks Meter: 37
Can this thread post again the picture or guide
To the software i succesfully connect the unit (I9300)
But sadly i dont know whats the next step
regard's
Old 03-19-2014, 21:23   #71 (permalink)
FULL_ERASE's Avatar
Member: 1574276
Thanks Meter: 37
Iva already to the following
Factory reset format
Samsung movinand format
Universal repairextcsd
Can anyone tell me whats the next procedure
regard's
Old 03-19-2014, 21:35   #72 (permalink)
Member: 1300483
Thanks Meter: 27
bro this is you next step
http://forum.gsmhosting.com/vbb/f672...nside-1774468/
loook its step by step
Old 03-19-2014, 21:47   #73 (permalink)
Member: 33690
Thanks Meter: 3,398
Hello
Hi,
still there is not full instructions about what to do.
Should battery be connected -
should usb cable be connected -
software tips should be implied for easy undersatnding. Thanks and have a nice day.
Old 03-19-2014, 23:50   #74 (permalink)
janzir's Avatar
Member: 1726910
Sonork: 100.1623945
Thanks Meter: 41
Just connect using the emmc adapter or by using two power supply
No need for battery nor usb cable
Sent from my iPad using Tapatalk
Old 03-20-2014, 14:10   #75 (permalink)
FULL_ERASE's Avatar
Member: 1574276
Thanks Meter: 37
I have a problem in the last procedure which is writing emmc
I read all the logs all of them writing and had a emmc_bin like this
Write Speed: 117 kB/s
Done !!!
But when i about to write the EMMC i only have this kind of bin (EMMC_00000000_00080000)
Instead of this like others (Writing 000000200000 bytes to 00000000)
Can anyone tell me if i do it wrong
Here's my logs
EasyJtag Suite ver.: 1.0.105.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition.
Successefuly connected to box on COM17
Box S/N: 0D003020E2DC2815, ,FW Ver.: 01.48
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial :FULL_ERASE , ver: 22
Successfully connected to box on COM17
CMD Pullup Level:1402 mV
CMD Active Level:1722 mV
Can't Init EMMC !!! ( Ready Condition TIMEOUT! )
Box S/N: FULL_ERASE, ,FW Ver.: 01.48
CMD Pullup Level:1247 mV
CMD Active Level:1711 mV
EMMC CID 15010056545530304DF12F665B0E9FF1
EMMC Date: 09/2012 FW rev.0xf1
EMMC NAME: VTU00M , S/N: 795237134
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
Backup saved: VTU00M_ 795237134_20140204_2042.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
CMD Pullup Level:1237 mV
Backup saved: VTU00M_ 795237134_20140204_2044.extcsd
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Running:SAMSUNG: MoviNAND Format...
CMD Pullup Level:1227 mV
Backup saved: VTU00M_ 795237134_20140204_2048.extcsd
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 795237134_20140204_2048.extcsd
Box S/N:FULL_ERASE, ,FW Ver.: 01.48
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Writing file...C:\Program Files\Z3X\EASYJTAG\Backups\EMMC_00000000_00080000. bin
CMD Pullup Level:1216 mV
Writing 000000080000 bytes to 00000000 ...ROM2
Done !!!
Page generated in 0.30578 seconds with 10 queries
