Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-22-2014, 10:16   #76 (permalink)
Member: 540932
Thanks Meter: 36
needded step by step tutorial plz
Originally Posted by drjaved_akhter View Post
note ii n7100 successfully repair no product
Running:Repair extCSD...
<br>Successfully connected to box on COM4<b>
Box S/N: 000000000000FW Ver.: 01.48
Z3X EasyJtag Software ver. 1.0.105.0
Loading eMMC Addon Firmware...
CMD Pullup Level:1206 mV
CMD Active Level:1701 mV
EMMC CID 15010056545530304D08AC5C3AC490A3
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 09/1997 FW rev.0x8
EMMC NAME: <b>VTU00M</b> , S/N: 2891725508
EMMC ROM1 (Main User Data) Capacity: 14910 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Running:SAMSUNG: BOOT and RPMB resize...
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48
<font color="red">Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!</font>
CMD Active Level:1691 mV
Backup saved: VTU00M_2891725508_20140200_1158.extcsd
Sending Internal Reconfiguration Request for BOOT ...
Waiting for configuration Apply!!!
Sending Internal Reconfiguration Request for RPMB ...
BOOT1 and BOOT2 Size Set to : 2048 KB
RPMB Size Set to : 128 KB
Done.
<font color="red">Please don't forget to repair extCSD from backup!!!</font>
Backup saved: VTU00M_2891725508_20140200_1204.extcsd
Done.
<font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font>
CMD Active Level:1680 mV
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 222 kB/s
Done !!!
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 308 kB/s
Done !!!
note ii n7100 must repartition then ok
i do same procedure like i 9300 but no success plzz guide me with tutorial
Old 03-23-2014, 03:51   #77 (permalink)
Member: 1617198
Originally Posted by TRABEL View Post
your problem may be something else .....
maybe only power switch ....
replacement on power switch was needed for mine
Old 03-24-2014, 10:07   #78 (permalink)
Member: 793565
Sonork: 100.1611436
Thanks Meter: 354
Dead boot done ,product anme ok but phone hang on logo.
Dead boot Done
Flased Phone 4.2.1 ,but no product name .
Then Flashd phone to 4.3 Product Name Back But CUSTOM BINARY DOWNLOAD: YES (1227707463)
PHONE HANG ON SAMSUNG LOGO
Old 03-24-2014, 11:40   #79 (permalink)
Member: 793565
Sonork: 100.1611436
Thanks Meter: 354
chek this post too
Originally Posted by gulzarjan View Post
Dead boot Done
Dead boot done ,product anme ok but phone hang on logo!!!!!!
Old 03-24-2014, 13:48   #80 (permalink)
wahidsam's Avatar
Member: 46191
Thanks Meter: 28
Originally Posted by janzir View Post
hi
i have problem with my gt-i9300 which has no product code
i followed ur method, but i couldn't do " novinand format" ,, result emmc ask error!!
i also get these values even if i write rom1 & rom2 images (from shell):
EMMC ROM1 (Main User Data) Capacity: 16384 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
is my EMMC diffected, or am i doing something wrong?
thanks
Hi
You've to set your phone partitions sizes as following :
It should be ok for formating and resore files writing (ROM1 2Mb & ROM2 512 Mb).
BR.
The Following User Says Thank You to wahidsam For This Useful Post:
Old 03-24-2014, 13:50   #81 (permalink)
wahidsam's Avatar
Member: 46191
Thanks Meter: 28
Originally Posted by mscomp View Post
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
Extended pleaz help i cant partition always 0 ko
Hi
Try to set partitions size again like following :
may be your problem will be solved..
BR.
Old 03-25-2014, 03:59   #82 (permalink)
Member: 901949
Thanks Meter: 43
Originally Posted by ...:::::NP™:::::... View Post
I Think Need This Thread With Sticky List For Easy Jtag User Who Have Don't Knowledge About eMMC Flashing
Keep it Up
Best Regard
Bro:- Palash Ahammad
what is the point of flashing emmc? i mean what will it achieve? can revive dead product? if the emmc has bad sector can we repartition it and make the phone alive?
thanks
Old 03-25-2014, 21:21   #83 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 757
manual format wipe data and fectory reset then flashed efs and again format
wipe and fect after phone power on
then repair imei
Old 03-31-2014, 09:37   #84 (permalink)
Member: 1549945
Thanks Meter: 2
great solution
me successfully rectified no product name issue with this method thanks to blang and drjaved akhter
Old 04-15-2014, 12:33   #85 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 312
yes done 4 i9300 nice soluation
Old 04-25-2014, 17:35   #86 (permalink)
Member: 826984
how repair efs i9300?
Old 04-25-2014, 18:07   #87 (permalink)
Member: 585807
Thanks Meter: 757
use z3x or spt .............................
Old 04-25-2014, 18:55   #88 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 356
have 1 problem i9300 repair product name black ok but now cant flash always error sboot by odin spt all box fail only can write efs and full factory but cant write flash
Old 04-25-2014, 19:32   #89 (permalink)
Member: 585807
Thanks Meter: 757
mx.pit file write if not ok then conect emmc pinout and repair ext_csd which backup in c:/program file/z3x/easy jtag/backups...............
Old 04-26-2014, 15:30   #90 (permalink)
Member: 2129557
Thanks Meter: 47
I9300 successfully repaired with easy jtag. Thanks to the whole team and users of easy jtag team.
The Following User Says Thank You to luqmanonline For This Useful Post:
Page generated in 0.44478 seconds with 8 queries
