Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-28-2014, 18:56   #91 (permalink)
zubair84's Avatar
Member: 1385730
Sonork: zubair84
Thanks Meter: 30
i have done i9300 boot repair after flash dead
can you tell me which flash file i have to flash thanks EasyJtag Suite ver.: 1.0.100.0 started.
Operating system ver.: Windows XP (build 2600, Service Pack 3).
Successefuly connected to box on COM155
Box S/N: 1313062362293D2E, ,FW Ver.: 01.48
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAC5-3119 , ver: 22
Loading repair file: 'C:\Documents and Settings\Dell\Bureau\easy jtag\Samsung GT-i9023.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9023, Ver.: 1.00
Error loading information!
Easy-Repair file load OK!
Start Z3X Jtag Pin Finder...
Waiting for box reset...
Box S/N: 0000000062293D2E
Box Working Mode: JTAG Pin Finder.
Stage 1: Search TCK / TMS / TDI / TDO...
Get IDCODE...
JTAG Pinout Found: TCK: Pin 9 / TMS: Pin 7 / TDI: Pin 5 / TDO: Pin 13
CPU IDCODE : 0x1BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A8
Stage 2: Search TRST...
TRST Pin Found: TRST: Pin 3
Using EasyRepair Mode...
Warning , you are using custom pinout config make shure that NRST and GND on proper places!
Checking repair data...
For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device.
Initialising: SAMSUNG GT-I9023 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: 1313062362293D2E ,FW Ver.: 01.48
Connecting to Target...
JTAG device: S5PC110
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting nand memory parameters ...
NAND flash device ID:00EC:0050 'NAND 512MB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00000800, Page size:1024 bytes , Block size:256 pages
NAND Writing BOOT...
NAND Write OK! Elapsed time: 13.968750s (453.584 KiB/s)
All Done.
Old 04-28-2014, 18:58   #92 (permalink)
zubair84's Avatar
Member: 1385730
Sonork: zubair84
Thanks Meter: 30
can you tell me which flash file i must flash
Old 04-28-2014, 19:03   #93 (permalink)
zubair84's Avatar
Member: 1385730
Sonork: zubair84
Thanks Meter: 30
sorry this is i9300 done
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_ 904020045_20140301_1639.extcsd
Done.
Reading dump to file...C:\Documents and Settings\Dell\Bureau\easy jtag\EMMC_00000000_00080000.zub.bin
Z3X EasyJtag Software ver. 1.2.0.0
Skip loading eMMC Addon Firmware
CMD Pullup Level:1361 mV
CMD Active Level:1856 mV
Reading 0x000000080000 bytes from 0x000000000000 ...ROM0
Read Speed: 466 kB/s
Done !!!
Writing file...C:\Documents and Settings\Dell\Bureau\easy jtag\EMMC_00000000_00080000.zub.bin
Writing 000000080000 bytes to 00000000 ...ROM0
Write Speed: 508 kB/s
Done !!!
Loading eMMC Addon Firmware...
Box S/N: 1313062362293D2E, ,FW Ver.: 01.49
CMD Pullup Level:1639 mV
CMD Active Level:2237 mV
eMMC Device Information
EMMC CID : 15010056545530304DF135E2404D4FE8
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 04/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 904020045
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
Backup saved: VTU00M_ 904020045_20140301_1808.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Please don't forget to repair extCSD from backup!!!
Running:SAMSUNG: MoviNAND Format...
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 904020045_20140301_1634.extcsd
Running:Repair extCSD...
Writing...
Done!
Done.
Writing file...C:\Documents and Settings\Dell\Bureau\easy jtag\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0020000 0.bin
Writing 000000200000 bytes to 00000000 ...ROM0
Write Speed: 498 kB/s
Done !!!
Writing file...C:\Documents and Settings\Dell\Bureau\easy jtag\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000_20000 000.bin
Writing 000020000000 bytes to 00000000 ...ROM0
Write Speed: 505 kB/s
Done !!!
Old 05-18-2014, 04:16   #94 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 210
Z3X EasyJtag Software ver. 1.4.0.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 06FFskyulock, ,FW Ver.: 01.50
CMD Pullup Level:1175 mV
CMD Active Level:1557 mV
EMMC CID : 15010056545530304DF12B012ACA5F32
EMMC Date: 05/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 721496778
Backup saved: VTU00M_ 721496778_20140406_1827.extcsd
Done.
Box S/N: 06FFD003E9C4F962, ,FW Ver.: 01.50
CMD Pullup Level:1165 mV
CMD Active Level:1546 mV
Backup saved: VTU00M_ 721496778_20140406_1828.extcsd
Done.
Done.
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 721496778_20140406_1828.extcsd
Writing...
Done!
Done.
Writing file...E:\s3i9300\EMMC_ROM2_00000000_00200000.bin
Write Speed: 450 kB/s
Done !!!
Writing file...E:\s3i9300\EMMC_ROM1_00000000_20000000.bin
Write Speed: 729 kB/s
Done !!!
i have done i9300 boot repair after flash dead what solution now my fone is dead
Old 06-19-2014, 10:22   #95 (permalink)
Member: 385979
Thanks Meter: 16
add I9300 emmc pinout
Old 06-25-2014, 18:19   #96 (permalink)
Member: 1799935
Thanks Meter: 2
Hi to everybody!
Brother realy nice work with the z3x easy jtag you saved me many times with your threds.
i have a question about the emmc tool if you can help me...
if you chose to read the soft partitions on the emmc tool you get more options for the partitions....is there any diference for the read/erase/write if you choose the preset size or choose the soft partition on the list???
Old 06-26-2014, 15:49   #97 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 757
Originally Posted by cerebrumaster View Post
Hi to everybody!
yes off course if you want erase main user data then slect main user patition ans size 512 mb are 1gb as u wish
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 06-27-2014, 11:02   #98 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,591
Originally Posted by chand_gee View Post
i repair mor than 10 phone via dead boot they are all no have product name,,,
butt every think is working fine and customers are using phones,,,,is there any problem
No you are totally wrong or very very lucky.
No Product Name, in 80% of case is HW problem, eMMc damaged.
Only 20% can repair with eMMc direct, so for sure you have repaired 10 over 10 Samsung from Dead Boot only.
For this haven't need any eMMc direct connection but only one easy "Sdc Boot Card", (create for you specific device) + Jig Unbrick + Odind flash Multifile fw +Pit.
For Samsung New Exinos CPU have need also small TP, No for New Qualcomm Cpu and send phone in SD Card Mode then DM for write Multifile + pit fw by odin.
allumts
Old 07-03-2014, 17:25   #99 (permalink)
\/\/imran's Avatar
Member: 1178314
Sonork: 100.1603064
Thanks Meter: 879
Need little help i9300 no product code
i try to detect emmc card with emmc tool then show me
Z3X EasyJtag Software ver. 1.5.6.0
Box S/N: xxxxxxxxxxxxxxxxxxx, ,FW Ver.: 01.50
Warning: CMD Pullup Level (711 mV) too low , check cables etc.!!!
CMD Active Level:1722 mV
Can't init EMMC, Reason: CMD Timeout Error
Done.
Old 07-03-2014, 18:21   #100 (permalink)
allumts's Avatar
Member: 1564612
Done.
hi loock were is ERROR:
Ceck you wires if are solder correct and pinout are right,
if fail then you eMMc is damaged.
br
allumts
Old 07-04-2014, 08:45   #101 (permalink)
\/\/imran's Avatar
Member: 1178314
Sonork: 100.1603064
Thanks Meter: 879
i check again wire is ok but now show
Box S/N: xxxxxxxxxxxxxxxxxxxx, ,FW Ver.: 01.50
CMD Pullup Level:1289 mV
CMD Active Level:1577 mV
Can't init EMMC, Reason: CARD Operation Condition Timeout Error
Old 07-04-2014, 08:59   #102 (permalink)
\/\/imran's Avatar
Member: 1178314
Sonork: 100.1603064
Thanks Meter: 879
Plz check whats wrong here is image
Old 07-04-2014, 12:20   #103 (permalink)
allumts's Avatar
Member: 1564612
No, now if you see Voltage is right, so wires have cecked.
Error becouse Not start Erase can be easy, you eMMc is broken, not all I9300 with No P.Name can repair, Big % is fault eMMc, then need replace it.
For you photo, how can see your connection, i see all white and no wires, low quality of photo.
allumts
Old 08-30-2014, 21:51   #104 (permalink)
Member: 93937
Thanks Meter: 2
i have over 10 pic of i9300 with no product name in download mode and all of them can not be repaired with easy jtag I connected them directly to pcb and emmc can not be detected I am getting this
Z3X EasyJtag Software ver. 1.6.1.1
Box S/N: xxxxxxxxxxxx0, ,FW Ver.: 01.50
CMD Pullup Level:1185 mV
CMD Active Level:1608 mV
then I took out the emmc ic form the pcb reball it and resolded it on easy jtag adapter
and still same then I took one i9300 100% working phone and connected him directly to pcb and easy jtag connected to emmc so ther is only one Conclusion from my Experiment
that easy jtag can not repair i9300 with no product name
Old 08-31-2014, 11:16   #105 (permalink)
allumts's Avatar
Member: 1564612
Hi, have wrote many many many times that NOT all eMMc you can repair, only an 20% not are damaged. Clear this?, ok
You have need of to do all steps for Erase and write all partition in eMMc, if you not connect good eMMc point, wires and write exactly commands with steps you never can repair not only I9300 "no p.name" but anythinghs, please read good sticky threads and post HOW TO eMMc direct procedure,
Here only one of many I9300 repaired with success:
Done.
Done !!!
Done !!!
Done.
Done.
Done.
Writing...
Done!
Done.
Done !!!
Done !!!
allumts
Page generated in 0.45694 seconds with 8 queries
