09-15-2014, 15:23 | #106 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Chile
Member: 71290 Status: Offline Sonork: 100.1645657 Thanks Meter: 104 | Thk Z3X EASY JTAG ;) Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 161606050BBA9xxx, ,FW Ver.: 01.50 CMD Pullup Level:1330 mV CMD Active Level:1753 mV eMMC Device Information EMMC CID : 1501003030303030300C201301281062 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2013 Rev.0xc EMMC NAME: <b>000000</b> , S/N: 538116392 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: 000000_ 538116392_20140403_1338.extcsd Done. Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... <br> Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1330 mV CMD Active Level:1753 mV Repair VTU00M eMMC: Entering repair mode 1... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 1... Success =================================== <font color="red">NOTE: This stage was reapir only eMMC NAME , not wear leveling data!!</font> <font color="red">NOTE: Repair Stage 2 must be done to make eMMC repair completely!</font> <font color="red">Please, Reconnect eMMC power lines and press 'VTU00M Repair' again</font> =================================== <br> Z3X EasyJtag Software ver. 1.5.2.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 161606050BBA9215, ,FW Ver.: 01.50 CMD Pullup Level:1330 mV CMD Active Level:1732 mV eMMC Device Information EMMC CID : 15010056545530304DF16B75594F4FA4 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1802852687 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1802852687_20140403_1340.extcsd Done. |
09-24-2014, 19:13 | #107 (permalink) |
Crazy Poster Join Date: Feb 2009 Location: Myanmar
Member: 983242 Status: Offline Sonork: 100.1660072:om Thanks Meter: 3 | hi sir after repair N7100 emmc recovery error E:failed to mount /cache (no such file or directory) E:can't mount /cache/recovery/last_install E:can't open /cache/recovery/last_install E:failed to mount /cache (no such file or directory) please help |
10-08-2014, 20:05 | #110 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
use s3 i9300 n7100 s4 i9500 .............. i repaired this fault many n7100 and gt-i9300 .only replaced cmd resistor .... Last edited by drjaved_akhter; 10-08-2014 at 20:11. | |
12-11-2014, 23:01 | #117 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Venezuela-Falcon
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | CMD Pullup Level:1247 mV CMD Active Level:1619 mV eMMC Device Information EMMC CID : 15010056545530304DF7E3C1260ACF36 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 Rev.0xf7 EMMC NAME: VTU00M , S/N: 3821086218 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3821086218_20141104_1723.extcsd Done. Z3X EasyJtag Software ver. 1.6.6.6 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 07FFB005A703FA68, ,FW Ver.: 01.50 CMD Pullup Level:1237 mV CMD Active Level:1629 mV eMMC Device Information EMMC CID : 15010056545530304DF7E3C1260ACF36 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 Rev.0xf7 EMMC NAME: VTU00M , S/N: 3821086218 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3821086218_20141104_1723.extcsd Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1237 mV CMD Active Level:1629 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.6.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1237 mV CMD Active Level:1629 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3821086218_20141 104_1525.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.6.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1237 mV CMD Active Level:1629 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Z3X EasyJtag Software ver. 1.6.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1237 mV CMD Active Level:1629 mV Input file : C:\Users\Omega - Cell Paragua\Desktop\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM2_00000000_0020 0000.bin Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 1149 kB/s Done !!! Z3X EasyJtag Software ver. 1.6.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1237 mV CMD Active Level:1629 mV Input file : C:\Users\Omega - Cell Paragua\Desktop\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM1_00000000_2000 0000.bin Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 7494 kB/s Done !!! |
12-12-2014, 18:47 | #118 (permalink) |
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | here are a video of my audit This is the process that made've repaired several Thanks Z3X team https://www.youtube.com/watch?v=71UMJzvsBz8 |
01-06-2015, 17:39 | #119 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
becouse when i put i9300 on odin mode its show product name gt-19300. this phone is baseband unkown and imei null. i flash it but no luck. i will be happy if you give me quick reply. | |
01-11-2015, 14:26 | #120 (permalink) |
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | succesfully no product code repair I9300 here all log EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 3465563100 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3465563100_20150000_1910.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.6.6.7 Skip loading eMMC Addon Firmware CMD Pullup Level:917 mV CMD Active Level:1113 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:917 mV CMD Active Level:1113 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3465563100_20150 000_1910.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.6.6.7 Skip loading eMMC Addon Firmware CMD Pullup Level:917 mV CMD Active Level:1113 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Z3X EasyJtag Software ver. 1.6.6.7 Skip loading eMMC Addon Firmware USB Open Failed, Reason: PORT Open Error Z3X EasyJtag Software ver. 1.6.6.7 Skip loading eMMC Addon Firmware CMD Pullup Level:917 mV CMD Active Level:1113 mV Input file : E:\easy tag repair file\dump\i9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000 000_00200000.bin Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 920 kB/s Done !!! Z3X EasyJtag Software ver. 1.6.6.7 Skip loading eMMC Addon Firmware CMD Pullup Level:917 mV CMD Active Level:1113 mV Input file : E:\easy tag repair file\dump\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_000 00000_20000000.bin Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 2718 kB/s Done !!! Z3X EasyJtag Software ver. 1.6.6.7 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.51 CMD Pullup Level:1206 mV CMD Active Level:1557 mV eMMC Device Information EMMC CID : 15010056545530304DF1CE904BDC9FF0 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 3465563100 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3465563100_20150000_1919.extcsd Done. |
