Old 08-29-2014, 05:51   #61 (permalink)
Member: 1792561
Thanks Meter: 78
Originally Posted by BABAK NURI View Post
Hi Guys
After few try playing for reset warranty counter ,i found solution
Here is manual:
I did test in few phone,Some phone need Step 1~5....Some Phone No Need.
1-Connect I9500 by direct eMMC
2-Dowanload attachment and extract it
3-Select "Movinand Format" and let finish
4-Try Resize Boot Partition,Set as Default "4MB"
5-Try Resize RMPB ,Set as Default "512kb"
6-Select Rom2 and Write "I9500_Rom2_Alive_BN.bin"....,Wait For Finish
7-Select Rom3 and Write "I9500_Rom3_Alive_BN.bin"....,Wait For Finish
8-Select Rom1 and Write "I9500_Rom1_Alive_BN.bin"....,Wait For Finish
Now,Use USB+Jig For Force Start DL-Mode,,,
WOW You Can See "WARRANTY BIT 0 "
Last Step is Flashing Phone Via "I9500XXUEMJ5" Firmware
Enjoy...
Please Note:
1-All Dump Based on version 4.3 and Firmware "I9500XXUEMJ5_I9500ODDEMJ5_I9500DDUEMJ5_ODD"
2-All your data going to format(take backup if you need)
3-you lost own IMEI and You have to use "SUPER-IMEI" if you don't have EFS Backup Completely
Thanks it become Now,Use USB+Jig For Force Start DL-Mode,,,
FACTORY MODE
PRODUCT NAME:GT-I9500
CURRENT BINARY:Samsung Officially
SYSTEM STATUS:Custom
WARRENTY BIT:0
but i try to flash as you say I9500XXUEMJ5_I9500ODDEMJ5_I9500DDUEMJ5_HOME.tar
show this error.
<ID:0/013> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> I9500XXUEMJ5_I9500ODDEMJ5_I9500DDUEMJ5_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/013> Odin v.3 engine (ID:13)..
<ID:0/013> File analysis..
<ID:0/013> SetupConnection..
<ID:0/013> Initialzation..
<ID:0/013> Get PIT for mapping..
<ID:0/013>
<ID:0/013> There is no PIT partition.
<OSM> All threads completed. (succeed 0 / failed 1)
what happean?
Old 08-29-2014, 17:15   #62 (permalink)
Member: 2220270
Thanks Meter: 8
Originally Posted by joel_3mo View Post
Give us more details about your problem and post log of all your operations.
Also remember that you have to flash with the same version (or above) of your current firmware installed. If you have 4.3 you must flash 4.3 or 4.4; if you have isntalled 4.4 you must install only 4.4
it was imei null and baseband unkown problem . so i full erase (select 16 gb)via easy jtag and
write rom1,rom2 same as 1st post, now my phone can't flash via odin using
almost all version like 4.2.2/4.3/4.4 but same always fail.
Old 08-29-2014, 17:17   #63 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
Try button combo. I had those factory mode problems but when I use the combo I went into actual Odin mode.
The Following User Says Thank You to concepttheman For This Useful Post:
Old 08-29-2014, 17:19   #64 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
Put pit file also its on.Google...rate me thanks..lol
Old 09-06-2014, 17:02   #65 (permalink)
Member: 2220270
Thanks Meter: 8
how ?
can you explain please?
Old 09-07-2014, 22:19   #66 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
Originally Posted by karnagrg View Post
how ?
Volume down + Home + Power
Old 09-07-2014, 22:31   #67 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
Post full log of Emmc operation and I will tell you what you doing wrong..
Old 11-17-2014, 12:12   #68 (permalink)
Member: 1418143
Thanks Meter: 353
I wanna try on N900 , where is Rom2 file ? isn't on support
Old 11-28-2014, 11:18   #69 (permalink)
Member: 1549945
Thanks Meter: 2
Gt-i9505 warranty counter reset help request
Is it possible to do warranty counter to 0x0
Old 11-29-2014, 05:20   #70 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
For NOTE 3 (SM-N900) exist a easier way to do that.
Just flash this file with odin (in boot). http://www.4shared.com/zip/lQgeoT4fc...0_SM-N900.html
Old 12-02-2014, 14:19   #71 (permalink)
Member: 1610636
I9500 4.2.2 dump emmc,no_knox
Old 01-19-2015, 18:52   #72 (permalink)
Member: 2319674
Can you please make this for gt-i9505? I'm receiving lot of 9505
Or how did you make your dump? What partitions?
Old 02-06-2015, 12:27   #73 (permalink)
Member: 1848742
Is there anyone who have succesfully Reseted the knox counter
Old 02-06-2015, 12:40   #74 (permalink)
Member: 1848742
For I9500 International variant
Old 11-05-2015, 00:54   #75 (permalink)
Member: 2077936
Thanks Meter: 21
I have i337m that is stuck on logo. System status is customer and bit counter is 0x1. The device will not go into recovery mode and just says "set warranty bit: recovery" and device fully reflashes through odin but device is still stuck on logo.
Anyone know what I can do? I have a working i337m that I can copy files from. Is there any partitions that I can copy over that may fix this issue or is my EMMC dead?
Page generated in 0.23274 seconds with 10 queries
