Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-06-2018, 16:00   #1 (permalink)
Member: 1980910
Sonork: 100.1650130
Thanks Meter: 32
GT-N8000 Can't connect to easy jtag but octoplus works fine
EasyJtag Suite Classic ver.: 3.3.0.0 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 10 (build 17134), 64-bit edition. Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6688.36675
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 0.0.0.0, may affect on box performance.
Z3X Card Serial : AXXX-XXXF , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 3 serial devices
COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6)
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
COM2 ACPI\VEN_PNP&DEV_0501 Communications Port (COM2)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Cant Connect any Phone giving cmd error
and on octoplus emmc box connect ok with same connection...
please help
Easy Jtag Connect With all volt option & Clock Rate
Compression is ON
Z3X EasyJtag Software ver. 3.3.0.0
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 1212171610F7FF01, ,FW Ver.: 01.63
CMD Pullup Level:814 mV
CMD Active Level:2423 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Ready Timeout Error [Box Internal Failure]
Done.
Connect With Octoplus
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-N8000
SRF : C:/Android/Box/Octoplus/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC MAG2GA
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 1501004D414732474107DA8A3B208F4B
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : MAG2GA
Full name : KLMAG2GE2A-A001
Product revision : 0.7
Product serial number : (hex) DA8A3B20
Manufacturing date : 08/2012
CSD Info
CSD : D02701320F5903FFF6DBFFFF8A404007
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.5 (for MMC v4.41)
Erase block size : 512 Kbytes
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 128 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7659520 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Android/Box/Octoplus/Octoplus Pro JTAG Software/EXT_CSD Backups/MAG2GA_06_11_2018_19_13_14.bin.
Connect successful.
SW: 1.6.9; FW: 1.24.
P00: PART_EE (00000001, 01D59FFF) 14.68 GB
Selected pit file: C:/Users/Adeeba/Desktop/note10.pit
Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/BL_N8000XXUDNE6_1813067_REV00_user_low_ship.tar.md 5".
Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/AP_N8000XXUDNE6_1813067_REV00_user_low_ship.tar.md 5".
Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/MODEM_N8000DDUCNE2_REV_00_CL1603814.tar.md5".
Open file "C:/Users/Adeeba/Desktop/GT-N8000_INU_1_20140612192230_chapm6qyga_fac/CSC_ODD_N8000ODDDNE4_1813067_REV00_user_low_ship.t ar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...
ERROR[012]: Write error.
At sector 30777311.
Disconnected.
please help
Old 11-06-2018, 22:01   #2 (permalink)
Member: 13148
Thanks Meter: 676
CMD Pullup Level: 814 mV
CMD Active Level: 2423 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
please help
1) Set correct IO voltage (1.8v, or try 2.8),
2) Disable Hipower mode if it no use
3) Reduce Freqence from 21 to 14Mhz or low
The Following 3 Users Say Thank You to layder For This Useful Post:
Page generated in 0.28398 seconds with 7 queries
