Old 10-12-2017, 07:24   #1 (permalink)
Vahidpappali's Avatar
Member: 2602890
Sonork: NOTINSTALLED
Thanks Meter: 230
Unhappy Gt-s7582 bootrepair not done
EasyJtag Suite Classic ver.: 2.6.0.1 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ
For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL
Check security...
OK
Initialising: SAMSUNG GT-S7582 Config ver.:1.00
I/O Level set to : 2200 mV
Box S/N: 17FF901DA7669AEC ,FW Ver.: 01.60
Connecting to Target...
JTAG device: BCM21664
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Halting CPU...
Target Not Examined
TREID 3 S7582 SAME RESULT
PINOUT OK
ANY SOLUTION.
Old 10-12-2017, 07:44   #2 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Thanks Meter: 215
Hi,
what's the status of the phone now?
BR.
Old 10-12-2017, 08:15   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Check security...
OK
Halting CPU...
Target Not Examined
PINOUT OK
ANY SOLUTION.
SRST connected property?
did you connect external power or use battery?
The Following User Says Thank You to blang For This Useful Post:
Old 10-12-2017, 10:05   #4 (permalink)
Member: 2602890
Thanks Meter: 230
Originally Posted by blang View Post
srst connected property?
Did you connect external power or use battery?
yes. Put battery and usb
pin out solder ok
but comes error
Old 10-12-2017, 10:06   #5 (permalink)
Member: 2602890
Thanks Meter: 230
Originally Posted by DEADBOOT View Post
Hi,
BR.
DEAD
THATS why iam doing boot repair
Old 10-13-2017, 08:54   #6 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Thanks Meter: 215
Red face
DEAD
This is EMMC problem im sure with that, Co'z i Have many S7582 here same with your problem the other set is hang logo but when you flash in odin it stop at 98% and then after you reboot the phone there's appear in screen, Firmware Upgrade in Kies with Triangle and i don't fix it until now.
Hope that will add this solution like direct EMMC in easy jtag in future update.
BR.
The Following User Says Thank You to DEADBOOT For This Useful Post:
Old 10-18-2017, 08:16   #7 (permalink)
yuvraj9x2's Avatar
Member: 2213928
Thanks Meter: 440
Check security...
OK
Halting CPU...
Target Not Examined
PINOUT OK
ANY SOLUTION.
Need to repair emmc whit dircit cantion
Don't asked about pinout becoz data cmd in under cpu
So take out emmc and cocncnet
1st need to check wp if wp yes then remvied
2nd need to update firmware
3 rd WIRTE rom1 rom2 csd
If want dump file asked I'll upload
Be
Regards
JTAG PLAYER TEAM
The Following 2 Users Say Thank You to yuvraj9x2 For This Useful Post:
Page generated in 0.18246 seconds with 8 queries
