Old 05-19-2020, 08:49   #1 (permalink)
Member: 1845632
Thanks Meter: 16
H9TQ27ADFTMC easy jtag plus not support ?
hi
i have 2 pcs H9TQ27ADFTMC EMMC an not detect via easy jtag plus E-socket
but this emmc detected by other box
pleas give me a solution
Old 05-19-2020, 10:32   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
this and some Hynix BGA254 chips (H9HP16AECMMD) work with only VIO rate: 1.8v < VIO < 2.0v
1) You need select use 1.8v VIO for e-Socket
2) Check 1,8 line voltage at ISP mode (1,8v at software). If you box have smallest voltage (1,75-1,79) you need modify your box to up it to 1.85
(need add (solder) 100k resistor at parrallel with 10k default box resistor)
The Following 6 Users Say Thank You to layder For This Useful Post:
Old 12-28-2022, 08:54   #3 (permalink)
jaan_e_ahsan45's Avatar
Member: 689829
Sonork: 100.1651716
Thanks Meter: 102
Still Not Working....
Originally Posted by layder View Post
this and some Hynix BGA254 chips (H9HP16AECMMD) work with only VIO rate: 1.8v < VIO < 2.0v 1) You need select use 1.8v VIO for e-Socket 2) Check 1,8 line voltage at ISP mode (1,8v at software). If you box have smallest voltage (1,75-1,79) you need modify your box to up it to 1.85 (need add (solder) 100k resistor at parrallel with 10k default box resistor)
Soldered 100K Parrallal, didn't work.
Changed R45 10K still not detecting any SKHynix BGA 254 Chip.
Old 12-31-2022, 09:33   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
check voltage, please
10+100 parralel is 9,1 result
Old 05-06-2023, 06:34   #5 (permalink)
Member: 2782328
Thanks Meter: 6
hi, i have H9TQ27ADFTMC chip , and i'm trying to detect it vith MOORC socket vith 1.8, not detected. Please give me solution for this socket . How can i modify it?
Old 05-06-2023, 07:34   #6 (permalink)
Member: 2782328
Thanks Meter: 6
and not detected via isp. it connected direct to emmc
Page generated in 0.20594 seconds with 10 queries
