Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-14-2019, 10:35   #1 (permalink)
Member: 1807389
Thanks Meter: 29
help oppo a3s cph1803 dead
pls help me oppo a3s cph1803 after clear pin/gst/pass & android clear frp phone is dead plss help
The Following User Says Thank You to elusyonado For This Useful Post:
Old 07-14-2019, 11:56   #2 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 439
check isp components, Especially CLK resistor
The Following User Says Thank You to rico_deep For This Useful Post:
Old 07-14-2019, 11:58   #3 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 829
new experience for us oppo is not safe for unlock jtag
The Following User Says Thank You to kothamamun For This Useful Post:
Old 08-16-2019, 03:40   #4 (permalink)
Member: 1402783
Thanks Meter: 3
for oppo 1803 reset oppo only
do not clear pin or frp clean
The Following 2 Users Say Thank You to blancherd For This Useful Post:
Old 08-31-2019, 03:20   #5 (permalink)
Member: 810891
Sonork: 100.1625691
Thanks Meter: 5
did you revive the power ?
same here. after reset factory on UFI makes error and now its dead phone.
oppo A3s cph1803
Old 09-02-2019, 13:28   #6 (permalink)
patel yogesh's Avatar
Member: 2529129
Thanks Meter: 54
i have same a3s cph1803
dead in easy jteq ...
Old 10-04-2019, 11:56   #7 (permalink)
Member: 2141040
Thanks Meter: 16
same also , first time to also here is the logs
EasyJtag Suite Classic ver.: 3.6.1.4 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 10 (build 10586). Admin rights FAIL
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 10.0.10586.306, are OK
Z3X Card Serial : AAA1-C5FB , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 5 serial devices
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
COM3 Intel(R) Active Management Technology - SOL (COM3)
COM39 root\rimports RIM Virtual Serial Port v2 (COM39)
COM40 root\rimports RIM Virtual Serial Port v2 (COM40)
COM160 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM160)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0200300EC96F8F0A, ,FW Ver.: 01.63
CMD Pullup Level:2010 mV
CMD Active Level:1619 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D4206472A9ACFA578
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 10/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 1193974479
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
RPMB Info mmc_init Error, Reason: CMD Timeout Error
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_1193974479_20191004_1523.extcsd
Done.
CMD Active Level:2526 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
EMMC RPMB is programmed and written 27832 times
Backup saved: QE63MB_1193974479_20191004_1524.extcsd
Done.
Warning: CMD Pullup Level (257 mV) too low , check cables etc.!
CMD Active Level:2536 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB)
Erasing...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB)
Erasing...
Done.
Done.
Running:Format FRP Partition...
CMD Pullup Level:2021 mV
CMD Active Level:2547 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
GPT: present
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting...
Done.
Done.
Done.
please help me team
Old 10-04-2019, 12:18   #8 (permalink)
Member: 975554
Thanks Meter: 52
for this model dont use clear pin pass or frp use only format userdata..it will only send command to phone to factory reset it..done many times without dead..be very carefull also when removing shield mostly while removing the shield you already killed the device
Old 10-08-2019, 08:50   #9 (permalink)
Member: 2790329
Thanks Meter: 27
If you connect device to computer and show 9008 port,you need to looo click resistor.solved many times
Sent from my Redmi Note 4 using Tapatalk
Page generated in 0.38239 seconds with 7 queries
