Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-25-2019, 12:30   #1 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
[help]samsung sm-c7010 pinouts
hi, i need correct pinouts for emmc of samsung c7010
i tried using this but i cannot detect
i am using moorc adapter
can anyone help me
i need the correct procedure.
i have done j100ml and g530h, but this one is i am having trouble.
here is logs:
Found 4 serial devices
COM65 root\rimports RIM Virtual Serial Port v2 (COM65)
COM66 root\rimports RIM Virtual Serial Port v2 (COM66)
COM112 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM112)
COM1 ACPI\PNP0501 Communications Port (COM1)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Compression is ON
Z3X EasyJtag Software ver. 3.4.0.3
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 12FF9016CE5F1172, ,FW Ver.: 01.63
CMD Pullup Level:2588 mV
CMD Active Level:3042 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
Old 03-25-2019, 12:43   #2 (permalink)
Member: 2127758
Thanks Meter: 24
3.3v it's to high...
Use 1.8 / 2.4 v
Old 03-25-2019, 13:14   #3 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
i tried all voltage, still not detected. i have multiple checked the wires and it is all good
Old 03-28-2019, 09:05   #4 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
anyone from support?
Old 03-28-2019, 09:41   #5 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
okay, i have done detection now, and i need to write boot,
how do i write boot??
Compression is ON
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:2124 mV
CMD Active Level:2475 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100524331344D420CB3379A458400
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2017 Rev.0xC
eMMC NAME: RC14MB , S/N: 3006765637
eMMC NAME (HEX): 524331344D42
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RC14MB_3006765637_20190328_1537.extcsd
Done.
Old 03-29-2019, 05:16   #6 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
the phone is still dead after writing firmware via write by manufacturer
here is logs :
3/28/2019 5:54:38 PM> Looking for EasyJTAG box...
3/28/2019 5:54:38 PM> EasyJTAG API ver. 2201
3/28/2019 5:54:38 PM> Setting IO Levels to 2.8V
3/28/2019 5:54:38 PM> Setting frequence to 21 Mhz
3/28/2019 5:54:38 PM> EasyJTAG Box Serial = 12FF9016CE5F1172
3/28/2019 5:54:38 PM> EasyJTAG Box Firmware = 1.63
3/28/2019 5:54:40 PM> Setting frequence to 21 Mhz
3/28/2019 5:54:40 PM> CMD Pullup Level: 2103 mV
3/28/2019 5:54:40 PM> CMD Active Level: 2485 mV
3/28/2019 5:54:40 PM> eMMC Init returned = 0
3/28/2019 5:54:40 PM> EMMC Device Information :
3/28/2019 5:54:40 PM> EMMC CID: 150100524331344D420CB3379A458400
3/28/2019 5:54:40 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
3/28/2019 5:54:40 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: RC14MB , HEX: 524331344D42 , S/N: B3379A45 , rev. 0x0C
3/28/2019 5:54:40 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017
3/28/2019 5:54:40 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
3/28/2019 5:54:40 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
3/28/2019 5:54:40 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
3/28/2019 5:54:40 PM> EMMC Permanent Write Protection: No
3/28/2019 5:54:40 PM> EMMC Temporary Write Protection: No
3/28/2019 5:54:40 PM> Extended CSD Information :
3/28/2019 5:54:40 PM> Extended CSD rev: 1.8 (MMC 5.1)
3/28/2019 5:54:40 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
3/28/2019 5:54:40 PM> Boot Bus Config: 0x00 , width 1bit
3/28/2019 5:54:40 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
3/28/2019 5:54:40 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
3/28/2019 5:54:40 PM> Device supports partitioning features
3/28/2019 5:54:40 PM> Device can have enhanced technological features in partitions and user data area
3/28/2019 5:54:40 PM> Device can have extended partitions attribute
3/28/2019 5:54:40 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
3/28/2019 5:54:40 PM> Backup saved: RC14MB_B3379A45_20190328_175440.extcsd
3/28/2019 5:54:40 PM> EMMC Init completed.
3/28/2019 5:54:40 PM> Opening file: D:\samsung firmware\C7010\C7010ZHU2CRL1_ZZH2CRL1\C7PROLTE_CHN _OPEN.pit
3/28/2019 5:54:40 PM> Pit: C7PROLTE_CHN_OPEN.pit
3/28/2019 5:54:40 PM> Entry count: 45
3/28/2019 5:54:40 PM> The size of the last section has been updated
3/28/2019 5:54:45 PM> Selected file: D:\samsung firmware\C7010\C7010ZHU2CRL1_ZZH2CRL1\BL_C7010ZHU2 CRL1_CL14063952_QB21088829_REV00_user_low_ship_MUL TI_CERT.tar.md5
3/28/2019 5:54:45 PM> BL_C7010ZHU2CRL1_CL14063952_QB21088829_REV00_user_ low_ship_MULTI_CERT.tar.md5
3/28/2019 5:54:45 PM> The list of files in the firmware:
3/28/2019 5:54:45 PM> aboot.mbn.lz4
3/28/2019 5:54:45 PM> sbl1.mbn.lz4
3/28/2019 5:54:45 PM> rpm.mbn.lz4
3/28/2019 5:54:45 PM> tz.mbn.lz4
3/28/2019 5:54:45 PM> devcfg.mbn.lz4
3/28/2019 5:54:45 PM> cmnlib.mbn.lz4
3/28/2019 5:54:45 PM> keymaster.mbn.lz4
3/28/2019 5:54:45 PM> apdp.mbn.lz4
3/28/2019 5:54:45 PM> msadp.mbn.lz4
3/28/2019 5:54:45 PM> non-hlos.bin.lz4
3/28/2019 5:54:45 PM> lksecapp.mbn.lz4
3/28/2019 5:54:45 PM> sec.dat.lz4
3/28/2019 5:54:50 PM> Selected file: D:\samsung firmware\C7010\C7010ZHU2CRL1_ZZH2CRL1\AP_C7010ZHU2 CRL1_CL14063952_QB21088829_REV00_user_low_ship_MUL TI_CERT_meta.tar.md5
3/28/2019 5:54:50 PM> AP_C7010ZHU2CRL1_CL14063952_QB21088829_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5
3/28/2019 5:54:50 PM> The list of files in the firmware:
3/28/2019 5:54:50 PM> boot.img.lz4
3/28/2019 5:54:50 PM> recovery.img.lz4
3/28/2019 5:54:50 PM> system.img.ext4.lz4
3/28/2019 5:54:50 PM> persist.img.ext4.lz4
3/28/2019 5:54:50 PM> userdata.img.ext4.lz4
3/28/2019 5:54:50 PM> meta-data/
3/28/2019 5:54:50 PM> meta-data/fota.zip
3/28/2019 5:54:53 PM> Selected file: D:\samsung firmware\C7010\C7010ZHU2CRL1_ZZH2CRL1\CP_C7010ZHU2 CRL1_CP11409572_CL14063952_QB21088829_REV00_user_l ow_ship_MULTI_CERT.tar.md5
3/28/2019 5:54:53 PM> CP_C7010ZHU2CRL1_CP11409572_CL14063952_QB21088829_ REV00_user_low_ship_MULTI_CERT.tar.md5
3/28/2019 5:54:53 PM> The list of files in the firmware:
3/28/2019 5:54:53 PM> modem.bin.lz4
3/28/2019 5:54:53 PM> adspso.bin.lz4
3/28/2019 5:54:55 PM> Selected file: D:\samsung firmware\C7010\C7010ZHU2CRL1_ZZH2CRL1\CSC_ZZH_C701 0ZZH2CRL1_CL14063952_QB21088829_REV00_user_low_shi p_MULTI_CERT.tar.md5
3/28/2019 5:54:55 PM> CSC_ZZH_C7010ZZH2CRL1_CL14063952_QB21088829_REV00_ user_low_ship_MULTI_CERT.tar.md5
3/28/2019 5:54:55 PM> The list of files in the firmware:
3/28/2019 5:54:55 PM> c7prolte_chn_open.pit
3/28/2019 5:54:55 PM> cache.img.ext4.lz4
3/28/2019 5:54:57 PM> Looking for EasyJTAG box...
3/28/2019 5:54:57 PM> EasyJTAG API ver. 2201
3/28/2019 5:54:57 PM> Setting IO Levels to 2.8V
3/28/2019 5:54:57 PM> Setting frequence to 21 Mhz
3/28/2019 5:54:57 PM> EasyJTAG Box Serial = 12FF9016CE5F1172
3/28/2019 5:54:57 PM> EasyJTAG Box Firmware = 1.63
3/28/2019 5:54:58 PM> Setting frequence to 21 Mhz
3/28/2019 5:54:58 PM> CMD Pullup Level: 2103 mV
3/28/2019 5:54:58 PM> CMD Active Level: 2464 mV
3/28/2019 5:54:59 PM> eMMC Init returned = 0
3/28/2019 5:54:59 PM> EMMC Device Information :
3/28/2019 5:54:59 PM> EMMC CID: 150100524331344D420CB3379A458400
3/28/2019 5:54:59 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
3/28/2019 5:54:59 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: RC14MB , HEX: 524331344D42 , S/N: B3379A45 , rev. 0x0C
3/28/2019 5:54:59 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017
3/28/2019 5:54:59 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
3/28/2019 5:54:59 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
3/28/2019 5:54:59 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
3/28/2019 5:54:59 PM> EMMC Permanent Write Protection: No
3/28/2019 5:54:59 PM> EMMC Temporary Write Protection: No
3/28/2019 5:54:59 PM> Extended CSD Information :
3/28/2019 5:54:59 PM> Extended CSD rev: 1.8 (MMC 5.1)
3/28/2019 5:54:59 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
3/28/2019 5:54:59 PM> Boot Bus Config: 0x00 , width 1bit
3/28/2019 5:54:59 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
3/28/2019 5:54:59 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
3/28/2019 5:54:59 PM> Device supports partitioning features
3/28/2019 5:54:59 PM> Device can have enhanced technological features in partitions and user data area
3/28/2019 5:54:59 PM> Device can have extended partitions attribute
3/28/2019 5:54:59 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
3/28/2019 5:54:59 PM> Backup saved: RC14MB_B3379A45_20190328_175459.extcsd
3/28/2019 5:54:59 PM> EMMC Init completed.
3/28/2019 5:54:59 PM> Operation: Write by vendor (Samsung)
3/28/2019 5:54:59 PM> Creating GPT-partitioninig
3/28/2019 5:54:59 PM> Writing PrimaryGPT at address: 000000000000
3/28/2019 5:54:59 PM> Writing BackupGPT at address: 000E8F7FBE00
3/28/2019 5:54:59 PM> Writing PIT at address: 000000004400
3/28/2019 5:54:59 PM> GPT-partitioning done
3/28/2019 5:54:59 PM> Unpacking file: sbl1.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: sbl1.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: rpm.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: rpm.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: tz.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: tz.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: aboot.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: aboot.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: sec.dat
3/28/2019 5:54:59 PM> Unpacking Lz4: sec.dat.lz4
3/28/2019 5:54:59 PM> Unpacking file: lksecapp.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: lksecapp.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: keymaster.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: keymaster.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: cmnlib.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: cmnlib.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: devcfg.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: devcfg.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: apdp.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: apdp.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: msadp.mbn
3/28/2019 5:54:59 PM> Unpacking Lz4: msadp.mbn.lz4
3/28/2019 5:54:59 PM> Unpacking file: boot.img
3/28/2019 5:54:59 PM> Unpacking Lz4: boot.img.lz4
3/28/2019 5:54:59 PM> Unpacking file: recovery.img
3/28/2019 5:55:00 PM> Unpacking Lz4: recovery.img.lz4
3/28/2019 5:55:00 PM> Unpacking file: persist.img.ext4
3/28/2019 5:55:00 PM> Unpacking Lz4: persist.img.ext4.lz4
3/28/2019 5:55:00 PM> Unpacking file: adspso.bin
3/28/2019 5:55:00 PM> Unpacking Lz4: adspso.bin.lz4
3/28/2019 5:55:00 PM> Unpacking file: modem.bin
3/28/2019 5:55:00 PM> Unpacking Lz4: modem.bin.lz4
3/28/2019 5:55:01 PM> Unpacking file: non-hlos.bin
3/28/2019 5:55:04 PM> Unpacking Lz4: non-hlos.bin.lz4
3/28/2019 5:55:04 PM> Unpacking file: system.img.ext4
3/28/2019 5:56:09 PM> Unpacking Lz4: system.img.ext4.lz4
3/28/2019 5:58:14 PM> Unpacking file: cache.img.ext4
3/28/2019 5:58:15 PM> Unpacking Lz4: cache.img.ext4.lz4
3/28/2019 5:58:15 PM> Unpacking file: userdata.img.ext4
3/28/2019 5:58:26 PM> Unpacking Lz4: userdata.img.ext4.lz4
3/28/2019 5:58:38 PM>
3/28/2019 5:58:38 PM> Partition name: SBL1
3/28/2019 5:58:38 PM> Filename: sbl1.mbn , Offset: 000000400000 , filesize: 406752 bytes
3/28/2019 5:58:38 PM> eMMC switching to ROM1
3/28/2019 5:58:39 PM> Erasing partition...
3/28/2019 5:58:40 PM> Writing partition...
3/28/2019 5:58:41 PM> Done writing partition. Write speed: 332.60 KB/s
3/28/2019 5:58:41 PM> Partition name: RPM
3/28/2019 5:58:41 PM> Filename: rpm.mbn , Offset: 000000580000 , filesize: 208636 bytes
3/28/2019 5:58:41 PM> eMMC switching to ROM1
3/28/2019 5:58:41 PM> Erasing partition...
3/28/2019 5:58:42 PM> Writing partition...
3/28/2019 5:58:43 PM> Done writing partition. Write speed: 517.78 KB/s
3/28/2019 5:58:43 PM> Partition name: TZ
3/28/2019 5:58:43 PM> Filename: tz.mbn , Offset: 000000600000 , filesize: 1547776 bytes
3/28/2019 5:58:43 PM> eMMC switching to ROM1
3/28/2019 5:58:43 PM> Erasing partition...
3/28/2019 5:58:44 PM> Writing partition...
3/28/2019 5:58:46 PM> Done writing partition. Write speed: 519.22 KB/s
3/28/2019 5:58:46 PM> Partition name: ABOOT
3/28/2019 5:58:46 PM> Filename: aboot.mbn , Offset: 000000800000 , filesize: 1862523 bytes
3/28/2019 5:58:47 PM> eMMC switching to ROM1
3/28/2019 5:58:47 PM> Erasing partition...
3/28/2019 5:58:47 PM> Writing partition...
3/28/2019 5:58:51 PM> Done writing partition. Write speed: 519.90 KB/s
3/28/2019 5:58:51 PM> Partition name: SEC
3/28/2019 5:58:51 PM> Filename: sec.dat , Offset: 000000A00000 , filesize: 692 bytes
3/28/2019 5:58:51 PM> eMMC switching to ROM1
3/28/2019 5:58:51 PM> Erasing partition...
3/28/2019 5:58:51 PM> Writing partition...
3/28/2019 5:58:51 PM> Done writing partition. Write speed: 75.64 KB/s
3/28/2019 5:58:52 PM> Partition name: LKSECAPP
3/28/2019 5:58:52 PM> Filename: lksecapp.mbn , Offset: 000000A40000 , filesize: 279160 bytes
3/28/2019 5:58:52 PM> eMMC switching to ROM1
3/28/2019 5:58:52 PM> Erasing partition...
3/28/2019 5:58:52 PM> Writing partition...
3/28/2019 5:58:53 PM> Done writing partition. Write speed: 508.15 KB/s
3/28/2019 5:58:53 PM> Partition name: KEYMASTER
3/28/2019 5:58:53 PM> Filename: keymaster.mbn , Offset: 000000AC0000 , filesize: 259032 bytes
3/28/2019 5:58:53 PM> eMMC switching to ROM1
3/28/2019 5:58:53 PM> Erasing partition...
3/28/2019 5:58:53 PM> Writing partition...
3/28/2019 5:58:54 PM> Done writing partition. Write speed: 516.49 KB/s
3/28/2019 5:58:54 PM> Partition name: CMNLIB
3/28/2019 5:58:54 PM> Filename: cmnlib.mbn , Offset: 000000B00000 , filesize: 238496 bytes
3/28/2019 5:58:54 PM> eMMC switching to ROM1
3/28/2019 5:58:54 PM> Erasing partition...
3/28/2019 5:58:55 PM> Writing partition...
3/28/2019 5:58:55 PM> Done writing partition. Write speed: 519.33 KB/s
3/28/2019 5:58:55 PM> Partition name: DEVCFG
3/28/2019 5:58:55 PM> Filename: devcfg.mbn , Offset: 000002F80000 , filesize: 71140 bytes
3/28/2019 5:58:55 PM> eMMC switching to ROM1
3/28/2019 5:58:55 PM> Erasing partition...
3/28/2019 5:58:56 PM> Writing partition...
3/28/2019 5:58:56 PM> Done writing partition. Write speed: 433.83 KB/s
3/28/2019 5:58:56 PM> Partition name: APDP
3/28/2019 5:58:56 PM> Filename: apdp.mbn , Offset: 000002FC0000 , filesize: 46272 bytes
3/28/2019 5:58:56 PM> eMMC switching to ROM1
3/28/2019 5:58:56 PM> Erasing partition...
3/28/2019 5:58:57 PM> Writing partition...
3/28/2019 5:58:57 PM> Done writing partition. Write speed: 356.30 KB/s
3/28/2019 5:58:57 PM> Partition name: MSADP
3/28/2019 5:58:57 PM> Filename: msadp.mbn , Offset: 000002FE0000 , filesize: 46272 bytes
3/28/2019 5:58:57 PM> eMMC switching to ROM1
3/28/2019 5:58:57 PM> Erasing partition...
3/28/2019 5:58:58 PM> Done writing partition. Write speed: 400.21 KB/s
3/28/2019 5:58:58 PM> Partition name: BOOT
3/28/2019 5:58:58 PM> Filename: boot.img , Offset: 000004000000 , filesize: 16115984 bytes
3/28/2019 5:58:58 PM> eMMC switching to ROM1
3/28/2019 5:58:58 PM> Erasing partition...
3/28/2019 5:59:00 PM> Writing partition...
3/28/2019 5:59:21 PM> Done writing partition. Write speed: 768.43 KB/s
3/28/2019 5:59:21 PM> Partition name: RECOVERY
3/28/2019 5:59:21 PM> Filename: recovery.img , Offset: 000006000000 , filesize: 21434640 bytes
3/28/2019 5:59:21 PM> eMMC switching to ROM1
3/28/2019 5:59:21 PM> Erasing partition...
3/28/2019 5:59:23 PM> Writing partition...
3/28/2019 6:00:00 PM> Done writing partition. Write speed: 580.08 KB/s
3/28/2019 6:00:00 PM> Partition name: PERSIST
3/28/2019 6:00:00 PM> Filename: persist.img.ext4 , Offset: 000008C00000 , filesize: 4776108 bytes
3/28/2019 6:00:00 PM> eMMC switching to ROM1
3/28/2019 6:00:00 PM> Erasing partition...
3/28/2019 6:00:02 PM> Writing partition...
3/28/2019 6:00:02 PM> Sparse image found v.1.0 Total chunks: 12
3/28/2019 6:00:08 PM> Done writing partition. Write speed: 867.22 KB/s
3/28/2019 6:00:08 PM> Partition name: DSP
3/28/2019 6:00:08 PM> Filename: adspso.bin , Offset: 00000B000000 , filesize: 16777216 bytes
3/28/2019 6:00:08 PM> eMMC switching to ROM1
3/28/2019 6:00:08 PM> Erasing partition...
3/28/2019 6:00:09 PM> Writing partition...
3/28/2019 6:00:33 PM> Done writing partition. Write speed: 691.75 KB/s
3/28/2019 6:00:33 PM> Partition name: MODEM
3/28/2019 6:00:33 PM> Filename: modem.bin , Offset: 00000C000000 , filesize: 88080640 bytes
3/28/2019 6:00:33 PM> eMMC switching to ROM1
3/28/2019 6:00:33 PM> Erasing partition...
3/28/2019 6:00:40 PM> Writing partition...
3/28/2019 6:03:29 PM> Done writing partition. Write speed: 508.11 KB/s
3/28/2019 6:03:29 PM> Partition name: APNHLOS
3/28/2019 6:03:29 PM> Filename: non-hlos.bin , Offset: 000012000000 , filesize: 25368320 bytes
3/28/2019 6:03:29 PM> eMMC switching to ROM1
3/28/2019 6:03:29 PM> Erasing partition...
3/28/2019 6:03:32 PM> Writing partition...
3/28/2019 6:04:20 PM> Done writing partition. Write speed: 518.29 KB/s
3/28/2019 6:04:20 PM> Partition name: SYSTEM
3/28/2019 6:04:20 PM> Filename: system.img.ext4 , Offset: 000014800000 , filesize: 4460645124 bytes
3/28/2019 6:04:20 PM> eMMC switching to ROM1
3/28/2019 6:04:20 PM> Erasing partition...
3/28/2019 6:09:17 PM> Writing partition...
3/28/2019 6:09:17 PM> Sparse image found v.1.0 Total chunks: 6718
3/28/2019 7:59:19 PM> Done writing partition. Write speed: 659.84 KB/s
3/28/2019 7:59:19 PM> Partition name: CACHE
3/28/2019 7:59:19 PM> Filename: cache.img.ext4 , Offset: 000168800000 , filesize: 89829596 bytes
3/28/2019 7:59:19 PM> eMMC switching to ROM1
3/28/2019 7:59:19 PM> Erasing partition...
3/28/2019 7:59:33 PM> Writing partition...
3/28/2019 7:59:33 PM> Sparse image found v.1.0 Total chunks: 16
3/28/2019 8:01:15 PM> Done writing partition. Write speed: 854.41 KB/s
3/28/2019 8:01:15 PM> Partition name: USERDATA
3/28/2019 8:01:15 PM> Filename: userdata.img.ext4 , Offset: 000175400000 , filesize: 1075387308 bytes
3/28/2019 8:01:15 PM> eMMC switching to ROM1
3/28/2019 8:01:15 PM> Erasing partition...
3/28/2019 8:57:26 PM> Writing partition...
3/28/2019 8:57:26 PM> Sparse image found v.1.0 Total chunks: 588
3/28/2019 9:17:21 PM> Done writing partition. Write speed: 879.06 KB/s
Old 04-02-2019, 11:33   #7 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
is there no support for easy jtag?
Old 04-02-2019, 11:37   #8 (permalink)
Member: 2365304
Thanks Meter: 16
without dump can't repair your phone
The Following User Says Thank You to hard drive For This Useful Post:
Old 04-02-2019, 13:37   #9 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 246
someone from support could at least say something. its not like everyone knows everything instant. that is why there are product supporters. to support the users of their products.
Old 04-03-2019, 00:05   #10 (permalink)
Member: 13148
Thanks Meter: 1,337
We have not been able to figure out why some new Samsung models are not always restored when recording firmware and dumps. This is usually due to the downgrade protection of the boot loader. (when write lowest boot version)
Old 04-03-2019, 09:45   #11 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 52
mr layder we need boot and dump file
Old 10-21-2019, 16:28   #12 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 229
can u plz share pinout.
Old 11-07-2019, 10:50   #13 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 77
C7010 pinout
c7 pro correct pinout
Page generated in 0.44492 seconds with 8 queries
